  1. Feb 24, 2026 at 5:29 PM
    BAM3
    BAM3 New Member
    Houston
    2020 Silver Sky CrewMax Platinum
    Fuel Wheels
    Where is the best place to source painted bushwacker fender flares these days?
    HulkSmurf14 likes this.
  2. Feb 24, 2026 at 5:36 PM
    Most likely they will have to be painted locally.
    bulldog93 and HulkSmurf14 like this.
  3. Feb 24, 2026 at 5:55 PM
    BAM3
    BAM3 New Member
    Houston
    Fuel Wheels
    Are they OE or aftermarket? The Tundra in my sig pic had them when i bought it. I want to add the same ones to my Silver Sky 2020.
  4. Feb 24, 2026 at 6:04 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    2017 Tundra Platinum CM 2016 4runner SR5P 2026 4runner TRDORP
    Group 24. They also didn’t have the 27.
  5. Feb 24, 2026 at 6:06 PM
    CaptRussia253
    Ruslan
    This! I have a battery jumper but it was dead so I pulled out the cables.
  6. Feb 24, 2026 at 6:07 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    You still won’t.
    24F worked perfectly for me in the last truck.
  7. Feb 24, 2026 at 6:08 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Pay it forward so @TRDFerguson can get his gears done, then he can pay it forward so I can get mine done…in perpetuity…
  8. Feb 24, 2026 at 6:12 PM
    OEM flares are hard to find. Not many trucks had them. They were more common on the 07-13's than the 14-21's. I have aftermarket Bushwackers on mine but I had them Line-X'ed.
  9. Feb 24, 2026 at 6:18 PM
    CaptRussia253
    Ruslan
    My last battery was a Costco 27f. The one next to me just didn’t have one in stock. I have zero concerns about running a 24f.
  10. Feb 24, 2026 at 6:21 PM
    joseph_womack
    joseph_womack Insta @ 4x4bound
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    then you can pay it forward to me :D
  11. Feb 24, 2026 at 6:37 PM
    RainMan_PNW
    Casey
    Clark County, WA
    27F flooded.
    Interstate didn’t make an AGM in that size
  12. Feb 24, 2026 at 6:45 PM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    2018 Crewmax 1794 4x4
    two is one
    StevetheBreeze likes this.
  13. Feb 24, 2026 at 6:49 PM
    centex
    centex New Member
    One is none.
  14. Feb 24, 2026 at 7:26 PM
    Dr3wski
    Dr3wski New Member
    2018 SR5 4x4
    Finally got the skid installed
    Nbab23, 300BLK, Henry1jg and 11 others like this.
  15. Feb 24, 2026 at 7:54 PM
    blenton
    blenton New Member
    Late to the party, but, yes the throttle settings in 4Lo are horrible and designed to keep things from breaking. But they can easily be modified with a tune. Or you can just get HP Tuners, some credits, and modify those throttle settings yourself.
    If memory serves from the last time I looked at the stock settings, you don't get full beans in 4Lo in any gear. They limit the throttle opening angle and really dumb it down. You get a little bit of throttle opening right off idle, but then everything after that is REALLY slow to open the throttle blade, especially compared to how standard 2wd throttle behaves. And to boot, the throttle angle is limited at RPM, so if you don't have enough power to get over a certain RPM, the throttle remains more closed than open.
    Good news is, you can change all of that.
    Years ago, Expedition Overland purchased a tundra, kitted it out, and then struggled to complete a trail on one of their episodes. They assumed the high altitude of the trail and heavy weight of the vehicle were to blame. In reality, the found that limit where a stopped vehicle attempting to overcome an obstacle hits the converter stall and is throttle-limited by the nannies no matter how far you push down the pedal. Basically, after 30 or 40% pedal, IIRC, you aren't getting any additional throttle body opening with additional pedal input.
    ATRAC is usually pretty helpful in 4Lo, IMO. Unless you need lots of wheel speed. But then see the comments above...
    You don't need to worry about a relay spoofing switch box to fix 4Lo. A tune from OTT or others can fix that :)
    I also carry an M18 inflator in all of my vehicles. Airing down has bailed me out of some hairy situations in the snow where I would have otherwise been spending the night in the middle of nowhere without cell service. Usually I tell my wife when I'll be out of cell service and might not be home to the next day. But I'd rather pack the inflator and give myself a better chance of getting home.
    On one occasion, I unloaded my trailer at a cabin in the middle of nowhere and spent the day working. There was about 7' of snow piled up - more where the trail in and "driveway" had been plowed - and at least a foot of base snow on the road. Sunny, warmish day caused the snow to compress, then it got cold and started snowing for a couple of hours before I left. 8-10 inches of fresh heavy snow on top of a compacted, wet, partially frozen base and I had to hitch up on my trailer on a graded "driveway" and I basically slide down backwards with little to no control until I bumped in to trailer tongue. Took about 5 attempts to position the truck since it was so slick the truck either moved sideways or kept sliding. After a half dozen attempts in various drive modes and nanny modes, I had iced up several spots. I knocked 20 psi out of the tires and literally didn't spin a tire dragging the trailer out of there.
    I would have been fine overnight; no power at the cabin, but it was a dry place to sleep. But I was much happier to drive 10 miles down the road aired down then spend another 10 minutes airing up.
  16. Feb 24, 2026 at 8:10 PM
    HondaDad
    HondaDad New Member
    Kreeg
    Oregon
    2019 TRD Sport
    I appreciate the response. Once I realized I was only making it worse by trying to just drive out, I got tunnel vision on my shovel as the only way to fix things, never considered airing down until it was mentioned above. Hindsight is always 20/20 I guess :rolleyes: I’ll be better prepared next time.
  17. Feb 24, 2026 at 8:17 PM
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    Great info, as always
    so off of that; pulling the abs fuse would not change the throttle sensitivity/mapping for 4Lo, you’d kill the nannies completely but you would not change up the “available” throttle
    as someone who hasn’t needed high speed with 4Lo (minus backing up a foot and bumping it - not many rocks in La lol) wouldnt it be ideal to switch to 4Hi since you’ll gain the throttle availability back? And you don’t run the risk of glazing the tcase clutches either
    edit: just remembering my 07 was tuned by YotaWerx with a “beta/preliminary” tune for the 2nd gen 4.7; so perhaps they changed the 4Lo throttle mapping and never said anything about it. Wheeled with the tune for probably 2.5-3 years
  18. Feb 24, 2026 at 8:18 PM
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    I think I still have my parts list for my cheap 4 tire deflater if you want me to check. I think all in on parts was like $70 or less
    bulldog93, CaptRussia253 and AZTundra like this.
  19. Feb 24, 2026 at 8:26 PM
    blenton
    blenton New Member
    Luckily, there aren’t any clutches in these transfer cases; once they are locked in they are locked in. You would be putting more strain on the transmission in 4Hi - the converter specifically. But really you would be quickly adding lots of heat to the system. 4Lo is really advantageous for that. I don’t recall offhand the throttle mapping for 4high.
    I had an old bronco with a 400m and np205 tcase with its abysmal 1.96:1 low range (but indestructible gears). After flat top pistons, an RV cam, a 4 barrel carb and Edelbrock intake, it make gobs of torque and 4Lo was rarely needed. But when it got hot, I’d have to shift in to 4Lo and the temps would drop.
    I know I’m bagging on how limited 4Lo is, but it’s gotten me out of some pretty sticky places before being tuned. So it works well-enough most times. Just that scenario of being stopped with an obstacle or lots of snow/sand/mud and needing to lean on the converter to get going.
  20. Feb 24, 2026 at 8:27 PM
    blenton
    blenton New Member
    Do tell. I just carry these in my truck but a slick setup would be nice.
  21. Feb 24, 2026 at 8:28 PM
    HondaDad
    HondaDad New Member
    Kreeg
    Oregon
    2019 TRD Sport
    joseph_womack[QUOTED] likes this.
  22. Feb 24, 2026 at 10:27 PM
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    Huh, I could have sworn I read on here that the 14-21 case switched to borg warner as the manufacturer and that it had clutches (hence the fluid change to 75w) vs the 07-13 case that was chain driven
    unless it’s not clutches but just gears?
    yeah for sure, 4Lo has done well for me on low speed crawling, just always seemed strange to me to need wheel speed and not go up to 4Hi; but I get the appeal
    blenton[QUOTED] likes this.
  23. Feb 24, 2026 at 10:28 PM
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    blenton[QUOTED] and bulldog93 like this.
  24. Feb 24, 2026 at 11:57 PM
    blenton
    blenton New Member
    I wonder if you are thinking about shift synchros? I mean, I could very well be wrong, but I don’t see any reason to have any clutches in that t case since it doesn’t have Auto4WD. The only T cases I know of with clutches were either viscous coupling type AWD transfer cases or Auto4WD cases that uses a clutch and electromagnet to engage and disengage the front driveshaft on demand while leaving the actual case in 4wd. I had an old exploder that had this type of t case. A popular mod was the ‘brown wire mod’ where you manually locked the frint driveshaft clutch since 4Hi was actually Auto4WD. I learned that the hard way after burying the thing in a 3 foot snowdrift o_O
    I think this is the same type of mechanism that Ford and GM use (or used at some point) to offer Auto4WD, which really means 2wd unless you slip a tire.
    The sequoia and Land Cruiser cases don’t use clutches either. They have a helical gear planetary gear set and an extra step in the shift fork range to engage the planetary or lock it out, which gives it AWD and 4WD (and differs from Auto4WD).
    Mdl and HulkSmurf14 like this.
  25. Feb 25, 2026 at 4:13 AM
    glazer1972
    glazer1972 New Member
    East TX
    21 Tundra SR5 4x4 TSS Crewmax
    Used a CARISTA OBD2 to turn off my front seat belt chimes.
  26. Feb 25, 2026 at 4:18 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,AL
    2020 SR5 Barcelona Red CREWMAX 4x4
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 KSP 1.25" Spacers Coachbuilder Shackles +2 Gator retractable bed cover 12Volt systems remote start Dasaita Android 13 A/C & 4WD Knobs from AJT Center console lid battery charger Cartrimhome Auto up switches CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light Coupe Battery Hold Down Under Hood LED ESP Rear under seat storage Blue Sumo's rear Superbumps up front Fumoto oil valve TRD RAD CAP TRD Billet oil cap Auxbeam 42" Curved lower bumper LED Auxbeam Pro ditch lights Auxbeam rear 4" work lights Firehawk 42" LED BAR mounted on roll up cover 3 panel switch behind shifter from Rainman Rear window switch move next to Tow/Haul switch Bullet point dash mount
    Did the same with my Launch Creader Elite and also changed the unlock all 4 doors with one press of the button on my key fob :)
    Sean492, koditten, bulldog93 and 2 others like this.
  27. Feb 25, 2026 at 6:51 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    No clutches and both use chains.
  28. Feb 25, 2026 at 7:24 AM
    seydou
    seydou Distinguished Member
    Isn't this something that can be done via the head unit?
    NewImprovedRon likes this.
  29. Feb 25, 2026 at 7:28 AM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    joseph_womack and BR73 like this.
  30. Feb 25, 2026 at 7:55 AM
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    Well thats what always confused me when I read it here; why would they switch to clutches for a transfer case?
    Just checked the parts diagrams and you're right, still gear sets and chain driven; they're a little different across 2nd gen vs 2.5 gen so they did change a little bit
    07:
    19:
