  1. Feb 24, 2026 at 5:04 AM
    HondaDad
    HondaDad New Member
    Kreeg
    Oregon
    2019 TRD Sport
    In his thread, he was talking about it cutting throttle out right as he was trying to bump up & over big rocks when crawling.
  2. Feb 24, 2026 at 5:05 AM
    joseph_womack
    joseph_womack Insta @ 4x4bound
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    Ohhhhh, then I could see the appeal there, but pulling the ABS fuse should have the same result
    HondaDad[QUOTED] likes this.
  3. Feb 24, 2026 at 5:07 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,AL
    2020 SR5 Barcelona Red CREWMAX 4x4
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 KSP 1.25" Spacers Coachbuilder Shackles +2 Gator retractable bed cover 12Volt systems remote start Dasaita Android 13 A/C & 4WD Knobs from AJT Center console lid battery charger Cartrimhome Auto up switches CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light Coupe Battery Hold Down Under Hood LED ESP Rear under seat storage Blue Sumo's rear Superbumps up front Fumoto oil valve TRD RAD CAP TRD Billet oil cap Auxbeam 42" Curved lower bumper LED Auxbeam Pro ditch lights Auxbeam rear 4" work lights Firehawk 42" LED BAR mounted on roll up cover 3 panel switch behind shifter from Rainman Rear window switch move next to Tow/Haul switch Bullet point dash mount
    PXL_20250918_224203054.MP.jpgYES
  4. Feb 24, 2026 at 5:08 AM
    HondaDad
    HondaDad New Member
    Kreeg
    Oregon
    2019 TRD Sport
    It was definitely a learning experience for me, luckily I had my young daughters’ commentary to help my shoveling out :rofl:. I’ll be going for the air down & boards right away next time. I don’t have enough time on them yet, but as of now I much preferred the 275 KO2 over the 295 wildpeak in snow.
  5. Feb 24, 2026 at 5:23 AM
    Vizsla
    Vizsla sGU #2
    4LO has throttle limits, pulling the ABS fuse does not change them.
  6. Feb 24, 2026 at 5:26 AM
    HondaDad
    HondaDad New Member
    Kreeg
    Oregon
    2019 TRD Sport
    I certainly found them. I was rocking back & forth to get momentum, and any progress I made was quickly negated by a lazy pedal after the R-D change.
  7. Feb 24, 2026 at 6:55 AM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    Love the @Cruzer Re-build for the Rubicon thread. Many hours of entertainment and information in there.
  8. Feb 24, 2026 at 7:34 AM
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    It’s also just a difference in tire compound and tread pattern; ko2s suck in mud or clay but from what I’ve heard they work well in snow
    air down to 18 or lower; since it’s snow you shouldn’t have to sweat too much about debeading the tire
  9. Feb 24, 2026 at 7:37 AM
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    Meaning throttle limits not imposed from traction control?
    but yeah that’s kind of the point; the 07-13 cases were chain driven so you risk stretching the chain if too much power is thrown through it; with the clutches on the 14-21 you could glaze them
    Boneskull420 likes this.
  10. Feb 24, 2026 at 7:39 AM
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    Next time if you’re trying to rock back and forth, I’d do it in 4Hi if it were me, I’ve been in the same scenario in mud and 4Hi won’t cut throttle quickly shifting from R-D
    bulldog93, HondaDad[QUOTED] and BR73 like this.
  11. Feb 24, 2026 at 7:54 AM
    centex
    centex New Member
    Swapped in the turbokits x3 MAF in place of the x2. Let the retuning begin.
  12. Feb 24, 2026 at 7:57 AM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    2018 Crewmax 1794 4x4
    thanks!
    Boneskull420 and RobertD[QUOTED] like this.
  13. Feb 24, 2026 at 7:58 AM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    thanks!
  14. Feb 24, 2026 at 8:14 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Ordered 12pt hardware and chromoly lugs for the new wheel package.
  15. Feb 24, 2026 at 9:16 AM
    831mic
    831mic 2016 DC TRD PRO
    California
    '16 DC TRD PRO
    Will do. I got it built out in Solidworks, just need to make the exploded view and do the write up. Hoping to have it done by this weekend.
  16. Feb 24, 2026 at 9:19 AM
    Vizsla
    Vizsla sGU #2
    Yes. Example of Tundra 1st gear and reverse engine throttle limits vs. rpm below, 86% is WOT, idle is approximately 10% iirc..
  17. Feb 24, 2026 at 9:53 AM
    Kung
    KG, VA
    NewImprovedRon and HondaDad like this.
  18. Feb 24, 2026 at 10:16 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Look man if you won the lottery you can just tell us, we'll still be your friends
  19. Feb 24, 2026 at 10:49 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Wallygator, Mdl, Bergy24 and 7 others like this.
  20. Feb 24, 2026 at 12:09 PM
    ARGrider
    ARGrider New Member
    2017 Tundra Platinum
    Switched out the old antenna with one from Cravenspeed
  21. Feb 24, 2026 at 12:22 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
  22. Feb 24, 2026 at 12:41 PM
    SAGE63
    San Diego County
    Again no pictires... FINALLY Yesterday the rear diff with 5.29 gears and (new) Eaton e-locker from my rolled Tundra was installed in the replacement Tundra
    call out to Premier West Grears in Riverside Ca for their work and getting the replacement locker from Eaton under warentee....not a simple process...
    So now I have a 2021 stock 4.30 geared 70k mile third member sitting in a bin in my garage. Looking for some thoughts on how much I should put it up for sale at. toyota sells new at $1800 ish, ebay and others I saw at $1100-$1200.
    So what do you all think I should price it at here on the market place?
    Thanks
  23. Feb 24, 2026 at 1:55 PM
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    Go on eBay and select “completed items” and “sold items” for your 3rd member search. That’ll tell you the day that item sold and for how much; it’ll get you a good idea what they’re going for
  24. Feb 24, 2026 at 3:03 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    2017 Tundra Platinum CM 2016 4runner SR5P 2026 4runner TRDORP
    Battery kept dying so I replaced it with a Costco agm. Waiting on a new battery holder to replace the rusty factory one.
  25. Feb 24, 2026 at 3:30 PM
  26. Feb 24, 2026 at 3:35 PM
    SAGE63
    San Diego County
    Thanks
  27. Feb 24, 2026 at 3:39 PM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    Group 24? I couldn't find a Group 27 AGM at the time of replacement.
    HulkSmurf14 likes this.
  28. Feb 24, 2026 at 4:34 PM
    Terndrerrr
    Terndrerrr 913000 miles to go
    Music City
    6UR-FE
    Neighbor lady wanted to pay my kids to haul a bunch of downed limbs and branches from the recent storm to the curb, so we did that this afternoon for a couple hours. She paid them each $20.
    She paid me $20, too :yes::laugh:
  29. Feb 24, 2026 at 4:39 PM
    centex
    centex New Member
    koditten, bflooks, Gaston and 5 others like this.
  30. Feb 24, 2026 at 4:48 PM
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    I’m sure you know, but make sure if you have a voltage booster if you don’t already
