  1. Feb 15, 2026 at 9:24 AM
    23Tundy
    23Tundy New Member
    SE Pa
    19 SR5 Cement crewmax
    5100s,Diode Dyn fogs, ARE topper, AJT interior chrome delete, meso lights/vleds, RC neoprene seat covers.
    Yep. Love the “rust belt”. Passenger side came out easy peasy with the m12 stubby. Driver side, not so much I had it soaking in Kroil all night. so we’ll give it another shot today
  2. Feb 15, 2026 at 9:28 AM
    23Tundy
    23Tundy New Member
    SE Pa
    Also just finished replacing both inner and outer tie rods on both sides. With a ton of help from @blenton and @Yota303. IMG_6579.jpg IMG_6578.jpg IMG_6577.jpg
  3. Feb 15, 2026 at 11:09 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,AL
    2020 SR5 Barcelona Red CREWMAX 4x4
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 KSP 1.25" Spacers Coachbuilder Shackles +2 Gator retractable bed cover 12Volt systems remote start Dasaita Android 13 A/C & 4WD Knobs from AJT Center console lid battery charger Cartrimhome Auto up switches CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light Coupe Battery Hold Down Under Hood LED ESP Rear under seat storage Blue Sumo's rear Superbumps up front Fumoto oil valve TRD RAD CAP TRD Billet oil cap Auxbeam 42" Curved lower bumper LED Auxbeam Pro ditch lights Auxbeam rear 4" work lights Firehawk 42" LED BAR mounted on roll up cover 3 panel switch behind shifter from Rainman Rear window switch move next to Tow/Haul switch Bullet point dash mount
    You drained 5qts out so I would put back 5.5qts to make sure you have enough which probably won't be coming back out of the fill hole then run the temp level check. Don't forget to run it through the gears after you first fill it while it's warming up with your foot on the brake.:)
  4. Feb 15, 2026 at 11:23 AM
    Of course reply after I put the skid and cat plates back on LOL.
  5. Feb 15, 2026 at 1:24 PM
    23Tundy
    23Tundy New Member
    SE Pa
    And finally got the bed stiffeners in. Won’t be able to to test until later this week after the alignment from tie rod work. IMG_6588.jpg IMG_6587.jpg
  6. Feb 15, 2026 at 2:07 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    Is the Digits only plan a physical SIM card you have to request from the store then insert it into the SIM card reader on the HU? Or can it be done by installing the Digits app on one or both phone and HU?
    BR73[QUOTED] likes this.
  7. Feb 15, 2026 at 2:32 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Yeah, this was the first time working on those for myself...surprisingly torqued!
    23Tundy[QUOTED] likes this.
  8. Feb 15, 2026 at 2:38 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,AL
    Physical SIM card from the store that inserts into the head unit via a plug in harness. There's a thread on the forum just for Dasaita HU
  9. Feb 15, 2026 at 2:44 PM
    TacomaTRD4x402
    Southern California
    Okay gotcha, thank you. Yeah I already have the Dasaita hu hooked up. I've just been using Android Auto for the couple weeks that I've had it installed but thinking of trying the SIM. There are certain minor things about android auto that I don't care too much about do might give the SIM a try.
    Thanks again :thumbsup:
  10. Feb 15, 2026 at 2:47 PM
    Kung
    KG, VA
    Drove it and the family to stop by this house.
  11. Feb 15, 2026 at 2:50 PM
    Jim LE 1301 Camaro Lover, SSEM # 11
    How's the new construction going?
    Kung[QUOTED] and Wallygator like this.
  12. Feb 15, 2026 at 2:53 PM
    Kung
    KG, VA
    It’s definitely going, but it doesn’t exactly look like a normal construction site, obviously. LOL
  13. Feb 15, 2026 at 3:05 PM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    Installed the sPOD switch panel today and also got the data cable run through the firewall to the terminal control block in the engine bay. Turned out really nice using the RMF 001 sPOD mini6 console insert. Thanks @RainMan_PNW for making this great product.
    :fistbump:
  14. Feb 15, 2026 at 3:52 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,AL
    Yeah I'm using Android Auto also and with the SIM watching YouTube TV:)
    joseph_womack and bulldog93 like this.
  15. Feb 15, 2026 at 3:57 PM
    Wallygator
    Anyone heard of these LCA's? I have a frozen one and they are saying it needs to be cut out. :rolleyes: Honestly I don't know which direction to go? And it seems to be a recurring issue with the stock parts
  16. Feb 15, 2026 at 4:21 PM
    blenton
    blenton New Member
    Is it this kit linked?
    https://freedomoffroadusa.com/oem-r...l-arms-w-cam-bolts-and-ball-joints-fo-t703fl/
    If so, it appears that they aren't much different price wise than OE stuff from Toyota. I just purchased both LCA's for my '13 from from Fred Anderson; with their 25% off sale and free shipping it was $417 to my door. They don't have 25% off right now but do have 15% off and free shipping, so $450ish to your door without the cam bolts.
    Freedom's listing says 'heavy duty OE Style balljoint' which makes me thing that they an aftermarket reproduction. As for quality, I can't speak to Freedom Offroad's gear good or bad. So maybe they are stellar, maybe they aren't. I wonder how much they weigh? I ask that because there was a YhouhgToober comparing 1st gen LCA's and the cheaper knockoffs were a good deal lighter with much flimsier metal.
    bulldog93 and 23Tundy like this.
  17. Feb 15, 2026 at 4:48 PM
    Racer X
    Racer X New Member
    Bob
    North Carolina
    2018 Tundra Limited 4WD 5.7 V8
    I don’t know about lowers, but I had their upper control arms on my FJ Cruiser. They seemed solid, I had them for about 60k miles and no problems.
    Wallygator[QUOTED] and bulldog93 like this.
  18. Feb 15, 2026 at 4:48 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA 1 7/8 Longtubes, Snivs 1.88 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT Trans/valve body, 4.5inch intake with 10x2 SABM, FIC 880/930cc injectors, 450 Walbro, Direct Port W/M injection, GM 95mm TB, DW fuel regulator, E-fan, Remote engine air/oil cooler, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    joseph_womack, bulldog93 and Yota303 like this.
  19. Feb 15, 2026 at 5:02 PM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    yep, she was off spending money elsewhere
  20. Feb 15, 2026 at 5:08 PM
    :thumbsup:
  21. Feb 15, 2026 at 5:10 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Repurposed this light from another vehicle...
  22. Feb 15, 2026 at 6:56 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Crossed a small item off the rebuild list…
  23. Feb 15, 2026 at 7:14 PM
    explorerst4x4
    explorerst4x4 I wonder if tacos think about me too?
    Marc
    Cincinnati
    2017 Tundra DC SR5 MGM "Donkey"
    Nothing.
    Finally ordered the wiring harness from Mario, to install the 2018+ TRD Pro LED headlights.
    Originally it said arrival of Sat evening.
    But then it sat in Indianapolis USPS for nearly 24 hours before moving. Something else I ordered also sat in Indy USPS distribution center for 24 hours.
    Good thing I didn't take my headlights off in anticipation Sat morning, cause I almost did.
    First world problems, amiright?
    BR73, Yota303, joseph_womack and 3 others like this.
  24. Feb 15, 2026 at 10:38 PM
    DirkS
    DirkS New Member
    Dirk
    Abbotsford, BC
    2016 Tundra Limited
    The harness is worth waiting for. Makes it so simple.
  25. Feb 16, 2026 at 6:05 AM
    HondaDad
    HondaDad New Member
    Kreeg
    Oregon
    2019 TRD Sport
    Hit the caps with an old school rub down. I’m thinking about the sunrise red I’ve seen on here for the tow hooks & these toyota symbols. I plan to do a TRD skid plate and it seems to match nicely. IMG_7560.jpg
    Nbab23, 23Tundy, bulldog93 and 6 others like this.
  26. Feb 16, 2026 at 6:53 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,AL
    I did mine with Duplicolor from AutoZone. Barcelona Red PXL_20250823_235705242.jpg
  27. Feb 16, 2026 at 8:24 AM
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    With the road quality in LA, or lack thereof, people actually speed there?
  28. Feb 16, 2026 at 8:32 AM
    Redtom4U
    Redtom4U Just me and the girls
    Tom
    South Chesterfield Va
    2016 Tundra Super White TRD DC 4WD
    You could also try these.
    Wheel Center Cap, Trd Pro
    pt28034150
  29. Feb 16, 2026 at 8:34 AM
    Redtom4U
    Tom
    Hey Rick are those TRD wheels? Just asking for a friend.
  30. Feb 16, 2026 at 8:37 AM
    Wallygator
    Thanks. Only reason I am considering the aftermarket option is because the stock design is clearly a design that is going to freeze up again in the future. Just not wanting to have to cut out lower control arms every time I need an alignment. Truck is only 6 years old and the lower control arms need cut out, ridiculous!
    ATV25 likes this.
