  1. Feb 12, 2026 at 5:11 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,AL
    2020 SR5 Barcelona Red CREWMAX 4x4
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 KSP 1.25" Spacers Coachbuilder Shackles +2 Gator retractable bed cover 12Volt systems remote start Dasaita Android 13 A/C & 4WD Knobs from AJT Center console lid battery charger Cartrimhome Auto up switches CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light Coupe Battery Hold Down Under Hood LED ESP Rear under seat storage Blue Sumo's rear Superbumps up front Fumoto oil valve TRD RAD CAP TRD Billet oil cap Auxbeam 42" Curved lower bumper LED Auxbeam Pro ditch lights Auxbeam rear 4" work lights Firehawk 42" LED BAR mounted on roll up cover 3 panel switch behind shifter from Rainman Rear window switch move next to Tow/Haul switch Bullet point dash mount
    Be sure to watch the YouTube video with this kit
  2. Feb 12, 2026 at 5:17 PM
    I just ordered the tubing for the transmission drain and fill. I just hit 64K today.
  3. Feb 12, 2026 at 5:19 PM
    Black Forest Tundra
    Black Forest Tundra New Member
    Bill
    Black Forest, CO
    2021 Cement Limited CM
    7" BDS Coilovers, 37x12.50x18's on Fuel wheels. AMP Research Powersteps, (2) JL Audio 10W3's , Focal components, JL Audio power, Rigid lighting
    Swapped out the limited grill for the pro grill. Next up are the bumpers to finally rid this of the last piece of chrome! IMG_3717.jpg IMG_3723.jpg
  4. Feb 12, 2026 at 7:03 PM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Make sure you use it outside where there's sunlight or have a black light handy. I made the mistake of fixing a similar chip on my 23' Sienna Hybrid and it was raining outside.. no way to really cure it.
    bulldog93 likes this.
  5. Feb 12, 2026 at 7:04 PM
    19_Sr5_XSP
    19_Sr5_XSP New Member
    PA
    2019 Sr5 XSP
    None for now
    Looks great!
  6. Feb 13, 2026 at 2:28 AM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    Looks better. :thumbsup:
  7. Feb 13, 2026 at 6:17 AM
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    Been there! I'd highly suggest before you get started, as in a few days, use some PB blaster or the likes on the bushings. Take your time and be prepared to curse like a sailor. It's not hard, just somewhat tedious.
  8. Feb 13, 2026 at 6:18 AM
    00h2itr
    00h2itr New Member
    Carolina's
    Love seeing another Cement with Pro grill. Much improved sir.
  9. Feb 13, 2026 at 6:27 AM
    Tripleconpanna
    2021 TRD PRO CM; 2011 SR5 SC'd DC; 2008 SR5 CM
    Obligatory kitchen photo...
    DW300c Fuel pump and DW 650s
    mqqn, Nbab23, BlueRibbon4x4 and 16 others like this.
  10. Feb 13, 2026 at 7:11 AM
    yakeng
    yakeng 3URFE^2
    Kawasaki Ultra 160
    ECGS Bushing; GCS Cooler RASHD; Eibach 2.0, DK UCA
    Did you have to change the harness or pins at all? There are some folks who had issues swapping this and ended up blowing their main fuse. I had to replace my 2020's blower as it failed and the factory replacement is starting to get pretty noisy. I'm beginning to think the last batch that was made for the 2020-2021's are problematic.
    BR73 and 1794TX like this.
  11. Feb 13, 2026 at 7:50 AM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    2018 Crewmax 1794 4x4
    Kuat confirmed that they will not likely be making the side panel kit for full size trucks. bummer.
  12. Feb 13, 2026 at 8:21 AM
    250000yota
    250000yota New Member
    Russ
    CO
    Black '21 Trail Edition CM
    2021 Black Trail Edition Crewmax
    Got after it and installed the easy as pie front hitch last night in prep for a light wheeling trip this weekend. 99% chance I won't need the winch for the trails were looking at doing but the Boy Scout in me said to, and you know I've gotta listen to that guy...
    Didn't lose any true ground clearance like I was worried about but obviously the front approach angle is going to suffer significantly. I have a hitch skid in the shed, I think I'll put it in to prevent too much bashing. It will also make putting my RCI skid on the new truck a little more of a challenge, but I think I'll take the opportunity to get some longer 10.9 bolts to attach the hitch a little better, as I bought the hitch used and the bolts the seller supplied are not for the Tundra. It mounts using the tow hook mounting bolts.
    mqqn, HulkSmurf14, _none_ and 6 others like this.
  13. Feb 13, 2026 at 8:35 AM
    Tikka Shooter
    Tikka Shooter New Member
    2011 VW GTI
    Does this interfere with the factory skid plate at all? Which model hitch is this? I'm looking to install one for a front bike rack.
    Thanks!
    joseph_womack likes this.
  14. Feb 13, 2026 at 8:39 AM
    250000yota
    Russ
    CO
    It is the Draw-Tite 65080 front hitch.
    Yes, it does interfere with the front mounting bolts, which will hinder my RCI skid plate install eventually. I will recommend that if you do install the hitch, do it in conjunction with an aftermarket skid or cut your factory to allow access to your oil filter.
  15. Feb 13, 2026 at 9:09 AM
    Fergie
    Fergie New Member
    I used the UV light I used for curing epoxy on flies; worked well for me, and no issues w the patch popping out.
    Jbehredt, HulkSmurf14 and BR73 like this.
  16. Feb 13, 2026 at 9:15 AM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    No. It's plug and play if you order the correct one. Those who blew their fuses and such ordered the wrong part.
  17. Feb 13, 2026 at 9:24 AM
    1794TX
    Steven
    N.TX
    '20 1794
    ^^That link takes you to the part. That's what I ordered for my 2020, and it's definitely plug and play. You should be able to get it 15% off right now.
  18. Feb 13, 2026 at 9:51 AM
    NEVERGIVEUP
    NEVERGIVEUP New Member
    2021 Super White Tundra SR5 CM
    Did you do anything to your splash guard/skid?
  19. Feb 13, 2026 at 11:08 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,AL
    PXL_20250518_113619683.MP.jpgTHIS:spending:
  20. Feb 13, 2026 at 11:53 AM
    250000yota
    Russ
    CO
    The previous owner trimmed the sides off, but I'll be installing my RCI skids at the next oil change anyway.
    bulldog93, Tripleconpanna and BR73 like this.
  21. Feb 13, 2026 at 12:47 PM
    Changed oil, swapped out the Fumoto for the Valvomax, and installed the SQHQ ABS Guards from @xrunnerdude67
    mqqn, Wallygator, bulldog93 and 9 others like this.
  22. Feb 13, 2026 at 12:57 PM
    Fergie
    Fergie New Member
    Looks like they redesigned the ABS guards. Mine are far chonkier and used an allen head bolt. Definitely worth the peace of mind as I fragged a sensor in a snowstorm a few years back.
  23. Feb 13, 2026 at 1:27 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    2017 Tundra Platinum CM 2016 4runner SR5P 2026 4runner TRDORP
    All skid plates removed in preparation for gears/locker/lsd install in two weeks. Also had time for an oil change this morning.
    mqqn, Wallygator, Velocity72 and 16 others like this.
  24. Feb 13, 2026 at 1:30 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA 1 7/8 Longtubes, Snivs 1.88 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT Trans/valve body, 4.5inch intake with 10x2 SABM, FIC 880/930cc injectors, 450 Walbro, Direct Port W/M injection, GM 95mm TB, DW fuel regulator, E-fan, Remote engine air/oil cooler, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Just double check part number is for LandCruiser NOT Sequoia. Sequoia has polarity reversed.
  25. Feb 13, 2026 at 1:52 PM
    Corndog123
    Corndog123 Knife creator.
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    I changed the oil in both diffs and the transfer case. :thumbsup:
    mqqn, TreeCat, Wallygator and 15 others like this.
  26. Feb 13, 2026 at 3:12 PM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    had to have the obligatory kitchen table picture.
    now just waiting for the time to install front brakes and DD 10" exhaust
    mqqn, 23Tundy, WILLINH and 18 others like this.
  27. Feb 13, 2026 at 3:59 PM
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    What wheels are these? Do you have any pics of em? They look awesome!
    Corndog123 and joseph_womack like this.
  28. Feb 13, 2026 at 4:04 PM
    Are those the Cryo treated and slotted rotors? I have them currently but I have to order another set. They have only been on since May or so but I had some vibration issues and the rotors have ridges. I'll get some pics tomorrow.
    Corndog123 likes this.
  29. Feb 13, 2026 at 4:24 PM
    Ebrperk
    Ebrperk Old member
    2018 1794 MGM
    Yes, they are. Ordered them with my exhaust from dirty deeds.
    bulldog93, Corndog123 and HulkSmurf14 like this.
  30. Feb 13, 2026 at 4:27 PM
    I haven't compared his prices to Frozens prices. I ordered directly from them back in the spring.
    HulkSmurf14 and Corndog123 like this.
