  1. Jan 24, 2026 at 5:35 PM
    joseph_womack
    joseph_womack Insta @ 4x4bound
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    Awesome, thank you! Are you still rocking the factory halogen map lights and wanted the red?
    Dr3wski[QUOTED] likes this.
  2. Jan 24, 2026 at 5:53 PM
    Dr3wski
    Dr3wski New Member
    2018 SR5 4x4
    I have Vleds 5K map lights and wanted the option for red at night
  3. Jan 24, 2026 at 6:06 PM
    Tripleconpanna
    2021 TRD PRO CM; 2011 SR5 SC'd DC; 2008 SR5 CM
    :notsure:
  4. Jan 24, 2026 at 6:11 PM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    Did the front diff and t-case drain and fill today, Amsoil 75w-90 in both. Luckily no struggle with the front diff drain or fill plugs but still swapped them out with the Lexus style plugs since I had ordered them a while back. Glad to have that done with as I had been putting it off for a while.
    *Side note:
    The front diff drain plug I ordered part# 90341-24016 fit a 14mm socket, I was expecting it to be a 24mm similar to the rear diff drain/fill plugs. Curious if that matches what others have for that same part number?
  5. Jan 24, 2026 at 7:25 PM
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    Yep, 14mm. But there are replacement plugs off Amazon that are a 24mm. I’ve got a couple saved in my cart that are magnetic also
  6. Jan 24, 2026 at 7:39 PM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    crap! I'm seeing problems now. Hmm.. It worked fine after installing and testing. 4 hrs later and there's problems. Not sure what to do there. I'll post a new thread to see if anyone can help me.
  7. Jan 24, 2026 at 7:40 PM
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    Are you actively towing? And are you sure you plugged everything in completely?
  8. Jan 24, 2026 at 7:42 PM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    I'm not towing. The trucks just parked.
    Errors
    SRS,
    TPMS,
    Trailer,
    Rear cross traffic,
  9. Jan 24, 2026 at 7:43 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    i'm not familiar with the install for this, but sounds to me like you've got a harness not fully plugged in.
    bulldog93 and joseph_womack like this.
  10. Jan 24, 2026 at 7:43 PM
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    Double check everything that you touched, confirm every connector is firmly seated
  11. Jan 24, 2026 at 7:45 PM
    Yota303
    Washington
    Ok nice thank you for confirming, I was just thinking 24mm would be stronger than 14 if it ever seized up like the 10mm hex plugs do, the 14mm looks a little small on a plug that big but only 29lbs torque though so I guess it’s fine.
    bulldog93 and HulkSmurf14 like this.
  12. Jan 24, 2026 at 7:45 PM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    I did plug it into the wrong plugs the first time and then had to redo the plugs. Maybe that did something, wonder if I can just simply "reset" it with my scan tool.
    bulldog93 likes this.
  13. Jan 24, 2026 at 7:48 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Most of those systems will auto-reset when a fault no longer exists. You can pull your negative battery terminal for about 15 mins and then plug it back in and try that.
    Dumb question - you are 100% sure you bought the one for 2018 and not 2017?
    There are some considerable changes to wiring when they added the safety sense system, and if the harnesses fit the same but don't have the same wire pin-outs that would cause issues.
  14. Jan 24, 2026 at 8:03 PM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Yes. 2018-2020.
    So I plugged the TPMS t harness into one of the wrong ones near the middle, not the lowest one by the blue Port. I just realized that I plugged in the wrong one after it wouldn't stop or doesn't unlock.
    But there was no errors on the dash at that time, even after plug it into the right TPMS port.
    I'm scanning it now. I'll try to reset it.
  15. Jan 24, 2026 at 8:23 PM
    KNGDM_KREW
    KNGDM_KREW New Member
    Southern California
    2020 SR5 Cement CrewMax
    Wheels/Tires, leveling kit, Prinsu Rack, full LED swap inside/outside.
    Looks good! How do you like them so far? What brand? Also, in channel or adhesive on the outter trim of the door?
  16. Jan 24, 2026 at 8:26 PM
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    Your scanner will read all systems? TPMS/ABS/SRS etc etc
  17. Jan 24, 2026 at 8:31 PM
    KNGDM_KREW
    Southern California
    I have the weather techs but noticed there are a few options some for carpet and some for rubber flooring. Maybe check the packaging to make sure they’re for protecting carpet. My front driver and passenger side mats have the “grippy” things on the bottom which are actually pretty sharp and two locking twisty things to keep them from sliding. They don’t budge at all. Hope this is helpful!
  18. Jan 24, 2026 at 8:35 PM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Launch Elite
    This LAUNCH x431 elite bidirectional OBD2 scanner for toyota lexus can perform the following functions!
    Engine, Transmission, ABS System, Electronic Parking Brake (EPB), Battery Manage System (BMS), Tire Pressure Monitoring System (TPMS), Supplemental Restraint System (SRS), Air Suspension, Cruise Control System, Steering Angle System, Air Conditioning System, Audio System, Body System, Gateway, etc.
  19. Jan 24, 2026 at 8:37 PM
    KNGDM_KREW
    Southern California
    So I have the flat black ones (just as yours is pictured). The flat black ones can come off just like the painted or chrome ones? If this is true I am an idiot. Thank you for enlightening me haha I thought I’d have to get some sort of overlay or swap out for different mirrors. Just got my first tundra so I’m new to this. Geeking out on all the forums for upgrades and learning a lot. By the way, your Badges look good too
    Boneskull420 likes this.
  20. Jan 24, 2026 at 8:43 PM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Unplug negative terminal for 20 minutes, that did not solve the problem. Trying to reset the system with my launch elite but it's taking forever to load.
    joseph_womack likes this.
  21. Jan 24, 2026 at 8:48 PM
    KNGDM_KREW
    Southern California
    So I detailed the Crewmax today.
    • Wash
    • Decon/claybar
    • Wash again
    • Two step polish
    • Ceramic coated
    • Trim restorer on plastics(ie:mirrors, door handles, bed rails tailgate cap. Used “solution finish” (you need this. you’re welcome)
    • Also added the black out badges the wife got me. The paint is t perfect but it’s better than it was.
    *yes I did this all day today.
  22. Jan 24, 2026 at 11:11 PM
    NEVERGIVEUP
    NEVERGIVEUP New Member
    2021 Super White Tundra SR5 CM
    Anyone here who lives in Los Angeles and has a supercharger in their 2.5gen tundra? I’m interested in getting one and just like to hear your experience with it. Thanks
  23. Jan 25, 2026 at 6:35 AM
    RainMan_PNW
    Casey
    Clark County, WA
  24. Jan 25, 2026 at 7:28 AM
    NEVERGIVEUP
    Thanks. Yeah, I’m more interested in seeing if anyone near me would be willing to let me test drive his/her supercharged tundra, so I can know if it’s worth the upgrade or not. I’d like to feel the drive and compare the differences between stock and the upgraded setup.
  25. Jan 25, 2026 at 7:36 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I know, deep down, you KNOW its worth it...what's not to like about 100+ extra horsepower with no downsides? Same fuel efficiency, more umph! It completely changes the truck into a brand new smile on your face! Experiencing it in person surely has merit, tho. Check the FB forum and youll.likely have more responses in locality.
  26. Jan 25, 2026 at 7:46 AM
    NEVERGIVEUP
    Yeah I’m sure you’re right. I want to believe it’s worth it, only need to test drive to truly know. I know it’s not apples to apples when comparing this, but I got the OTT tune for my tundra and thought it was going to change the feel of the drive like it did for my 3rd gen Tacoma; however, the tune itself the changes were so minor that I could hardly feel a difference in the Tundra. I didn’t feel the oomph like I did when I had my Tacoma tuned.
    Do you know the Facebook forum I can try asking? I don’t use Facebook much.
    HulkSmurf14[QUOTED] likes this.
  27. Jan 25, 2026 at 7:49 AM
    HulkSmurf14
    2014 Tundra Limited
    "Supercharged tundras"
    BR73 and NEVERGIVEUP like this.
  28. Jan 25, 2026 at 8:32 AM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    2018 Crewmax 1794 4x4
    I've got Weathertechs all around. the Floorliner HP models. there's no movement. You could install several large strips of the HOOK side (the firmer side) of velcro on the bottom of your mats and that should help on the carpet.
  29. Jan 25, 2026 at 9:57 AM
    KNGDM_KREW
    Southern California
    Oh I’m good, but thank you. My post was in response to tat2ude39 post on this thread. Maybe this will help him out.
    rdiddy5[QUOTED] likes this.
  30. Jan 25, 2026 at 10:00 AM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    ah yes @tat2ude39
    KNGDM_KREW[QUOTED] likes this.
