  1. Jan 20, 2026 at 11:12 PM
    831mic
    831mic 2016 DC TRD PRO
    California
    '16 DC TRD PRO
    not sure if someone else posted between when you posted and now, but... I cut my bump stops when i installed airbags. Maybe there were airbags at one point? #shrug
    ATV25 and koditten like this.
  2. Jan 21, 2026 at 5:57 AM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    Very nice color combo, looks great!
  3. Jan 21, 2026 at 7:52 AM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    2018 Crewmax 1794 4x4
    I had Frontrunner crossbars on my RetraxOne XR that were 1575mm (thats 62") this is what they looked like.
  4. Jan 21, 2026 at 9:31 AM
    centex
    centex New Member
    Turbokit’s drop in fuel pressure regulator. Getting ready to set the rails up for dual feeds.
  5. Jan 21, 2026 at 10:28 AM
    Velocity72
    Velocity72 New Member
    Upstate SC
    2021 Platinum
    It can give lift and/or prevent sag and sway. Have had it for 3 years.
    bulldog93 and 250000yota like this.
  6. Jan 21, 2026 at 7:25 PM
    Tundrav82019
    Tundrav82019 I have all the duckies
    Leo
    2019 Tundra Limited TRD Off Road Cement
    Did you get the HD one?
    have you had to adjust it at all depending on use?
    still happy with it and would recommend?
    For me I was going to use for towing and give maybe 0.5-1 inch of rear lift if my front level looks weird later.
    Yota303 likes this.
  7. Jan 21, 2026 at 7:27 PM
    Tundrav82019
    Leo
    Did you need new upper control arms with a 1.5-2 inch level lift?
    I’ve read mixed reports of when it’s needed for a level.
    I.e. 2 inches or greater or 2.5 inches or greater
    NWPirate[QUOTED] likes this.
  8. Jan 21, 2026 at 7:28 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Factory UCA will work just fine with 1.5-2” unless the coilovers specifically need something for more space.
    The TRD Pro comes leveled (2”) and has standard factory UCAs
    Henry1jg, bulldog93, Ace96 and 5 others like this.
  9. Jan 21, 2026 at 7:40 PM
    RobertD
    RobertD SSEM#123
    Robert
    DFW, Texas
    I also have the HD RAS set to the lower setting with about 30k miles of use. I absolutely love it and recommend it. My bed is normally pretty empty and the truck rides and handles great. When I'm fully loaded or towing, I don't need to do anything to the RAS and it does what I expect. I've had my bed filled with dirt and/or mulch multiple times since the RAS and its sooo much nicer to drive since you can hit bumps and take turns and the truck feels pretty much normal. You can tell you are loaded but you don't porpoise or feel massive leans.
  10. Jan 21, 2026 at 7:41 PM
    Tundrav82019
    Leo
    Ok awesome, that was my plan.
    I didn’t know that about the TRD pro models and UCAs. Thank you!
    In the event I go higher with my lift, I have the Eibach pro truck 2 (adjustable 0-2.75 inch) and I need UCAs, any you would recommend?
  11. Jan 21, 2026 at 7:42 PM
    AZBoatHauler
    So.Arizona
    Another uneventful oil change - #25 if I'm counting right - just in time for a roadtrip this weekend.
    Henry1jg, Yota303, Velocity72 and 8 others like this.
  12. Jan 21, 2026 at 7:53 PM
    Tundrav82019
    Leo
    Awesome, I’ll definitely need to check them out. Would it be ok with a rear TRD sway bar?
    Velocity72 likes this.
  13. Jan 21, 2026 at 8:05 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    That’s the best kind of oil change :rofl:
  14. Jan 21, 2026 at 8:19 PM
    RobertD
    RobertD SSEM#123
    Robert
    DFW, Texas
    You can run both together. @TacomaTRD4x402 ran both for a bit
    I replaced my rear sway bar with the RAS and like the RAS more. The RAS limits body roll almost as much as the rear bar, but I like that it lets the sides articulate independently which for me gave a smoother ride in day to day life when dealing with poorly maintained roads.
  15. Jan 21, 2026 at 8:41 PM
    NWPirate
    Zach
    WA
    What he said. :thumbsup:
    I'm on Bilstein 6112s set at 1.3", factory UCA
  16. Jan 21, 2026 at 9:15 PM
    RainMan_PNW
    Casey
    Clark County, WA
    They say 2.5" is the max, but I've seen people get 3" out of the factory ones. All depends on how good your alignment guy is with playing the game. If you're truly looking to max out those coilovers, I'd look at a set of UCAs made for that sort of height.
  17. Jan 22, 2026 at 4:17 AM
    @StevetheBreeze The 2020 SR5 non-JBL gets navigation through AA/Craplay by plugging in the USB cable or using a wireless device such as the Motorola MA1.
    bulldog93 and StevetheBreeze like this.
  18. Jan 22, 2026 at 4:25 AM
    Lift it and go with 295's :D
  19. Jan 22, 2026 at 4:27 AM
    The maps button is what brings up the AA/Carplay nav screen when you have your phone plugged in for AA or carplay.
  20. Jan 22, 2026 at 4:44 AM
    HondaDad
    HondaDad New Member
    Oregon
    TRD Sport 4x4
    Does anyone with an 18-21 model know how/if it’s possible to make the blinkers glow with the DRL? I see it on the 14-17 with the added LED harness, but not on mine. IMG_7321.jpg IMG_7322.jpg
    bulldog93, AGTundra and HulkSmurf14 like this.
  21. Jan 22, 2026 at 4:56 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    @iHacker would probably know
  22. Jan 22, 2026 at 5:02 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Isn't there a blue wire thats looped, you need to cut?
  23. Jan 22, 2026 at 5:16 AM
    Uhhhh....
    Dave
    7” BDS, 37s
    For an 18-21 I have no idea. I know for my 16, when I added Pro LED lights & iHacker's harness, I had to cut a ?yellow? wire to disable the amber running lights. Not that that helps here :)
    bulldog93, HulkSmurf14 and HondaDad like this.
  24. Jan 22, 2026 at 5:17 AM
    21TundraJM
    21TundraJM New Member
    JM
    21 Tundra
    Rago, TRD PRO LED Headlights, leveled, RAS is next.
    I like that idea. Following.
    HulkSmurf14 and HondaDad[QUOTED] like this.
  25. Jan 22, 2026 at 5:20 AM
    21TundraJM
    JM
    21 Tundra
    I had the RAS for about 50k on my last truck and loved it. It's next on the list for this truck.
  26. Jan 22, 2026 at 5:56 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    Thanks @RobertD :fistbump:
    @Tundrav82019 my Tundra came with the TRD front and rear sways. I really liked how it made the truck handle on turns. I installed the RAS and kept the sway bar on for a few months. So yes you can run both together. I eventually picked up a really bad squeaking sound and narrowed it down to the rear sway bar. Took it off and been running just RAS since and not sure if I'll go back to the sway bar again. Might end up listing it for sale soon.
    Try to find one local on Marketplace or OfferUp rather than buying one brand new, you might end up uninstalling it eventually and just stick with the RAS.
  27. Jan 22, 2026 at 6:23 AM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
    All Highway...I bet the 3rd Gen can't do this
  28. Jan 22, 2026 at 7:23 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    200k on a 2020!!!
    Thats fucking impressive.
  29. Jan 22, 2026 at 8:38 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Pops rig update- wiring guys are in doing there thing getting all the wiring updated. Rear bumper fabbed up and off to powder coat. Need to trim the bedsides a bit.
    equin, Tboh1870, 21TundraJM and 19 others like this.
  30. Jan 22, 2026 at 9:24 AM
    406cam
    406cam New Member
    Cameron
    SW Montana
    2021 WHT Limited TRD
    Recent: Remote start New head unit Running boards Interior chrome deleting NEXT: outer chrome delete wheels heated steering grill replace/swap: White color match, and maybe a TRD PRO grill.
    dang... I need this. I miss this option my Trailboss had. Where did you get yours? are you liking it ok?
