  1. Jan 10, 2026 at 6:37 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Sports maybe, but not the Pros. It could be port added, but wasn’t part of the factory package.
  2. Jan 10, 2026 at 6:43 AM
    HondaDad
    HondaDad New Member
    Oregon
    TRD Sport 4x4
    How much was the refinishing on the wheels? First powdercoat place I called wanted $700, and that’s when painting myself came to mind:D I’m going to call a body shop I’ve used before and get a quote for fun today. I would put a ceramic coating on your wheels inside & out (after mount & balancing) to help keep them fresh. Gloss black wheels scratch like a b!tch.
    joseph_womack likes this.
  3. Jan 10, 2026 at 6:52 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red CREWMAX 4x4
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 KSP 1.25" Spacers Coachbuilder Shackles +2 Gator retractable bed cover 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light Coupe Battery Hold Down Under Hood LED ESP Rear under seat storage Blue Sumo's rear Superbumps up front Fumoto oil valve TRD RAD CAP TRD Billet oil cap Auxbeam 42" Curved lower bumper LED Auxbeam Pro ditch lights Auxbeam rear 4" work lights
    PXL_20250823_235705242.jpg PXL_20250901_000330333.jpgHere's a couple of pics with glossy black
  4. Jan 10, 2026 at 6:57 AM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    I figured the pros was a standard part, the sports definitely get them.
    HulkSmurf14 and Boneskull420 like this.
  5. Jan 10, 2026 at 7:01 AM
    HondaDad
    HondaDad New Member
    Oregon
    TRD Sport 4x4
    Thanks, that’s a great looking truck! The red lettering is a nice touch.
    BR73[QUOTED] likes this.
  6. Jan 10, 2026 at 7:19 AM
    Hodgexj1996
    Hodgexj1996 New Member
    2017 Tundra TRD-OR
    I agree with above thoughts on silver/machined. But maybe I'm also biased. I am really tempted to take mine down to the wheel shop and have them stripped down to the machine finish and cleared. Imo it's always easier to add paint than it is to wonder.....what iffffff.
    Obviously I'm across the country in NJ but I was quoted $175/EA for a set of 17s how ever I wanted them colored. Fwiw
  7. Jan 10, 2026 at 7:43 AM
    HondaDad
    HondaDad New Member
    Oregon
    TRD Sport 4x4
    I’m sure the rate they gave me is pretty standard, but $700 wasn’t worth it to me knowing $100 in supplies and a rainy day in my garage could do pretty well. I get analysis paralysis every time I do a build, so there will be lots of back & forth o_O
    joseph_womack, 23Tundy and BR73 like this.
  8. Jan 10, 2026 at 7:45 AM
    WV_21Tundra
    WV_21Tundra New Member
    WV
    21 Tundra SR5
    My concern was it doesn't look like all the CRD's listed with it. Also they aren't showing mounting hardware.
    easleycrawler[QUOTED] likes this.
  9. Jan 10, 2026 at 7:57 AM
    easleycrawler
    Travis
    That's the part number I ordered, supposed to have all the hardware. It will be delivered today sometime, so I'll post pics when it gets here.
  10. Jan 10, 2026 at 8:33 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    I called the installer and he said he only uses rtv and that the oem rubber gasket tends to leak sometimes.
  11. Jan 10, 2026 at 8:34 AM
    CaptRussia253
    Ruslan
    Thanks. My installer said the same and that the oem gasket leaks sometimes. Funny when I bought mine the rear leaked a little until I switched to a heavy diff fluid.
  12. Jan 10, 2026 at 8:44 AM
    Dr3wski
    Dr3wski New Member
    2018 SR5 4x4
    Skid finally came in. Now just need to paint
  13. Jan 10, 2026 at 8:57 AM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    I am living vicariously through you
  14. Jan 10, 2026 at 8:57 AM
    Tripleconpanna
    2021 TRD PRO CM; 2011 SR5 SC'd DC; 2008 SR5 CM
    They purposely left them off the Pros for more real wheel articulation, but a lot of folks add them to reduce the body roll when cornering at hwy speeds...
  15. Jan 10, 2026 at 9:40 AM
    Reddawg1100
    Reddawg1100 Why’s all the rum gone?
    FL
    21 SR5 Midnight Black DC, AKA: Bat Truck
    Ethanol free gas
    Definitely will fit. The reason it says it won’t is because your VIN isn’t for a factory TRD trim. But as mentioned above, the part of the truck it attaches to is the same across all trim levels.
  16. Jan 10, 2026 at 10:26 AM
    blenton
    blenton New Member
    My powdercoater charged $500 for a set of four with clear topcoat a couple of years ago. A few months ago, I had another set of wheels PC'd the same color and same extra clear coat and it was $600. He does good work, though, and I've not had an issue with them exposed to wintry conditions. He degreases and sandblasts the wheels clean before PC.
    I painted an old set of Acura wheels for an accord I once owned; it wasn't a terrible ordeal. However, those wheels were painted from the factory so it was easy to sand, prep, prime, and paint. However, I believe your new TRD wheels are powder coated clear from the factory. So sanding will be a bear unless you have a sandblaster, and paint over PC is less ideal. Yes, you can do it, but it typically doesn't adhere as well as if you prepped bare metal so the end finish might not turn out as well as expected.
  17. Jan 10, 2026 at 10:53 AM
    Ace96
    Ace96 New Member
    Western KY
    2021 Voodoo Blue TRD Sport
    Sounds like you found a great shop to do the work. That’s awesome.
    Tripleconpanna and Boneskull420 like this.
  18. Jan 10, 2026 at 11:27 AM
    HondaDad
    HondaDad New Member
    Oregon
    TRD Sport 4x4
    I appreciate the input! If I paint them myself, I was planning on putting them through a blasting cabinet first. I cleaned one this morning and it turned out pretty nice, I might just leave them alone for a bit. Your set looks great !
  19. Jan 10, 2026 at 1:47 PM
    23Tundy
    23Tundy New Member
    SE Pa
    19 SR5 Cement crewmax
    5100s,Diode Dyn fogs, ARE topper, AJT interior chrome delete, meso lights/vleds, RC neoprene seat covers.
    IMG_6371.jpg IMG_6372.jpg Got power connector for new dash cam, should be able to hook into rear view mirror. also got speaker ring backers. Both from trail grid pro. Ordered Thursday night received today. Awesome company. Will prob look into their speaker packages for future sound system upgrade.
  20. Jan 10, 2026 at 2:17 PM
    Finally installed the Dirt Kings before getting the new tires and alignment on Monday.
    Compress_20260110_171137_7812.jpg Compress_20260110_171138_8191.jpg Compress_20260110_171139_9132.jpg
  21. Jan 10, 2026 at 2:30 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Are you certain the 12pin is correct for your truck? My '14 looks to be a 14pin...
  22. Jan 10, 2026 at 2:40 PM
    23Tundy
    23Tundy New Member
    SE Pa
    I did check before ordering. And checked it was a 12 pin. But I’ll confirm later with the actual adapter.
    * edit. Just ran out to the truck to check and confirmed it is a 12 pin and the adapter is hooked in to the rearview now just need to hook up the dash cam.
  23. Jan 10, 2026 at 2:41 PM
    SRQVillain
    SRQVillain Taco to Tundra recent convert
    Ian
    The 941
    2019 SR5 4x4 in Cement
    Just getting started...
    I just put in their speaker package today. Excellent service, excellent package with absolutely everything you need separated out and labeled. Highly recommend! And that package of Nerds in there was just what I didn't know I needed during the install, but it was perfect!
  24. Jan 10, 2026 at 3:14 PM
    23Tundy
    23Tundy New Member
    SE Pa
    Which speaker set up did you go with. Had I realized the service was awesome and the price on full head unit speaker and sub. I would’ve gone that route from jump. I ended up parting together a head unit and wiring this past summer. I used old amps and sub I had laying around. But I need new speakers.
  25. Jan 10, 2026 at 3:29 PM
    Donyms
    Donyms New Member
    Don
    Well, today I updated the maps to the latest release on my GPS. It still had the 2015 maps. LOL!
    After doing that I installed my new bedrail caps. Whoever had the truck before me had installed an ugly and cheap cloth bed cover and it was catching water. Oh, and did I say it was ugly? LOL! I took it off and they had used double stick tape on the mounting rails and it had been on there for a while because my detail guy couldn't get the glue off. I ordered the new caps and they came in with one clip broke right in the middle of the drivers side cap. I told the company I bought them from and they sent me a whole new set. Now I have an extra set that are probably just fine, I don't believe that one broke clip would effect anything. If anybody wants to pay shipping from south Alabama, you can have them. Just let me know, I will give you my email and you can send a pack and ship label for UPS and I will drop them off for you at the UPS store.
  26. Jan 10, 2026 at 4:17 PM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    Where did you get the map update?
    How much did it cost you?
    Was the installation process fairly easy?
    I still have the 2015 map card in my truck and it is very outdated.
  27. Jan 10, 2026 at 5:14 PM
    Donyms
    Donyms New Member
    Don
    I got mine on Amazon, it was 25 dollars and I just switched out the old micro SD for the new one, started the truck and I had the new maps. Very easy, quick and cheap. Very happy so far. I got the Grayda. https://www.amazon.com/dp/B0F9L3HCFP?ref=ppx_yo2ov_dt_b_fed_asin_title
  28. Jan 10, 2026 at 5:22 PM
    RainMan_PNW
    Casey
    Clark County, WA
    It changed to 12-pin somewhere along the line. Maybe 2018…
  29. Jan 10, 2026 at 5:27 PM
    joseph_womack
    joseph_womack Insta @ 4x4bound
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    I can't really remember but I think I got quoted around $500 maybe for powder coating for a set of 4
    HondaDad[QUOTED] likes this.
  30. Jan 10, 2026 at 5:32 PM
    Fergie
    Fergie New Member
    What is the Super Redhawk chambered in? 454 or plain ol 44 mag?
