  1. Jan 2, 2026 at 9:23 AM
    SwitchThrottle
    SwitchThrottle Living in Idiocracy
    2021 Barcelona CrewMax
    I run Lux magnetic rock lights...same locations under the doors. All in one solution. Decently bright.
    rdiddy5[QUOTED] and Boneskull420 like this.
  2. Jan 2, 2026 at 11:39 AM
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    Love the pups!!!
    BlueRibbon4x4[QUOTED] likes this.
  3. Jan 2, 2026 at 11:39 AM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    2018 Crewmax 1794 4x4
    yea. you gotta lay it out and play with it. just installed an auxbeam set and had to lengthen power wires, and fabricate some brackets (3d printed mine).
  4. Jan 2, 2026 at 11:48 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Thanks!
    jmdaniel[QUOTED] likes this.
  5. Jan 2, 2026 at 12:22 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Did a little involuntary improvement to my rear shock setup. I had noticed that one of the two small jam nuts that Icon has you use had backed off and just left one there, which I didn’t think was the end of the world. Upon trying to tighten said nut, I realized that it had pushed up and stripped the threads on the top of the shock body. Thankfully I was able to run to the hardware store and get a good old fashioned lock nut, which I recommend anyone with Icons standard hardware to swap to.
    I always thought those two small nuts were stupid, I wish I had swapped to regular hardware ahead of time.
  6. Jan 2, 2026 at 1:12 PM
    Boneskull420
    Boneskull420 God loving,Tundra driving,rednek custom joker!
    Mark
    Tn
    2018 tundra crewmax magnetic gray trd offroad
    Ironman 4x4 foamcell pro 3.5in lift Complete custom stereo with 2 12's under rear seat S&B/stillen Frankenstein cold air intake True dual exhaust with Carven Tr mufflers Rough country hood bulge led strip Running board led's
    Well ain't you special...... Mr. I just 3d printed mine......:(
    :stirthepot:
    Just kidding :fistbump:, that's awesome! I would love to get one of those one day until then though I do know a guy. Not sure ill go that route but the option is there.
    Hopefully there will be enough wire but if not maybe I can bluetooth it:rofl:
    Did you go in the wheel well or opt for another location?
  7. Jan 2, 2026 at 1:30 PM
    bucketlintels02
    bucketlintels02 Newish Member
    NW Georgia
    2021 Tundra TRD-Pro Crew
    RAS Road-Active Suspension System HD. 2" (estimated) Spacer and Block Lift . S&B CAI - closed VLED Footwell lighting MESO Customs Interior Lighting 285/65/18 KO2 Gator Hard Cover Tri-Fold AJT Designs interior trim CSU 9 - year ceramic coating Rigid Amber Fog Covers Full Tint (70% Windshield) 20% all others.
    First rotate and balance on the 285/75/r18 Ko3’s.
  8. Jan 2, 2026 at 1:56 PM
    StevetheBreeze
    StevetheBreeze New Member
    North Alabama
    2020 SR5 Tundra
    Vision 353 Turbine Wheels 18x9 +12 Cooper Discoverer ATP Step Rails Bed Cover Complete LED Interior light swap out
    How do you like the K03's?
    Beautiful truck by the way!
  9. Jan 2, 2026 at 2:07 PM
    centex
    centex New Member
  10. Jan 2, 2026 at 2:14 PM
    WV_21Tundra
    WV_21Tundra New Member
    WV
    21 Tundra SR5
    I've tried the search unsuccessfully. Are there parts #'s somewhere here for TRD sway bars, both front and rear. Would like everything necessary.
  11. Jan 2, 2026 at 2:16 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA 1 7/8 Longtubes, Snivs 1.88 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT Trans/valve body, 4.5inch intake with 10x2 SABM, FIC 880/930cc injectors, 450 Walbro, Direct Port W/M injection, GM 95mm TB, DW fuel regulator, E-fan, Remote engine air/oil cooler, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
  12. Jan 2, 2026 at 2:27 PM
    centex
    centex New Member
    Gonna be weird for me. I’m the guy that always goes to 20’s so this will be new for me going to 18’s.
  13. Jan 2, 2026 at 2:35 PM
    StevetheBreeze
    North Alabama
    2020 SR5 Tundra
    I just ran across that thread yesterday but glanced over it and kept going. I think it was under "New Posts" thread down the list on first page.
    Scroll up to the top and its on the blue line, last tab
  14. Jan 2, 2026 at 3:40 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Tho it's not my truck, my 1k miles on the KO3s in all weather conditions, including ice and snow has been good. Excellent traction in snow and pretty strong on ice, tho I have 480lbs of sand in the bed during winter months...I'm happily surprised by them...caveat being they run a bit smaller than Coopers and Falkens...I'm currently on 275/70/18s, myself.
  15. Jan 2, 2026 at 3:42 PM
    HulkSmurf14
    2014 Tundra Limited
    I had a chance to throw the Perry Parts bump stops on...quite a bit more comfy in all driving I've encountered in the last 20 miles...pot holes and gravel roads have been tamed a bit more, now. I'd say a valued update to OEM.
  16. Jan 2, 2026 at 3:46 PM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    It's a new toy we got for Christmas. Happy to share the STL file if needed.
    I am running mine on the frame between the wheels. There was not enough wire on the kit to make it work in the wheel wells.
  17. Jan 2, 2026 at 3:47 PM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    these are on my next thing to buy list!
    HulkSmurf14[QUOTED] likes this.
  18. Jan 2, 2026 at 4:01 PM
    StevetheBreeze
    North Alabama
    2020 SR5 Tundra
    Nice. I had a 2013 Yukon SLT that I built an Overlander out of it and I put K02's on it. Had zero issues with them. No whining or road noise, good ride. But I dont have to deal with Ice either like you. The K03s look really good.
  19. Jan 2, 2026 at 5:01 PM
    Fergie
    Fergie New Member
    One place where they don’t do well is in mud….obviously. Was out rabbit hunting last weekend, and the roads were snotty, thick mud, that just wouldn’t clear. I’d throw it in 4wd and gun it for a bit and that would clear them, but they’d clog up shortly after. Honestly though, MTs would have had issue w these conditions too.
  20. Jan 2, 2026 at 5:34 PM
    koditten
    Kirk
    Midland of the Mitten
    You won't be disappointed. I was very disappointed when my '21 showed up with 20's.
    Many more options available for 18" tires.
    As a person that tows much with 2nd gen and plans to tow much with the 2.5, I can't wait until these 20" tires wear out. I'll be installing 18" wheels with some sort of heavier duty tires.
    These 20" low profiles ride rougher than my 18" ers with extra ply rubber.
    With that said, the low profiles look odd to me on a 4 wheel drive.
    I've only got 22 k miles on '21, so I got some time to shop.
    OHwendTrd and joseph_womack like this.
  21. Jan 2, 2026 at 5:38 PM
    StevetheBreeze
    North Alabama
    2020 SR5 Tundra
    Im a bit old school and like more rubber, less rim, and OWL.
    I don't think you will be unhappy with 18s @centex but what do I know. I'm an old fat geezer
  22. Jan 2, 2026 at 6:04 PM
    HulkSmurf14
    2014 Tundra Limited
    I had the challenges in mud with the original KOs and I heard the same with the KO2s...I guess I'm hoping these work better, at least, than the previous versions! Coming from die hard Cooper ST MAXX Fandom, these still need to prove themselves...so far, they're doing great!
    StevetheBreeze likes this.
  23. Jan 2, 2026 at 6:08 PM
    Blackheart
    Blackheart New Member
    2014 Tundra CrewMax
    Tires/Rims, Upgraded Slotted/Drilled Rotors, LED Headlights, LED Fog lights, Weathertech Mats, Rhino Lined bed
    Hello Tundra Forum. Long time Toyota fan, 1st time Tundra owner. I gotta say, “I love my 2014 CM!”.
    Little history on my…. Uhhhh history with Toyota in the last 20 years:
    1980 Corolla SR5 Hatchback - Bought used, restored, destroyed it - (Name: P.I.T.A) 387,000 miles (92,000 on rebuild)
    1985 Celica GTS Hatchback - Bought used, restored-ish, Sold it - (Name: Delilah) 214,00 miles (12,000 on rebuild)
    1989 4Runner - Bought used from a friend, Semi -restored it, made into an “overlander”, sold it. - (Name: Red) 322,000 miles
    1992 Toyota SR5 XtraCab 4x4 - Bought it from a mechanic (Old guy didn’t pay his- (Name: ) 194,000 miles
    1998 4Runner (Limited) - We Bought used, still rebuilding it - (Name: Blackie) - 298,000 miles - Daughter still driving its
    2000 4Runner (Limited)- We Bought used, rebuilt it, new Transmission, T-boned & Scraped - (Name: Elvis)
    2003 4Runner (Sport 4WD)- We Bought used, Repaired 4WD system, (Name: Flash) - Son’s Ride (when he paid me for it…) 339,000 Miles
    2005 Land Cruiser - I Bought it used for a steal and repaired lots. My favorite daily beast - (Name: LC) - 328,000 Miles
    2018 4Runner TRD Pro - Bought new, mostly stock-ish now, Just regular maintenance, (Name: Carbon) - 99,784 Miles - Wife’s car!!!… (Off Limits unless I’m fixing something for her… :))
    So this brings me to the 2014 Tundra CM - I bought it used and Love this damn thing!- (Name: Silver) - 153,000 Miles
    I’ve done a lot of cosmetic and some body repair work. Previous owner did NOT love this truck! I have done the following on the drive train:
    Dumped the diff and replaced the diff fluid - Gears looked clean and no scarring
    Removed the drive shaft and had it balanced - had a little vibration I didn’t like
    Had all the tires and wheels balanced - Had a bad out of balance tire/rim but got it fixed
    Plasti-dipped the rims Black to cover some scratches and scuffing - Looking for new tires and Rims soon.
    Flushed the coolant system
    Flushed the brake system and replaced the pads on all 4 corners
    Replaced the hood shocks
    Replaced the headlights with LED DRL headlights
    Replaced the fog lights with LED
    New side bed top rail covers
    New Tailgate top rail cover
    Soon to be putting new rhino lining in the bed and underneath.
    Happy New Year!… Look forward to learning lots from those that came before me with the Tundra
  24. Jan 2, 2026 at 6:16 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red CREWMAX 4x4
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 KSP 1.25" Spacers Coachbuilder Shackles +2 Gator retractable bed cover 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light Coupe Battery Hold Down Under Hood LED ESP Rear under seat storage Blue Sumo's rear Superbumps up front Fumoto oil valve TRD RAD CAP TRD Billet oil cap Auxbeam 42" Curved lower bumper LED Auxbeam Pro ditch lights Auxbeam rear 4" work lights
    You have come to the right place to spend money on mods... just remember to post pics :spending:
  25. Jan 2, 2026 at 6:45 PM
    centex
    centex New Member
    I tend to drive my trucks like sports cars so the shorter stiffer sidewall is a plus. The ride quality I don’t care about. I don’t tow a lot, just a rzr, I’m not to concerned with it.
    My k5 is sitting on 37’s with 17’s only because I can’t make a 15” rim work with the ton axles. I like the look and the purpose as the truck is built for crawling. My tundra is just a daily that doesn’t wheel. Got tired of wheeling my daily’s and making them squeak and creek and getting banged up.
  26. Jan 2, 2026 at 7:28 PM
    SAGE63
    San Diego County
    Putting the OVS Expedition bedcap on tommorrow... built it today..
    20260102_104005.jpg 20260102_120814.jpg 294c6038-ffe4-43ad-a820-f07ed81ae0f5.jpg
  27. Jan 2, 2026 at 8:39 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I’m not a fan of the twin locknut design either, but I’ve had no issues with mine thus far. Glad you caught the missing one early. That’s a common failure point on a lot of rear shocks it seems. There was some dude with a 3rd gen that was on Instagram blasting Icon after one or both sides completely lost the nuts and sent the stems through the plastic erm I mean composite bed while he was screwing around in the Cinders up by Flagstaff. Definitely something that needs to be checked regularly and torqued/retorqued to keep the nut sandwich intact.
  28. Jan 2, 2026 at 9:00 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    aka.. Guy LaDouche!
  29. Jan 2, 2026 at 9:22 PM
    joseph_womack
    joseph_womack Insta @ 4x4bound
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    tiny little tac weld on the top nut would fix that issue lol
  30. Jan 2, 2026 at 10:24 PM
    blenton
    blenton New Member
    Love the look of the BFD’s! I just got mine back from the powdercoater but haven’t had time to get them mounted up. Dustin @FNWheels was awesome to deal with.
    Those Perry bumps have treated me well. I have them on all three of my rigs. The sequoia rear bumps are SUBSTANTIAL and with all the road construction around me I know they have taken a few hits.
    Easy solution to disappear tread post haste:
