  1. Dec 17, 2025 at 5:19 AM
    HondaDad
    HondaDad New Member
    Oregon
    TRD Sport 4x4
    IMG_6651.jpgPondering wheel, tire & suspension setups. The truck has stock TRD Sport suspension & 275/60/20 BFG K02 currently, but it definitely looks like there’s room for more how it sits:monocle:
  2. Dec 17, 2025 at 6:25 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    1UP, joseph_womack, AGTundra and 2 others like this.
  3. Dec 17, 2025 at 6:46 AM
    HondaDad
    HondaDad New Member
    Oregon
    TRD Sport 4x4
    I’ve browsed through that a few times, my truck already has the largest tire I can run on the 20” & stock suspension according to that list. But when I actually look at my truck & crank the wheel side to side, there’s definitely still room. I don’t want to do any metal cutting on it, but would like to go 18s with more meaty rubber. The tires on there are 10/32 so it’ll be awhile.
    Boneskull420 likes this.
  4. Dec 17, 2025 at 6:53 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    It's not about the front/rear spacing at rest - you need to look at both sides with the steering wheel at 3/4-full lock and see how close you are to the bumper and cab mount and the plastics on both. And if you off road at all, need to plan for additional clearance at lock during any type of articulation.
  5. Dec 17, 2025 at 7:00 AM
    HondaDad
    HondaDad New Member
    Oregon
    TRD Sport 4x4
    I’ll have to get a measure on it turned each way next time the truck is on. Nothing serious for me as far as rock crawling goes, but the truck will definitely go around some mild PNW trails/ snow spots.
  6. Dec 17, 2025 at 7:03 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    He has spoken
  7. Dec 17, 2025 at 7:04 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    You can definitely go to a bigger tire on the stock wheels and probably be okay, but you’ll need to remove the front spat on the bumper and most likely trim up the mudflaps a bit. I ran 295/70R18 on my TRD off road wheels and did those things. Once I added wheel spacers, had to do a little more trimming. And then a little more when I added new wheels with +18 offset. And then a cab mount chip when I moved up to 35s… welcome to the rabbit hole :rofl:
  8. Dec 17, 2025 at 7:11 AM
    250000yota
    250000yota New Member
    Russ
    CO
    Black '21 Trail Edition CM
    2021 Black Trail Edition Crewmax
    Aside from the ranch hand, this is the route I was in the middle of when my '15 was totaled. I'm planning on doing it to my new '21 but using a front hitch receiver until I get a front winch bumper.
    I already have the trailer set up for it, just need to route the power wires to the back. I got a set of quick connect jumper cables when I bought all the supplies for running the wiring, so for right now when I use the winch on the trailer, I just run the jumper cables up to the battery. It worked pretty well, my setups first pull was this wildfire burnt dead dodge.
  9. Dec 17, 2025 at 7:16 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    Like @TRDFerguson said above, look at the spacing when turned full lock. Keep in mind that wheel offset and tire width will both have an affect on how big you can go in diameter. The less positive the offset and the wider the tire will both reduce how big in diameter you can go, unless you place to cut some stuff up. The tires design could also have an affect if it has a wider shoulder when compared to other tires of the same size. I didn't want to cut and I wanted to keep mudflaps, I am running 285/75R17 tires with a +35 offset rim and my alignment has the caster near +3°, I have the small flap in front of the tire removed and the liner pushed forward slightly and I clear both front bumper liner and mudflap no problem, I will likely go a little bigger next time now that I see what I'm working with, but I'll also probably go with an aftermarket slimmer mudflap for extra clearance.
  10. Dec 17, 2025 at 7:37 AM
    HondaDad
    HondaDad New Member
    Oregon
    TRD Sport 4x4
    I’ve noticed the hole runs deep… luckily I’ve had project cars for the 10+ years my wife & I have been together so there’s a level of understanding already ground in :rofl: added bonus of my truck being a company rig :amen: I’m fine with plastic cutting, but don’t think I want to get into the metal. To be continued after work, thanks for the input :thumbsup:
  11. Dec 17, 2025 at 8:28 AM
    HondaDad
    HondaDad New Member
    Oregon
    TRD Sport 4x4
    :thumbsup:
    I definitely have some planning & researching to do still. Thank you :thumbsup:
    Gaston[QUOTED] likes this.
  12. Dec 17, 2025 at 8:46 AM
    SAGE63
    San Diego County
    What no 37s..... booo
  13. Dec 17, 2025 at 8:54 AM
    assfister55
    assfister55 small member
    Johnny
    Kremmling, Colorado
    black '15 Tundra 1794
    SUCK IT, TREBEK
    wow... it's like you're my doppelganger... I did a similar thing with my Tacoma last year with a 1978 K5 Blazer. except the K5 Blazer was mine and I accidentally burned it to the ground 4 years prior until the Forest service finally called me to get it out. in my defense at the time of the incident I talked to the fire department and the police department and gave them my info to contact me but they never did and in my opinion at the time I thought it was impossible to get it out without a badass off-road wrecker or a front end loader. ended up doing it with my Tacoma and my buddies Silverado and a rented U-Haul dolly. was a hell of an adventure... I'm still butt hurt. that K5 was sweet.
  14. Dec 17, 2025 at 9:00 AM
    250000yota
    Russ
    CO
    Wow! Sad to see an old K5 go but that's exactly why I want to do the winch setup this way. At least until I can justify a winch bumper on this truck. The biggest problem I have with it is eating up some of my ground clearance with the front receiver. Might have to look into something custom :monocle:
    BTW, good to see another CO guy on here.
  15. Dec 17, 2025 at 9:10 AM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Heck yeah!
  16. Dec 17, 2025 at 9:20 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    one can absolutely fit 37's on stock suspension ;)
  17. Dec 17, 2025 at 9:22 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    35x12.5 @+25mm at stock without issue.
    https://www.tundras.com/threads/bigghertz-dztlimo.101679/page-2#post-2627453
  18. Dec 17, 2025 at 9:34 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  19. Dec 17, 2025 at 9:40 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red CREWMAX 4x4
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 KSP 1.25" Spacers Coachbuilder Shackles +2 Gator retractable bed cover 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light Coupe Battery Hold Down Under Hood LED ESP Rear under seat storage Blue Sumo's rear Superbumps up front Fumoto oil valve TRD RAD CAP TRD Billet oil cap Auxbeam 42" Curved lower bumper LED Auxbeam Pro ditch lights Auxbeam rear 4" work lights
    If anyone is looking to buy a BA shop chair this is it....Vyper ain't cheap but I'm tired of wasting money on POS chairs that don't hold up17659931887893255188116659433157.jpg
  20. Dec 17, 2025 at 9:50 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
  21. Dec 17, 2025 at 9:53 AM
    JT_925
    JT_925 New Member
    JT
    Pleasant Hill
    2021 TRD Off-Road
    Parts have been trickling in from Black Friday sales. Starting with small items to get my feet wet, like my ajt chrome delete parts.
  22. Dec 17, 2025 at 10:21 AM
    JT_925
    JT_925 New Member
    JT
    Pleasant Hill
    2021 TRD Off-Road
    All my suspension parts got delivered from Hotshot Off-road, dirt king uca’s, bilstein 6112/5160’s, and a coach builder shim.
    I was planning on doing the install myself, but after installing the rears, I realized my tools are a bit inadequate. My floor jack and jack stands were pretty much maxed out and I decided to have a shop install the 6112’s and uca, not worth the risk imo.
  23. Dec 17, 2025 at 10:43 AM
    assfister55
    Johnny
    Kremmling, Colorado
    SUCK IT, TREBEK
    :fistbump: hazzah colorado! I looked into front receivers too super low hanging fruit. not a lot of good options for even bumpers with front receivers. I've seen people take a front receiver and modify it so it sticks out straight instead of dropping down. requires cutting/welding and you have to cut a hole in your factory bumper for it to poke out through. this guy on YouTube did it with his Chevy.
  24. Dec 17, 2025 at 10:59 AM
    HondaDad
    HondaDad New Member
    Oregon
    TRD Sport 4x4
    This looks so damn good, it’s got me thinking that chop chop is worth it for the 35s w/ no lift :annoyed:
  25. Dec 17, 2025 at 11:24 AM
    Keep in mind that if he drops to an 18 inch wheel, offset will come into play..
    Boneskull420, HondaDad and BR73 like this.
  26. Dec 17, 2025 at 11:26 AM
    We can help you spend money haha. That's how my truck ended up the way it did. Damn peer pressure :D
  27. Dec 17, 2025 at 1:04 PM
    bulldog93
    Jeff
    But it's such a good excuse to buy the proper tools...
  28. Dec 17, 2025 at 2:31 PM
    PlumCrazy
    PlumCrazy New Member
    South Georgia
    2019 TRD Pro Voodoo Blue
    Ordered me a AJT Voodoo Blue key fob cover
  29. Dec 17, 2025 at 4:11 PM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    Do they still have that off road park there in Kremmling? I went there once right when it opened as a spectator for a competition and remember watching Mike Caskey from Off Road Solutions showing off in his 2nd gen 4runner doing some crazy obstacles in reverse and whatnot to please the crowd. This was probably late 90’s?
    assfister55[QUOTED] likes this.
  30. Dec 17, 2025 at 4:56 PM
    joseph_womack
    joseph_womack Insta @ 4x4bound
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    wait which one? Not for the smart key cause you have a 19?
    edit: I’m slow and didn’t know he made one for the 18-19… I just wish it was an actually smaller case and not larger
