  1. Dec 15, 2025 at 10:29 PM
    SAGE63
    San Diego County
    There are several threads on here for this aswell
    NEVERGIVEUP[QUOTED] likes this.
  2. Dec 16, 2025 at 3:30 AM
    Chasingstatus
    Chasingstatus New Member
    James
    Sherrill NY
    2018 cement grey Toyota Tundra
    Ditched the fuel wheels for some Kansei KNP wheels. The fuel wheels were nice, just not my style. The truck felt noticibly sluggish with them also. Went from 112lbs per corner to 87lbs with the new wheels. The Mickey Thompson tires (295/70r18) were nice but too loud and I think majority of the weight. Went to a 285/75r17 KO3 I like them so far. Also replaced the brake lines with some steel braided brake lines, new calipers powder coated in red, new OEM suspension and some husky floor liners.
  3. Dec 16, 2025 at 3:40 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Pretty sure I almost broke my Allen wrench trying to get mine loose and still couldn't do it.
  4. Dec 16, 2025 at 3:45 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Same but after a week, bulge is back to flapping in the wind.
  5. Dec 16, 2025 at 4:37 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red CREWMAX 4x4
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 KSP 1.25" Spacers Coachbuilder Shackles +2 Gator retractable bed cover 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light Coupe Battery Hold Down Under Hood LED ESP Rear under seat storage Blue Sumo's rear Superbumps up front Fumoto oil valve TRD RAD CAP TRD Billet oil cap Auxbeam 42" Curved lower bumper LED Auxbeam Pro ditch lights Auxbeam rear 4" work lights
    You need one of these setups too for the bottom bolt hole.Screenshot_20250601-190713.png
    Boneskull420, SAGE63, ATV25 and 2 others like this.
  6. Dec 16, 2025 at 6:26 AM
    assfister55
    assfister55 small member
    Johnny
    Kremmling, Colorado
    black '15 Tundra 1794
    SUCK IT, TREBEK
    I heated it with a torch for a while and it didn't work. what ended up breaking it loose was the heat from being welded. I think the best setup would be welding a tall lug nut to it... then there's plenty to grab with a wrench.
  7. Dec 16, 2025 at 7:02 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah I drenched mine in spray lube and didn't do squat. When it does come off, I'm gonna replace it with a plug that has edges I can wrench on
  8. Dec 16, 2025 at 7:11 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    You need these:
    9034118060 1 $ 9.20 PLUG
    9034124016 1 $ 9.47 PLUG (FOR FRONT DIFFERENTIAL DRAIN)
  9. Dec 16, 2025 at 7:27 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    :cheers:
  10. Dec 16, 2025 at 7:49 AM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    I recently ordered these and fluids to do front diff and t-case fluid change, will update with the results. I’ve also read if you give the face of the plug a little smack with a hammer just enough to shock it, that will help it break loose.
  11. Dec 16, 2025 at 7:53 AM
    HulkSmurf14
    2014 Tundra Limited
    The shocking is real! It will help a lot!
  12. Dec 16, 2025 at 8:17 AM
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    2018 Crewmax 1794 4x4
    THIS. I got them because I am runnning a Kuat Ibex rack w/ a RTT. Definitely feels more rigid now.
    Boneskull420, ATV25, HondaDad and 2 others like this.
  13. Dec 16, 2025 at 10:00 AM
    SAGE63
    San Diego County
    True.... I might have one in my spare parts tub...
  14. Dec 16, 2025 at 11:03 AM
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
  15. Dec 16, 2025 at 11:41 AM
    assfister55
    Johnny
    Kremmling, Colorado
    SUCK IT, TREBEK
    set up a badlands 9.5k winch on a cradle for the 2" receiver. now i just need to route cable to the rear receiver.
  16. Dec 16, 2025 at 12:28 PM
    TundraTT
    TundraTT Full Send
    17 Pro
    Found the biggest 1/2 breaker bar and that bizatch bent like an Olympic weight lifting bar before it broke loose. Unfortunately I put a new copper washer and hand tightened the old Allen one back on when I was done. Definitely ordering what Smurf posted for the next change
  17. Dec 16, 2025 at 4:23 PM
    joseph_womack
    joseph_womack Insta @ 4x4bound
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    I'm gonna eat my words the next time I do it but I've never had a problem cracking it open, yeah it requires a lot of force to eventually pop but
    You know what, probably the big difference is that I'm standing up and doing it at the shop and not on my back, I can fully insert the allen key and not worry about it slipping
  18. Dec 16, 2025 at 4:35 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    I hit mine a couple of times with PB Blaster about a week before I even attempted to remove the plugs. I had no issues on a '21
    jmdaniel, bulldog93 and Henry1jg like this.
  19. Dec 16, 2025 at 4:51 PM
    Scud
    Scud New Member
    San Francisco Bay Area
    2017 1794 Tundra Super White
    Working on it :-)
    Thanks for all of the great information. It is about time I do something to clean/protect the suede.
  20. Dec 16, 2025 at 7:31 PM
    BeauDacious
    BeauDacious 040 > all other colors
    Beau
    14 DC 4x
    Opinion of course. Those wheels look MUCH better than the fuel wheels.
  21. Dec 16, 2025 at 7:34 PM
    BeauDacious
    Beau
    14 DC 4x
    Time for an update
  22. Dec 16, 2025 at 7:36 PM
    BeauDacious
    Beau
    14 DC 4x
    OK. NOW I see a use for a 2" on the front of the truck. I'm sure there are more from you great white north folks that us desert rats never consider.
  23. Dec 16, 2025 at 7:52 PM
    assfister55
    Johnny
    Kremmling, Colorado
    SUCK IT, TREBEK
    I debated in my head for weeks whether I wanted a winch bumper or not and I've always wanted to try this for modularity. that and I like having less weight on the nose. stripper pole mount, toilet seat mount, the only limit is your imagination...
  24. Dec 16, 2025 at 7:56 PM
    BeauDacious
    Beau
    14 DC 4x
    That was exactly where I went in my head. Anything I can plug into a 2" -- BUT on the front of the truck as well...
    I mean. I have 0 real life use for that, and am not going to do it. BUT, I totally see it now!
  25. Dec 16, 2025 at 8:01 PM
    assfister55
    Johnny
    Kremmling, Colorado
    SUCK IT, TREBEK
    for sure! The only other thing I thought about having on there would be like a little two-person seat for... idk watching fireworks on the 4th of July with the ol lady or something. or I guess... fronting in a trailer? Now that's just poor sportsmanship. fuck I wana try that now
  26. Dec 16, 2025 at 8:16 PM
    Yota303
    Washington
    Nice 4runner you got there too
  27. Dec 16, 2025 at 8:26 PM
    assfister55
    Johnny
    Kremmling, Colorado
    SUCK IT, TREBEK
    thanks! :D
  28. Dec 16, 2025 at 8:41 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Custom bedcage is done leaving it raw just incase we tie into it with other lacing from the chassis and rear tire layout plans. Had him add some corner tabs for whips and flags as well.
  29. Dec 16, 2025 at 8:43 PM
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    I think you probably need some LP9's for chase lights right there... they can't run into you if all they see is yellow
    Boneskull420 and blenton like this.
  30. Dec 16, 2025 at 9:37 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    That’s assuming they can keep up lol
