  1. Dec 1, 2025 at 4:20 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    Has anyone put a tailgate salt spreader on their Tundras? My sanding guy for the winter quit doing it, and I live rurally where there is no chance I get anything by a commercial guy before 2pm. Part of me hates the idea of doing it to the Tundra, but besides buying another machine or truck for it, there isn't much for options available to me.
    HulkSmurf14 and BR73 like this.
  2. Dec 1, 2025 at 4:30 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red CREWMAX 4x4
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 KSP 1.25" Spacers Coachbuilder Shackles +2 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light Coupe Battery Hold Down Under Hood LED Rear under seat storage Blue Sumo's rear Superbumps up front Fumoto oil valve TRD RAD CAP TRD Billet oil cap
    Have you got a 4-wheeler or side x side that you could use? Several manufacturers make one to fit these UTV's
  3. Dec 1, 2025 at 4:37 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    I do have a 4x4 and that might be a better solution, I'd feel better about shooting salt over a 8 year old ATV rather than my truck I want to last forever. Good idea.
  4. Dec 1, 2025 at 5:36 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    If you’re open to fabrication, you could get a piece of flat bar from Home Depot, drill it to sandwich between the frame and the front tow hook and then extend it out to clear the front bumper. Take another piece of the flat bar and weld it on at 90° on the edge of the existing flat bar and drill two holes for the license plate and you’re good to go (if it needs support you can take the remaining flat bar and place it vertically at the tow hook to the license plate mount and that should stiffen it up)
    if that doesn’t make sense let me know and I can draw it out
  5. Dec 1, 2025 at 5:56 AM
    Tripleconpanna
    2021 TRD PRO CM; 2011 SR5 SC'd DC; 2008 SR5 CM
    @woods
    I was thinking that sounds like a perfect excuse to buy a small tractor :D
  6. Dec 1, 2025 at 6:13 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    I have one! But its got a blower on the back and a push box on the front. It might be a good excuse to get a skid steer for plowing and the tractor for sanding now though:cheers:
  7. Dec 1, 2025 at 6:15 AM
    Tripleconpanna
    Sounds like you have a couple of great options that keep your Tundra from having to do the deed!!!
    Well, I'm heading off to bed now.... So, you folks all have a great day!!! :cheers:
    NWPirate, BR73, HulkSmurf14 and 6 others like this.
  8. Dec 1, 2025 at 3:04 PM
    mfelton18
    mfelton18 New Member
    South Central Texas
    2014 Magnetic Grey SR5 4x4 crewmax
    rear dif fluid change and breather relocation. Ravenol 75w85 was pretty clear after 35k.
    Nbab23, BR73, HulkSmurf14 and 6 others like this.
  9. Dec 1, 2025 at 3:37 PM
    TundraTT
    TundraTT Full Send
    17 Pro
    Might as well do the front dif and transfer case too:D
    BR73 and HulkSmurf14 like this.
  10. Dec 1, 2025 at 3:40 PM
    mfelton18
    South Central Texas
    yeah, It got too dark and cold outside. Weird saying that since I'm in Texas.
  11. Dec 1, 2025 at 5:14 PM
    StevetheBreeze
    StevetheBreeze New Member
    North Alabama
    2020 SR5 Tundra
    Vision 353 Turbine Wheels 18x9 +12 Cooper Discoverer ATP Step Rails Bed Cover Complete LED Interior light swap out
    Speaking of this, is there a pinned thread by chance, on all the stuff needed to do the rear dif, Front dif and oil change with any other parts needed? I seen one on the 2022-25 thread and it was pinned. Thought that was a great idea.
    I am wanting to take advantage of the current 25% sale going on.
    BR73 likes this.
  12. Dec 1, 2025 at 5:17 PM
    Tundras.com Forum Santa
    Tundras.com Forum Santa Milk and Cookies
    Santa
    3" Lifted Sleigh. sPOD lights on each reindeer. HeftyFab sliders
    DIY: Front differential and transfer case fluid change
    If you look at the top of the home page;
    Click on Mods/Tutorials;
    Click on the first link which is DIY/MODs/Tutorials
    First post that thread is stuffed w/hyperlinks, etc. for various maintenance, DIY, and vanity type modifications!! :thumbsup:
  13. Dec 1, 2025 at 5:22 PM
    Tripleconpanna
    Here's a quick list of what I use, including the Lexus Front Differential Drain Plug Swap...
    Front Differential:
    ·Fluid: Amsoil Severe Gear 75W-85 100% synthetic gear lube (3 qts, 2.2qt capacity) Ravenol is also good (same weights)!!
    · Fill Washer: Toyota Part# 12157-10010 (steel crush gasket)
    ·Fill Plug: Switching to Lexus Part# 90341-18060 (29ft lbs)
    ·Drain Washer: Toyota Part# 90430-24017 (copper flat gasket)
    ·Drain Plug: Switching to Lexus Part# 90341-24016 (29ft lbs)
    Rear Differential:
    ·Fluid: Amsoil Severe Gear 75W-85 100% synthetic gear lube (4 qts, 3.85qt capacity) Ravenol is also good (same weights)!!
    ·Drain Plug: Toyota Part# 90341-18057 (36ft lbs)
    ·Drain Washer: Toyota Part# 12157-10010 (steel crush gasket)
    ·Fill Plug: Toyota Part# 90341-A0002 (36ft lbs)
    ·Fill Washer: Toyota Part# 12157-10010 (steel crush gasket)
    Transfer Case:
    ·Fluid: Ravenol Gear Oil MTF-3 75W (Ordered 2 liters, capacity 1.58qts)
    ·Drain Plug: Toyota Part# 36136-0C010 (18ft lbs)
    ·Drain Washer: N/A
    ·Fill Plug: Toyota Part# 36136-0C010 (18ft lbs)
    ·Fill Washer: N/A
    Edit: Crap!!! :frusty: It looks like Santa beat me to it:rofl:
  14. Dec 1, 2025 at 5:33 PM
    Mdnitedrftr
    Mdnitedrftr TAKITEZ
    Rich
    NW, CT
    '21 1794
    I lifted the wipers off the windshield for the impending snow/ice/rain tomorrow.
  15. Dec 1, 2025 at 6:09 PM
    StevetheBreeze
    North Alabama
    2020 SR5 Tundra
    Thank you!
    HulkSmurf14 likes this.
  16. Dec 1, 2025 at 6:11 PM
    StevetheBreeze
    North Alabama
    2020 SR5 Tundra
    LOL Thanks! This is perfect! (other than the money its going to cost me..)
  17. Dec 1, 2025 at 6:16 PM
    Tripleconpanna
    :hattip:
    In reality, it's really not that bad...
    Just grab those parts tonight from Fred Anderson, and you'll get the 25% off and free shipping (I'd just buy a few of each one so you'll have them for next time).
    I believe Blauparts is running a sale right now (BF/Cyber Monday) on fluids if you're going to do it yourself...
    Either way maintenance is always cheaper than repair!!!
    bulldog93, Reddawg1100, BR73 and 3 others like this.
  18. Dec 1, 2025 at 6:17 PM
    StevetheBreeze
    North Alabama
    2020 SR5 Tundra
    You got that right! Thanks again!
  19. Dec 1, 2025 at 6:24 PM
    StevetheBreeze
    North Alabama
    2020 SR5 Tundra
    That list is so freaking awesome!! SO many things on there I want to do now. Thanks Santa!! :santa::santa2::yes:
  20. Dec 1, 2025 at 6:33 PM
    Santa
    Hell, you could even simply cut and paste most of those into a Wish List :santa2:
  21. Dec 1, 2025 at 6:51 PM
    Dr3wski
    Dr3wski New Member
    2018 SR5 4x4
    100K service
    mqqn, BrandonL812, 23Tundy and 18 others like this.
  22. Dec 1, 2025 at 7:53 PM
    Played around some more this evening lol.
  23. Dec 1, 2025 at 8:36 PM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    Glad others figured this out. I was wondering why folks would be spreading tailgates!
    HulkSmurf14 and woods[QUOTED] like this.
  24. Dec 1, 2025 at 11:38 PM
    NWPirate
    Zach
    WA
    New bat-tree this week.
    My oem hold down was getting corroded so I threw together this temp hold down with ministrut and 1/4" allthread.
    Any recommendations for one that doesn't break the bank?
    I like the SDHQ but I don't want to spend $100+ on it.
  25. Dec 1, 2025 at 11:50 PM
    Boneskull420
    Boneskull420 God loving,Tundra driving,rednek custom joker!
    Mark
    Tn
    2018 tundra crewmax magnetic gray trd offroad
    Ironman 4x4 foamcell pro 3.5in lift Complete custom stereo with 2 12's under rear seat S&B/stillen Frankenstein cold air intake True dual exhaust with Carven Tr mufflers Rough country hood bulge led strip Running board led's
    I think that looks good as is:notsure:
  26. Dec 2, 2025 at 12:46 AM
    NWPirate
    Zach
    WA
    Never thought about just upgrading it's title to a permanent hold down.. :laugh:
    :fistbump:
  27. Dec 2, 2025 at 1:11 AM
    Boneskull420
    Mark
    Tn
    :fistbump: it almost looks like it was made for it:D
  28. Dec 2, 2025 at 3:42 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    AJT designs has one also
  29. Dec 2, 2025 at 3:45 AM
    biebs96
    PA
    I’d leave it. This looks like an upgrade.
    …and now I mod I have to do as well :rolleyes:
  30. Dec 2, 2025 at 4:01 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    Coupe used to make them and sell on here but discontinued PXL_20250827_002743638.jpg
    mqqn, SRQVillain, WAtundra4x4 and 5 others like this.
