  1. Nov 7, 2025 at 6:20 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    lol, don't! I sat on those shocks for about 9mo before finally rebuilding them and getting them installed. Grill and middle bumper was even worse, bought that almost 2yrs ago, never even took them out of the box until the day I installed them.
    I've already got a box of stuff started for next year when the weather warms up haha, mostly interior parts
  2. Nov 7, 2025 at 6:22 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    I knew that advice was coming.:thumbsup:
  3. Nov 7, 2025 at 6:24 AM
    OHwendTrd
    OHwendTrd Aging Member
    2021 SR5
    ATF Cooler, FRAC, RCI Skid, Bilstein 6112/5160
    Glad the rebuild went well for you. Tire and rim swap probably dramatically helped, I'm in the same situation with 20" OE rims and E rated BFGs. I'm going to 18" rims with my next set of tires, but will maintain the E rating because of towing, 295/70/18 Nokian Outposts are on the radar.
    Boneskull420 and BR73 like this.
  4. Nov 7, 2025 at 6:28 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    Did you have a video or breakdown on how to rebuild the rears? Debating on just doing it myself
    Boneskull420 likes this.
  5. Nov 7, 2025 at 6:29 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    yeah, the wheel swap was noticeable. I had aftermarket 20" and they were heavy, the picture of the grill was still with the old setup. I wanted to bring the wheels in a bit, went from +25 offset to +35 offset, and I wanted to drop some weight as well, lost about 10lbs per corner on the new setup. I've towed our boat (~5,700lbs) a few times now with these tires, didn't up the pressure (set at 35psi right now) or put the longer sumo springs in and it felt good.
  6. Nov 7, 2025 at 6:30 AM
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    So if I’m understanding correctly, the only difference in the wheels is one is satin and one is matte?
  7. Nov 7, 2025 at 6:31 AM
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    Same situation here too; factory 20s with 35s E rated
    gonna put my wheels and tires on from my old truck, 18s on 35s also E rated; it’s crazy the weight difference
  8. Nov 7, 2025 at 6:36 AM
    OHwendTrd
    2021 SR5
    Thinking of adding Sumo's myself, still deciding on which one, black or yellow.
  9. Nov 7, 2025 at 6:38 AM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    Yes,
    Here is the info regarding the different options for the BBS PRO Wheels
    Add some flash and give your Tundra a custom look by outfitting it with the 18" matte black TRD alloy wheels. Alloy wheels are light, help enhance heat dissipation and provide greater rigidity under high-load cornering maneuvers than stock wheels. Incorporates the proper weight, offset and brake clearance to ensure proper fit, finish and reliability. This is a Black TRD Wheel that comes from the factory on certain Tundra/Sequoia models. It has a +60 offset and the 5x150 lug pattern. Please inspect the photos closely!
    This wheel is very similar to two other wheels that Toyota makes. Here are those part numbers and their description:
    • PT960-34190-02 - Gloss/Semi Gloss Black with PRO and BBS-Forged Embossed in Brushed Aluminum
    • PT960-34200-02 - Matte Black With TRD and BBS-Forged Embossed in All Black
    • PT960-34190-F2 - Matte Black With PRO and BSS-Forged Embossed in Brushed Aluminum
    These wheels do not include the center cap.
    There are three interchangeable choices for the center caps. Here are those part numbers and their descriptions as well:
    • PT280-34190-02 - Gloss/Semi Gloss Black with a red ring
    • PT280-34200-02 - Matte Black with a black ring
    • PT280-34190-F2 - Matte Black with a red ring
    bulldog93 likes this.
  10. Nov 7, 2025 at 6:46 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    I watched this video several times, the front and rear are basically the same.
    https://www.youtube.com/watch?v=LIeBG934Etw
    They installed the IFP upside down for some reason, not sure why. In the comment section of that video someone lists the IFP depth and nitrogen pressure for both the front and rear shocks, I measured the IFP depth when I disassembled and it was close to the values listed. But I also watched and read up on just basic rebuilding as well. I watched another video of a Ford Raptor shock being rebuilt and it's very similar as well, don't have a link to that one though.
    I initially had trouble getting the seal head off but I was trying to clamp onto the lower mounting bushing and that wasn't working. I 3D printed a set of jaws to go into a vise and clamp onto the aluminum body of the shock, once I did that it came apart easily. Have a set of picks on hand for getting all the seals out of the seal head, I think getting those seals in was the hardest part honestly.
    I also drilled and tapped the reservoir caps for a schrader valve because Shock Seals didn't have the direct replacement schrader valves in stock when I was ordering, they sell one that just installed in place of the flat head screw that is there. For that I 3D printed a set of covers for a 3-jaw chuck that I used at work to do the drilling and tapping.
    I bought all my parts from Shock Seals, I also bought a regulator, hose and no-lose gauge for filling and checking the nitrogen, I'd have to look where I bought those. I also bought the built looking thing used in the video when installed the seal head back onto the shaft, again I'd have to look where I bought that. Everything else was just regular tools.
    Overall I don't think it was too bad, I just took my time with the first shock but the second shock was much faster. The rears should slightly easier since you don't have to remove the mount/spring/spring perch from the shock before starting work, but after that should be the same.
    Piki, Henry1jg, Boneskull420 and 3 others like this.
  11. Nov 7, 2025 at 6:52 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    I've had Sumo Springs on for over 50k miles now, I just wanted to let the rear suspension move more freely so I cut a set down to try. Plus I have RAS back there and that helps. I don't recall what I had them set to before but I cranked those up some now, between the two discs that are supplier and that gave me just a little lift in the back. The front stayed right where is was previouslt with the TRD Sport shocks and spacers.
  12. Nov 7, 2025 at 6:55 AM
    OHwendTrd
    2021 SR5
    I have RAS as well, thinking of tightening it up as well, rear sags too much for my liking when towing the camper. How much did you tighten them up? Right now I have them set with the thicker of the two plastic pieces.
  13. Nov 7, 2025 at 7:04 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    I thought I originally set them to the white disc, I believe that is the thinner disc. But when I was doing all the work I checked them and the thinner disc didn't fit. One disc is 1mm and the other is 2mm, so I reset mine to right about 1.5mm using feeler gauges. Our boat only has a tongue weight of ~350lbs last time I checked it. After doing all the work and hooking the boat up I measured my truck and still have ~.5in rake if I recall correctly.
  14. Nov 7, 2025 at 8:01 AM
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    PPF on them is better...
  15. Nov 7, 2025 at 8:39 AM
    250000yota
    250000yota New Member
    Russ
    CO
    Black '21 Trail Edition CM
    2021 Black Trail Edition Crewmax
    Picked my new truck up from the dealer after having the S-Cargo SmartCap installed. I've got parts coming in from all over the place and trying to decide what of my old truck to throw on now. Also, does anyone have a link for Fred Anderson Toyota and their parts website? I've tried looking and every time I do it on my phone it comes up as a warning that this site may be trying to steal your information, and it won't let me pass the warning.
  16. Nov 7, 2025 at 9:00 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    Genuine Toyota Parts and Accessories: Official Online Store Fred Anderson Toyota
    Boneskull420 and bulldog93 like this.
  17. Nov 7, 2025 at 9:11 AM
    Im betting that another sale is coming.
    Boneskull420, Reddawg1100 and BR73 like this.
  18. Nov 7, 2025 at 9:39 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red CREWMAX 4x4
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 KSP 1.25" Spacers Coachbuilder Shackles +2 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light Coupe Battery Hold Down Under Hood LED Rear under seat storage Blue Sumo's rear Superbumps up front Fumoto oil valve TRD RAD CAP TRD Billet oil cap
    Parts lady at my local Toyota dealership said one is coming for Black Friday
  19. Nov 7, 2025 at 9:49 AM
    seydou
    seydou Distinguished Member
    Not for protecting the paint on the body underneath the flares it isn't.
    Boneskull420 and Tundra234 like this.
  20. Nov 7, 2025 at 10:27 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Gotta love marketplace. Scored a brand new set of nitro 5.29 gears for $400 out of pocket!
    Jego, TOYOTARIG, PolishedTRD and 24 others like this.
  21. Nov 7, 2025 at 11:18 AM
    D3VA
    D3VA New Member
    NoVA
    2021 TRD Pro in the MGM Master Race!
    Replaced to old with the new.
  22. Nov 7, 2025 at 11:51 AM
    lerbud1
    lerbud1 New Member
    Larry
    Waco, TX
    2021 Tundra SR5
    Installed my transmission cooler finally. Turned into a pain in the rear. I had hell getting the hard lines bolted in and then had hell with the thermostat getting it installed. Everything is working fine and no leaks. Now to reinstall my cat covers...........
  23. Nov 7, 2025 at 12:18 PM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    Do you have a link for that spring compressor?
    Yota303 and BR73 like this.
  24. Nov 7, 2025 at 12:27 PM
    D3VA
    D3VA New Member
    NoVA
    Replaced the old (shown) with the new; took about 20 minutes as I was fussing with the clips.
    My unscientific test on my Kestrel showed 18mph before and 21mph after (sorry, wasn't smart enough to snap a before pic).
  25. Nov 7, 2025 at 12:27 PM
    TundraTT
    TundraTT Full Send
    17 Pro
    For anyone trying to save some money. This is the same as oem minus the upchargeIMG_6700.png
  26. Nov 7, 2025 at 12:33 PM
    ThatGuyTheCooler
    ThatGuyTheCooler New Member
    Had Krown applied today, 1st time user here. Was and am super nervous about the drilled holes
  27. Nov 7, 2025 at 12:47 PM
    SpyderRC
    SpyderRC New Member
    2021 Limited Nightshade
    I feel it’s extremely stable. My buddy and i have done this three years in a row now with our trucks and not once have we been sketched out. I only wish they were a tad taller
    Putting the truck on Jack stands could give me more height but it’s more work and I’m lazy :anonymous:
    Boneskull420 and ATV25 like this.
  28. Nov 7, 2025 at 2:33 PM
    easleycrawler
    Travis
    I've got a 2020 limited. Does anyone have the oem part numbers for the driver and passenger side mirrors? All my mirrors have is the heated feature, no bsm or turn signals.
  29. Nov 7, 2025 at 4:00 PM
  30. Nov 7, 2025 at 4:15 PM
    easleycrawler
    Travis
