  1. Nov 3, 2025 at 3:33 AM
    Corndog123
    Corndog123 Knife creator.
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
  2. Nov 3, 2025 at 4:27 AM
    Norfolk757
    Norfolk757 עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    Finally got the switch relocated to the proper location. The cable i originally bought from accessorides.com was short so had to move to the right side of the steering wheel. Purchased the 47' from 12volt.solutions and was able to reach the desired location by the shifter. Thanks to @RainMan_PNW for the guidance and fast delivery of the 3-way cover that is great quality and super easy to install with his template. This is a great mod that leaves room for future expansions.
    PXL_20251102_211401606.jpg PXL_20251102_211408784.jpg PXL_20251102_212355959.jpg PXL_20251102_212406650.jpg
  3. Nov 3, 2025 at 5:08 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    I use Redline MT-LV for the transfer case. Most auto parts stores carry it in stock. I stock up when they have a sale. For diffs it doesn't really matter what brand as long as you change it on time.
  4. Nov 3, 2025 at 5:14 AM
    CaptRussia253
    Ruslan
    I have the Victory 4x4 over the cab and Rhino Rack over the canopy.
  5. Nov 3, 2025 at 5:26 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red CREWMAX 4x4
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 KSP 1.25" Spacers Coachbuilder Shackles +2 Gator retractable bed cover 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light Coupe Battery Hold Down Under Hood LED ESP Rear under seat storage Blue Sumo's rear Superbumps up front Fumoto oil valve TRD RAD CAP TRD Billet oil cap Auxbeam 42" Curved lower bumper LED Auxbeam Pro ditch lights Auxbeam rear 4" work lights
    I bought that cable from accessorides too ... man I hope it's long enough but your install looks awesome
  6. Nov 3, 2025 at 5:45 AM
    Corndog123
    Sam
    Tennessee
    Thank you Sir!
    CaptRussia253[QUOTED] likes this.
  7. Nov 3, 2025 at 7:08 AM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    Yes. That's the part.
    Thank you! I'll watch the video at YouTube University. I appreciate the link.
  8. Nov 3, 2025 at 7:20 AM
    joseph_womack
    joseph_womack Insta @ 4x4bound
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    It’s an easy change, just pull the door card off, roll the window all the way up (if you had it down) and it’s two 10mm bolts on the door side, after it’s unbolted from the door and can you just pull it out, super easy
  9. Nov 3, 2025 at 7:34 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    Man, we need to be able to pin stuff on this site.
  10. Nov 3, 2025 at 7:43 AM
    Tripleconpanna
    2021 TRD PRO CM; 2011 SR5 SC'd DC; 2008 SR5 CM
    Definitely hard to keep track of shit sometimes... Couple that with how fast threads get 'cross-homogenized' w/various opinions and part#s, it quickly get a bit convoluted and confusing at best. Oftentimes, the wrong #s get thrown out there throughout the discussions which leads to folks getting the wrong part#s due to bad intel... HVAC blower motor is a good example of this. I think there were 4 or 5 part#s floating around in that one :notsure:
    I ended starting a spreadsheet and a word doc to log things that this when they come up so I can find them easily.
    This list in particular was put out there by @AZTundra (I believe). Saved me a bunch of time and the headache of looking everything up myself, plus the #s were all spot on, so no reason not to share w/others!!! :thumbsup:
    Wallygator, Henry1jg, Yota303 and 7 others like this.
  11. Nov 3, 2025 at 8:03 AM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    My accesorides cable is just long enough.
  12. Nov 3, 2025 at 8:33 AM
    WBW
    WBW Resident lurker
    Bruce
    Thank you! How difficult is peeling back the watershed plastic without destroying it or getting three black butyl tape on everything?
  13. Nov 3, 2025 at 9:24 AM
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    Super easy, go slow and don’t try and do a big section, ease it section by section off the tape/glue and it’ll come; worst case if the plastic rips just get some gorilla tape or duct tape and tape the front and back
    since it is colder out now, maybe applying heat with a heat gun or hair dryer would also help (edit x2: actually that theoretically would make it stickier so maybe don’t)
    Tripleconpanna and WBW[QUOTED] like this.
  14. Nov 3, 2025 at 9:29 AM
    WBW
    WBW Resident lurker
    Bruce
    Thank you very much. It sounds like I have enough skill to do this task.
  15. Nov 3, 2025 at 10:35 AM
    21TundraJM
    21TundraJM New Member
    JM
    21 Tundra
    Rago, TRD PRO LED Headlights, leveled, RAS is next.
    I'm trying to find a post with the part numbers for the trans cooler would like to make that next upgrade. TIA
  16. Nov 3, 2025 at 10:38 AM
    bflooks
    bflooks New Member
    Metrowest MA
  17. Nov 3, 2025 at 10:44 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I just got the lumpiest, 120lb box from FA...brake rotors, pads, et Al...I already see peanuts shooting out...
  18. Nov 3, 2025 at 10:48 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
  19. Nov 3, 2025 at 10:50 AM
    Corndog123
    Sam
    Tennessee
    WOOOOO HOOOOOO!!!
  20. Nov 3, 2025 at 11:26 AM
    TundraTT
    TundraTT Full Send
    17 Pro
  21. Nov 3, 2025 at 12:11 PM
    OHwendTrd
    OHwendTrd Aging Member
    2021 SR5
    Couple things
    You too?! lol corner part you can’t see was shredded on mine, to my surprise everything was still in there.
  22. Nov 3, 2025 at 12:52 PM
    Reddawg1100
    Reddawg1100 Why’s all the rum gone?
    FL
    21 SR5 Midnight Black DC, AKA: Bat Truck
    Ethanol free gas
    Do you have to do anything special to get the code to work? It no workie for me.
    HulkSmurf14 likes this.
  23. Nov 3, 2025 at 1:38 PM
    TundraTT
    TundraTT Full Send
    17 Pro
  24. Nov 3, 2025 at 2:46 PM
    I have 14 quarts of transmission fluid that I'm waiting on from them.
    joseph_womack and BR73 like this.
  25. Nov 3, 2025 at 5:05 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    Wallygator, Corndog123, D3VA and 6 others like this.
  26. Nov 3, 2025 at 7:39 PM
    WBW
    WBW Resident lurker
    Bruce
    Thank you! That was a very useful video! I guess I don't need to mess with the watershed sheet. Nice!
  27. Nov 4, 2025 at 3:00 AM
    Pimpala1962
    Pimpala1962 New Member
    Kyle
    Massachusetts
    2015 double cab
    Where
    Did u find these i have all emblems done like this except the 5.7 , i was told he cant cut those stickers anymore
  28. Nov 4, 2025 at 6:20 AM
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    Following this up.
    Found the culprit - bad exhaust gasket. I have stainless works headers into spd performance cat back. Sound is from rear of truck. Just reached out to spd for new gaskets. Finally. Been chasing it for a month.
    Also did an oil change today. Went from 5w-30 to 0w-20 again, both pennzoil ultra platinum. First time using 5w-30 and will be sending the sample to Blackstone for analysis.
    Vr0ck, NWPirate, Reddawg1100 and 5 others like this.
  29. Nov 4, 2025 at 6:28 AM
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    We shall await your Blackstone results with eager anticipation :hattip:
    SPD doesn’t use just generic exhaust gaskets?
  30. Nov 4, 2025 at 6:57 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Should’ve asked me… standard gasket https://www.amazon.com/dp/B000CHLKIW
