  1. Mar 21, 2026 at 11:26 PM
    Gens
    Gens Amateur Techpriest
    01AC5VZMT4WDrTRD
    5100/2884 Front SPC UCAs 5160/OEM Rear
    The HD packs are 4/1 and non-side-specific. If you get a kit from ATS they just ship two of the same part and tell ya to put whichever has slightly more arch on the driver side.
    The ATS 3/1s are still side specific part #s like the original toyota springs.
  2. Mar 21, 2026 at 11:30 PM
    Methodical
    Methodical New Member
    Maryland
    2006 Tundra SR5 DC TRD 4x4
    I'm going with the 4(1) leaf spring pack. I will check with them but I thought I just inquire while on the subject.
  3. Mar 22, 2026 at 8:29 AM
    Methodical
    Maryland
    Yep. They only show one part number for the HD leaf springs.
  4. Mar 22, 2026 at 2:11 PM
    mtnbuck
    mtnbuck New Member
    North Georgia
    ‘05 DC Limited 4x4/V8
    Installed new LBJ
    abcinv, Voss, Gens and 4 others like this.
  5. Mar 22, 2026 at 2:44 PM
    nodoi
    nodoi New Member
    02 Tundra SR5
    Whelp, I'm in it now. Started on replacing the timing belt and everything was going fine. Got to the compressor and removed the bolt nut/bracket up front, and the rear bolt and then started turning the bolt that is right up against the hose and it is stripped. I was using a 12mm box wrench, thought it was turning and is was actually rounding the bolt. I have a small jaw vise grip that Tried on the bolt, but even that can barely squeeze in the space.
    Please say a prayer for me and I'm open ears if anyone has any ideas.
    Voss likes this.
  6. Mar 22, 2026 at 2:55 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    Welcome!
    Is this bolt stripped or rounded off? Broken or still whole? One might be able to weld a nut onto the remains to allow extraction.
    des2mtn and FrenchToasty like this.
  7. Mar 22, 2026 at 2:58 PM
    shifty` Got patience on my neck like a cold, cold knife
    They make extractor kits for exactly that purpose. They're shaped like a socket, you hammer them onto the fastener, and ratchet (or impact) the bolt or nut out.
    Voss, des2mtn and KNABORES like this.
  8. Mar 22, 2026 at 3:06 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Gearwrench bolt biter sockets work good. If there's room to get at it.
    https://www.amazon.com/dp/B07PNS5QH4
    They also have a larger set with more sizes.
    Very similar to the more expensive gripedge rpt removal sockets but without the internal threaded tool. (Also sold by mac, matco at even higher prices).
    disc4tw, Voss, des2mtn and 1 other person like this.
  9. Mar 22, 2026 at 3:07 PM
    nodoi
    nodoi New Member
    02 Tundra SR5
    It’s in there, I don’t have a welder, and I’m not sure there’s enough clearance to even try. I’m looking at it thinking I may have to evacuate the AC lines and remove the lines from the compressor so I have better access? I’m not totally sure if that hose junction is removable?IMG_3810.jpg
  10. Mar 22, 2026 at 3:10 PM
    nodoi
    nodoi New Member
    02 Tundra SR5
  11. Mar 22, 2026 at 3:14 PM
    nodoi
    nodoi New Member
    02 Tundra SR5
    There is no room for a socket. The closed end of my box wrench won’t even fit in there. So it’s less than 8mm clearance.
  12. Mar 22, 2026 at 3:18 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Hmmm. IF there is room to swing them some Knipex cobra pliers (may need needle nose version) or pliers wrench would probably do the job. Maybe a good quality needle nose visegrip.
    If that line goes to a block that is held to the compressor with a bolt, it can be removed after evacuating the system. You can also replace the bolt then too.
  13. Mar 22, 2026 at 3:21 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    I have found that there are places where a 12 point boxed end wrench does not serve well. They do make 6 point boxed end wrenches ifna ya ain't ruined the head too much.
  14. Mar 22, 2026 at 3:28 PM
    nodoi
    nodoi New Member
    02 Tundra SR5
    I was thinking the same thing, but at this point I've lost just about any edge after thinking I was making progress with the vice grip. I think I could get it out if I could get that AC line out of the way. Guess that is my next move.
  15. Mar 22, 2026 at 3:37 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I’ve got 2 piece rotors. I just need to use different blanks and have different hats made. I’d rather keep my stoptech calipers
    Nicklovin[QUOTED] likes this.
  16. Mar 22, 2026 at 3:38 PM
    empty_lord
    05 rollover special
    IMG_9846.jpg The ol reliable steed has so far completed 70% of the trip today. 600 miles down. Just 400 more to go
    13th mr2 acquired.
    sportbike37, abcinv, Voss and 8 others like this.
  17. Mar 22, 2026 at 6:06 PM
    Nicklovin
    Nicklovin Yap Yap
    Nick
    Huntington Beach, CA
    00’ 4.7 AC 4x4 - GFC
    13 all at once? Wilddd
  18. Mar 22, 2026 at 6:12 PM
    Nicklovin
    Nicklovin Yap Yap
    Nick
    Working on the valve covers again today, started yesterday. Got the passenger side reassembled and put back on. Broke one of the new spark plug tube seals when bending the last tab over, ughh. Robbed one from the other side and another $16 to Amazon for a pack of 8 from Felpro. Oh well. Might offer up the rest here if someone needs them, or throw them on a shelf and forget about them for years.
    Really had to beat the piss out of the old ones to pop them out
    des2mtn, Voss and bmf4069 like this.
  19. Mar 22, 2026 at 6:52 PM
    bing5
    bing5 Fight the powah
    New Mexico
    2004 DC SR5 4WD V8
    Are those Cobra pliers the shit? Been eyeing them with envy....
  20. Mar 22, 2026 at 6:58 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    I like them. I've got I think 6 pairs currently. I've gifted a few as well.
    The 7" and 10" are my most used. Consider getting the set of 3.
  21. Mar 22, 2026 at 7:02 PM
    Jack McCarthy
    Jack McCarthy I’ve got my eye on you.
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    So you can’t cut them out with some wire cutters?
  22. Mar 22, 2026 at 7:12 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    They are the kittens kittens!
    I have the 6 or 7” version which open up to the equivalent of 8+ and the adjustment range is very tight. I mainly like them because of the width of the jaws; I do a lot of close quarter pipe fitting and the thin jaws are a major plus!
    Voss, des2mtn, BroHon and 2 others like this.
  23. Mar 22, 2026 at 7:22 PM
    455h0le_dachshund
    455h0le_dachshund NO MASTERS, NO CHAINS
    Coastal TX
    Penelope & Elvira
    So are you trying to build like 10 at this point and the rest are for parts?
    Your tundra would look sick with a KBD valence with some auxiliary lights in it.
    I'm still figuring out how I want to mount lights in mine.
    empty_lord[QUOTED] likes this.
  24. Mar 22, 2026 at 7:25 PM
    empty_lord
    05 rollover special
    I haven’t a clue what the KBD valance is
    des2mtn likes this.
  25. Mar 22, 2026 at 7:33 PM
    455h0le_dachshund
    Coastal TX
    Penelope & Elvira
    Here you go
  26. Mar 22, 2026 at 7:40 PM
    empty_lord
    05 rollover special
    I don’t hate it. But I also don’t like it. This trucks getting ditch lights and some other love before anything
  27. Mar 22, 2026 at 8:31 PM
    bing5
    New Mexico
    2004 DC SR5 4WD V8
    I finally got off my ass and installed the sway bar bushings and end link bushings that have been sitting in my living room for a year. Interestingly, the sway bar bushings were in pretty good shape, but the link bushings were toast. I have enough leftover Toyota rubber lube to last a few lifetimes....
  28. Mar 22, 2026 at 8:56 PM
    bing5
    New Mexico
    2004 DC SR5 4WD V8
    I have the 7 inch variety of these: Irwin 4 in. Locking Wrench - Locking Jaw Pliers - Amazon.com. The head thickness on mine is 12.7mm. You might be able to squeeze in the 4 inch variety....I couldn't readily find the thickness of the head for the 4 inch. The 7 inch worked like a champ for removing a stripped fuel filter flare nut.....
  29. Mar 22, 2026 at 10:47 PM
    Methodical
    Maryland
    Can you get a small plumber pipe wrench in there? They will bite on a bolt better than vice grips.
    whodatschrome and KNABORES like this.
  30. Mar 23, 2026 at 7:17 AM
    Yeah, doesn't work like that. They're press-fit into the valve cover slot, and they have a rigid wire (almost like a steel belt) that runs through them in multiple places. After a while, the rubber hardens up, so you're dealing with hard plasticky rubber AND a steel belt, so ...
    You really kinda need to get something to pinch the circle into a pacman shape, by pushing the interior ring in. But you need to do it in such a way that you don't mar the machining for the section they get press-fit into. It can be a bitch.
