  1. Mar 5, 2026 at 7:17 AM
    Methodical
    Methodical New Member
    Maryland
    2006 Tundra SR5 DC TRD 4x4
  2. Mar 5, 2026 at 7:25 AM
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    02 SR5 RC Desert Sand- ARB'd 4x4
    BOSS head Unit, Track Rack, Tint. MT Baja Legend EXP 16x9, Pro-Comp 69, Icon Titanium Rebound 17x8. Cant decide on Lift. ARB Rear. Bash Fab Sliders.
    Those ribs are hard on the knees. I don't know how the ladies do it.
    455h0le_dachshund likes this.
  3. Mar 5, 2026 at 7:27 AM
    Methodical
    Maryland
    Mine was 3 quarts drain and fill. I would never rely on what is stated in those documents as they are just estimates. I just catch what is removed and refill with same amount. Note: this method can be done once you know that the transmission has been filled properly. If the truck is new to you, then you should do refill method as described by Toyota. After that, you can do the refill method or drain and fill what comes out. If drain and fill method make sure the fluid in the truck and bottles are at the same temperature.
    Wait a minute. Is that not a sealed transmission?
  4. Mar 5, 2026 at 7:36 AM
    des2mtn
    des2mtn Barf me out, gag me with a spoon!
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    At first, Powerstop rotors worked well for me, but once they started to warp it got bad quick. I switched to EBC slotted only rotors and have gotten more life out of them. I don't think I'll use a drilled rotor again for my truck. I was already using EBC pads on the Powerstop rotors.
  5. Mar 5, 2026 at 7:37 AM
    How many miles on the EBCs?
  6. Mar 5, 2026 at 7:38 AM
    Elam.Pingleton
    Elam.Pingleton 1st Gen 04 2WD V-8 DC
    Elam
    Nashville Area
    2004 Tundra DC Limited
    About a month ago my rear end wheel bearing seized up and I ended up replacing all the components while mechanic had everything tore down. Did brakes and drums, bearing, abs zone rings, seals etc. All OEM parts.
    I will definitely keep you posted. Give me a few weeks and my 04 DC will be sittin pretty
    G_unit3000, shifty` and oscardog86 like this.
  7. Mar 5, 2026 at 7:42 AM
    des2mtn
    Shady Grove
    Tonto cover
    Don't have an exact number, but over 30k. Definitely more miles than the Powerstop rotors.
    KNABORES[QUOTED] likes this.
  8. Mar 5, 2026 at 7:48 AM
    I've been running some brand of heavy duty parts store rotors up front with BrakeBest pads and reman calipers that are working well, but have about 50k on them. I've replaced the pads once under warranty for a sticking caliper, also replaced under warranty. Really want to redo the whole front braking system with new rotors, calipers and pads soon. They actually are performing very well, even when towing with almost zero brake shake when stopping. Still on my original rear drums at 287k miles. only replaced the shoes once.
    G_unit3000 and oscardog86 like this.
  9. Mar 5, 2026 at 8:05 AM
    des2mtn
    Shady Grove
    Tonto cover
    EBC Orangestuff are probably the best pads I've ran and have the strongest bite, but they're pretty dusty which doesn't bother me.
  10. Mar 5, 2026 at 8:49 AM
    Kalannar97
    Kalannar97 New Member
    Michael
    Hillsboro, TN
    2003 Red Tundra SR5 2wd AC V-8 LSD ABS
    New Frame (Recall in 2019), added 17" 4-Runner Snowflake Rims
    I did not add antiseize, the rust all came from its time up in Illinois while my dad had it. It will now be spending all of its time in TN.
    I had bought 4 all new O2 sensors when it was throwing the codes initially and they are OEM. But I only ended up needing a new gasket and 2 new nuts to secure them to the new Walker resonator pipe assembly I got from Rock Auto. I bought the resonator and the muffler assemlies and they shipped to me fully assembled. The welds aren't as good as our boilermaker I work with can do, but they look like they are sealed up good.
    Methodical[QUOTED] likes this.
  11. Mar 5, 2026 at 9:03 AM
    Casper421
    In the woods
    06 DC
    I won’t run slotted or drilled anymore. They seem to warp no matter if just drilled, just slotted or both. More material is stronger in my mind and won’t warp as easy.
    I agree! Someone was nice enough to gift me these for secret Santa. Thanks again buddy!!
  12. Mar 5, 2026 at 9:07 AM
    Are those the R1 rotors?
  13. Mar 5, 2026 at 9:35 AM
    Casper421
    In the woods
    06 DC
    I wanna say EBC RK rotors. I can confirm after work.
  14. Mar 5, 2026 at 9:51 AM
    TXTundraGuy23
    TXTundraGuy23 One piece at a time
    Dallas
    2004 DC 4.7L 4WD
    6112s up front w/ 650 lb springs, 5160s in the rear, JBA UCAs, Suspension Maxx Links, ATS leafs w/ Wheeler's AAL and overload spring, Toyota Gloss Gunmetal TRD Wheels, Toyo Open Country AT3s 275/70/17
    Nope. It is not sealed. Has a dipstick and drain plug, so to me that means it was meant to be serviced. Even though the dipstick says you don't need to. Which is weird...
  15. Mar 5, 2026 at 9:58 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2001 AC 4X4
    I've been very happy with the greenstuff. I'll have to try orange stuff next time. They do give off a lot of dust, but I spray painted my wheels black so the dust is like touch up for my wheels :)
    des2mtn[QUOTED] likes this.
  16. Mar 5, 2026 at 1:05 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    265/75r17 M/T Baja Boss AT 17x8.5 -10mm SCS Ray 10’s Bilstein 5100’s 2nd notch
    Went and bought some more paint I think I’m going to try and tackle my upper doors and fenders when it comes in.
    ToyotaDude and 455h0le_dachshund like this.
  17. Mar 5, 2026 at 1:51 PM
    Kalannar97
    Michael
    Hillsboro, TN
    My new Fr33 Lance Fab steering knuckles and spindles came in today. Almost have everything for the front suspension rebuild now. Just waiting on the upper control arm bolts and my springs/strut assemblies.
  18. Mar 5, 2026 at 2:11 PM
    shifty` Do some sister twisters 'til the cows come home
    VVTi trucks only. 2005-2006 for the sealed 5spd AT.
  19. Mar 5, 2026 at 2:23 PM
    Neo
    Neo New Member
    Alabama
    (See Signature for Trucks Info)
    2003 AC SR5 4.7 V8 4x4
    My dad only got one RS3200 key fob when he bought his 03 used. So, I scored a couple of used OEM RS3200 fobs off eBay. Today, I used the "REPROGRAM EXISTING REMOTE CONTROLS" procedure from the tviprs3200.pdf document in this post to clear all previous fobs and add these 3 fobs. I shoulda gone and bought a lottery ticket afterwards because I got the programming sequence correct the FIRST time.
    abcinv, Hoferkill, hammeron and 7 others like this.
  20. Mar 5, 2026 at 3:22 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
  21. Mar 5, 2026 at 3:23 PM
    des2mtn
    Shady Grove
    Tonto cover
  22. Mar 5, 2026 at 3:24 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
  23. Mar 5, 2026 at 3:33 PM
    Voss
    2003 AC TRD 4x4
  24. Mar 5, 2026 at 3:38 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    That other tool is used to hold the cam gears while you loosen the front bolt when canghing the cam seals on a non-VVT 4.7.
    Voss likes this.
  25. Mar 5, 2026 at 4:07 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    2004 AC 2wd to 4wd conversion ABS delete
  26. Mar 6, 2026 at 7:39 AM
    AnnDee4444
    AnnDee4444 New Member
    2001 2WD Access Cab
    I bought some BullRing stake pocket tie-downs, but during install realized that there is a small gap between the bedrail cap and the actual bedrail. Tightening these causes the cap to flex downwards and bow out. So I made some 5mm spacers out of ABS and slid them underneath the bedrail cap. Now there's slightly less D-ring exposed, but they look correct. FWIW: the color is slightly darker than my brand new bedrail caps, and they're about 0.5mm too long which can be corrected with some light sanding.
    khooiii, kodyquist21, DBombs and 11 others like this.
  27. Mar 6, 2026 at 7:46 AM
    whodatschrome
    I also have the Bull Rings in my stake pockets. At least with the access cab caps, there’s zero need for sanding or shimming. Simply pop the plastic cap off the top of the bed rails, install Bullrings flush on the sheetmetal, then slap back on the rail caps. Done and done. By doing that it also makes the flush mount rings an actual flush mount.
    Tundraforever1 and ToyotaDude like this.
  28. Mar 6, 2026 at 9:17 AM
    AnnDee4444
    2001 2WD Access Cab
    I want to be able to remove mine, and I don't really want to take off the bedrail rail caps if I can avoid it.
    Here's a photo I found of part # BU75FR (what I am using). Even in this view you can see how the cap is deflecting in towards the stake pocket. It also bows into the bed.
  29. Mar 6, 2026 at 11:22 AM
    whodatschrome
    Yes, i can see the deflection in the bed rail cap. That person installed the bullring incorrectly. It takes about 3 seconds to remove it, and maybe twice that time to pop it back on.
    And just how often are you planning on removing and reinstalling the bullrings?…once a week, once a year, once ever?
  30. Mar 6, 2026 at 4:06 PM
    AnnDee4444
    2001 2WD Access Cab
    How?
    It really doesn't matter how many times, I just don't want to pull the bed rail caps off again if I can avoid it. In my experience the clips have a finite lifespan and I don't want to expedite their failure.
