  1. Feb 25, 2026 at 8:55 AM
    Sirfive
    Sirfive Socially feral
    SATX
    Roxanne
    Bassani cat-back
    Paint? Hit em with bedliner.
  2. Feb 25, 2026 at 9:33 AM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    I didn't realize that about the cold but it makes sense. I bought one a few years ago and it still sits in my parts pile. After cleaning my throttle body last fall, I was thinking about installing the catch can as a mini weekend project. That photo of the mounting location looks decent.
    455h0le_dachshund likes this.
  3. Feb 25, 2026 at 10:41 AM
    shifty` Do some sister twisters 'til the cows come home
    I agree, it's a clever spot to mount the bracket, but the bracket itself is clumsly looking to me. It could easily be improved, and I bet someone could draft something up and send it off to one of those sheet metal cutting/stamping places to have a couple hundred stamped out to sell on here.
    G_unit3000[QUOTED] likes this.
  4. Feb 25, 2026 at 10:44 AM
    bmf4069
    bmf4069 Scored 4 touchdowns vs Andrew Johnson High School
    Beau
    TX
    02 AC sr5 4wd v8
    You and I both know a guy. @JakeJake. He's fabbing up a coolant overflow tank and catch can for me now on Donut.
  5. Feb 25, 2026 at 10:46 AM
    Sirfive
    SATX
    Roxanne
    Bassani cat-back
    i want one. But i want mine to vent through a tube in my driver side exhaust pipe for a vacuum signal & to spray on people that need to be passed on the left.might even build a ‘purge’ button.
  6. Feb 25, 2026 at 10:46 AM
    I'm pretty sure the bolt holes on the firewall are in the same place, same spacing, same thread, at least for the AC/RC frames. Some of them have something bolted there (I forget what, maybe a vacuum line support?), but ... that could easily be overcome, or just add provisions to the part to add onto it. Would need to make sure the can holder has versatile mounting options maybe, to support a couple of models of can. Or maybe make it so it supported holding a molle panel, so you could mount lots of other stuff to it. Could double as an electrical mounting panel for some of the folks that are setup for a couple weeks off-grid.
  7. Feb 25, 2026 at 10:49 AM
    Pffft, yeah, said nobody on here, like, ever. :rofl:
    bmf4069[QUOTED] likes this.
  8. Feb 25, 2026 at 11:08 AM
    Casper421
    In the woods
    06 DC
    While I’m over here in the fetal position needing a set of 40/13.5r17’s for my crawler.
  9. Feb 25, 2026 at 11:26 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Casper421[QUOTED] likes this.
  10. Feb 25, 2026 at 11:51 AM
    Hoferkill
    Hoferkill New Member
    Hofer
    2006 blue DC SR5 4.7l auto Tundra
    Stock as far as I can tell with 211,000 miles
    G_unit3000 likes this.
  11. Feb 25, 2026 at 12:06 PM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    I've never seen that on any of the 6 TKT-021 kits I've purchased. You didn't buy it on Amazon or ebay, right??
    Voss and Hoferkill[QUOTED] like this.
  12. Feb 25, 2026 at 12:19 PM
    Bilgepump
    Bilgepump New Member
    '06 Sequoia Limited 4.7L VVT-i 2WD
    All Stock
    Looks handwritten to me as well.....hope everything lines up for you ....be absolute sure of your timing before you button things up ...
    G_unit3000 and Hoferkill like this.
  13. Feb 25, 2026 at 12:24 PM
    Call them, I think the number for Auto division is (606) 878-6523
    You can try emailing their Sales people also @ info@aisinworld.com
    It's also possible you got re-boxed equipment, someone got intimidated and re-boxed, then returned. You can also try contacting RockAuto to discuss, they'll likely exchange after they pull and compare to another part. I've never seen that before.
    "I just purchased a timing belt kit for my truck, and I have concerns about the authenticity of the belt, it appears the cam timing arrows on my belt were drawn on by hand, and I'm suspicious..."
  14. Feb 25, 2026 at 12:32 PM
    Hoferkill
    Hofer
    Thanks everyone, I'll give Rock auto a call.. I noticed another box for the idler had been opened. Maybe someone returned an Amazon purchase to RA?
    FirstGenVol likes this.
  15. Feb 25, 2026 at 12:40 PM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    Sorry about the resolution, it's the best I can do while zooming in. This kit came from Rock Auto and installed last week.
  16. Feb 25, 2026 at 12:44 PM
    ... it happens
    Hoferkill[QUOTED] likes this.
  17. Feb 25, 2026 at 12:46 PM
    Hoferkill
    Hofer
    The arrows look better than mine but the writing may be handwritten? Hard to tell..
  18. Feb 25, 2026 at 12:54 PM
    Did it come in a sealed bag like this, or was it loose in the box?
    Here's some pics @des2mtn and @Gnarbrah's posted which show the normal writing fairly well:
    [​IMG][/QUOTE]​
    oscardog86 likes this.
  19. Feb 25, 2026 at 12:57 PM
    @flyfisher also had doubts about a belt he purchased online. The belt said "Made in Japan", see this thread.
    This is how the box came packaged, with each item wrapped:
  20. Feb 25, 2026 at 12:59 PM
  21. Feb 25, 2026 at 1:20 PM
    Bilgepump
    All Stock
    Mitsuboshi is a major supplier of timing belts thru out the auto industry...to all the big players ... a good belt.....just be sure of your markings....that belt may very well work for you if everything lines up on both cams and the crank ......
    Hoferkill likes this.
  22. Feb 25, 2026 at 1:22 PM
    Hoferkill
    Hofer
    [/QUOTE]
    Thanks Shifty, those marking definitely looked stamped. My belt was NOT in a bag, water pump was in a sealed bag, gaskets in an open bag...
  23. Feb 25, 2026 at 1:27 PM
    I suspect that belt has been tampered with then. I looked back on half a dozen posts with open-box of the TKT kit 021, and every single one of them had the belt in a bag, at unboxing, just like the water pump. And it appeared it was a sealed bag, not an open-end bag like the water pump gasket.
    That alone is enough to warrant me to post a support request via your RA order page (you can't call them). But when you combine it with the handwritten-looking bullshit, and the unbagged belt, something ain't right here.
  24. Feb 25, 2026 at 1:29 PM
    Tundraforever1
    Tundraforever1 Nobody rides for free
    2001 2WD AC 4.7l 2010 2WD CM Limited 5.7l
    I'd err on the side of caution and send the kit back.
    G_unit3000, oscardog86 and Bilgepump like this.
  25. Feb 25, 2026 at 1:31 PM
    Bilgepump
    All Stock
    Agreed....send back if you have the time
  26. Feb 25, 2026 at 1:36 PM
    Hoferkill
    Hofer
    I just noticed there is a desiccant pack in the bagged belt that you posted..
  27. Feb 25, 2026 at 1:46 PM
    Hoferkill
    Hofer
    Sigh... I think you are correct in returning it.. here goes another 2 weeks of waiting!
    Voss and Tundraforever1 like this.
  28. Feb 25, 2026 at 1:53 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Question. The water pump I bought from Toyota came with 2 O rings. One small and a bigger one. Not sure where the bigger one goes and don’t see where it would go. IMG_1912.jpg
    Tundraforever1 and FrenchToasty like this.
  29. Feb 25, 2026 at 2:00 PM
    Voss
    2003 AC TRD 4x4
    Toyota sells the belt on its own and think it’s around $70-$80. Should be ready to pick up tomorrow if you order today. If you don’t want to wait 2 weeks.
    Oh, not sure if the dealer near you is like the one near me but I usually get the part # from them then order it through their auto parts website. It’s like 30% cheaper than ordering it directly from the parts department at the dealer.
  30. Feb 25, 2026 at 2:16 PM
    Tundraforever1
    I'm pretty certain that because the kit fits a wide array of Toyota models they include both o-rings since they don't know which specific model it's purchased for. They just go by kit # and send it. The end-user just uses the one they need.
    oscardog86 and Voss[QUOTED] like this.
