  1. Feb 6, 2026 at 1:23 PM
    shifty` Got patience on my neck like a cold, cold knife
    The one major turn off, and maybe why the quality of the image on their cams is so potato, is how thin those wires are. The ground and power were about as thick as two pubes twisted together. I can only imagine how skinny the video cables are. It would be super easy to rip one of those red / green / black wires in half.
  2. Feb 6, 2026 at 2:41 PM
    Sirfive
    Sirfive Socially feral
    SATX
    Roxanne
    Bassani cat-back
    I still wanna know how i can run a 1tb memory thing to a set of 24/7 good cameras. How long could i record four 4k cameras before it needs to overwrite?
  3. Feb 6, 2026 at 3:02 PM
    Depends a number of factors, three big ones I can think of OTOMH being:
    • What resolution and FPS are the cameras set to? (something low-res like 640x480 will record exponentially longer than resolution of 4k, and if you're running 15fps vs. 30fps, you're clearly going to be able to store far more of the 15fps frames)
    • Will the video be compressed using codecs or similar? (would depend on the NVR or potentially the camera)
    • How many cameras? (obvs for each one you add, adding [+1] storage usage)
    Most NVRs I've dealt with have a [main stream] and [sub stream] function, and you can adjust so one of the streams is lower-resolution, and you can choose to record the substream only, to save on space.
    The equipment I typically work with (UniFi) has a calculator to give you an idea of how many hours recording time based on number of cameras and min/max resolution. There are some generic ones like what Seagate has here: https://www.seagate.com/video-storage-calculator/ and what Western Digital has here: https://www.westerndigital.com/tools/surveillance-capacity-calculator
    Another generic tool from non-hard drive manufacturer: https://www.cctvcalculator.net/en/calculations/storage-needs-calculator/
    tl;dr - It's wildly variable. Need more info on NVR, cameras, resolution, quantity, FPS, etc.
  4. Feb 6, 2026 at 3:15 PM
    Sirfive
    SATX
    Roxanne
    Bassani cat-back
    I wanna be able to zoom & enhance on the people coming towards me that dont turn off their brights fast enough.
    100 fps so i can play it in slow motion. I can get on board air, but i dont see how that will help. Four cameras.
    Not even a day @30fps. Almost 4 days with h.365. I dont know anything about data compression and dont care to learn. But i wanna put ‘em on my youtube channel.
    Tlar25 and G_unit3000 like this.
  5. Feb 6, 2026 at 4:02 PM
    Sirfive
    SATX
    Roxanne
    Bassani cat-back
    side thought about speedo calibrators.
    Could you use a speedo calibrator to trick the computer into thinking you’re going 45mph (lockup in 3rd, a340) when you’re really doing 35, effectively locking up the convertor below 2krpm?
  6. Feb 6, 2026 at 6:56 PM
    Supercharged03
    Supercharged03 New Member
    Mark
    Friendswood TX
    2004 Regular cab V6 5 speed
    SOS lowering kit, Magnuson s/c, Hellwig sway bars
    Texas has no emission test for vehicles more than 24 years old. Only seventeen of the 255 counties in Texas (around Dallas, Houston and Austin) test emissions anyhow.
    G_unit3000 likes this.
  7. Feb 6, 2026 at 7:23 PM
    Yeah, the “enhance” stuff as seen on TV is bullshittery. It would require immense resolution to drill down into valid pixels. The technology you want doesn’t exist in a price range most ppl could afford, and it would eat thru a TB of disk space in minutes versus hours or days.
    I wish that kinda stuff was approachable!
    :confused:
  8. Feb 6, 2026 at 11:18 PM
    455h0le_dachshund
    455h0le_dachshund NO MASTERS, NO CHAINS
    Coastal TX
    Penelope & Elvira
    The 03 thinks it's going 40 when it's going 35, with 4.10's. Perhaps if you had 4.30's, your truck would think you were going 45 when going 35.
    Sirfive[QUOTED] likes this.
  9. Feb 7, 2026 at 8:22 AM
    Gens
    Gens Amateur Techpriest
    01AC5VZMT4WDrTRD
    5100/2884 Front SPC UCAs 5160/OEM Rear
    Swapped shoes between my Toyotas today. I don't love the way the gulf state dealership gamer rims look per se, but I’ll be damned if the C-range BFGs don’t ride significantly better than the E-range Firestone X/Ts.
    I will however say that I am greatly amused by the Patrick Star rims on a 3rd-gen Tacoma, God bless Toyota for using the same hub size for as long as they did.
  10. Feb 7, 2026 at 12:21 PM
    Mr Badwrench
    Mr Badwrench New Member
    '01 SR5 4X4 V8
    She'll go 300 hectares on a single tank of kerosene
    I finally found another 1st generation for what seemed like a great deal. It was right next door to me, in fact. A spruce mica 2001 Tundra extended cab from my elderly neighbor.
    I'm glad to own it, but the guy could not repair a vehicle. At least he tried despite his old age, he's nearly 90 years old! I'll be long gone or sitting in a corner drooling on myself if I make it to that age.
    Some of the stuff that I am finding, it would have been better if he left it broken. Not the excellent deal I thought it was, now that I look into it, but I own it now.
    oscardog86, bmf4069, Tlar25 and 8 others like this.
  11. Feb 7, 2026 at 12:27 PM
    Jack McCarthy
    Jack McCarthy I’ve got my eye on you.
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Pics?
  12. Feb 7, 2026 at 5:19 PM
    Mr Badwrench
    '01 SR5 4X4 V8
    I'll post some tomorrow for sure. You guys might have some advice to help. There are cheap hose clamps on the coolant line that runs in front of the timing belt cover, and they leak. The coolant line goes to the oil filter housing. I don't see any way to swap them without pulling the fan shroud and possibly the tensioner for the fan belt, which I really don't want to do.
  13. Feb 7, 2026 at 5:22 PM
    Jack McCarthy
    Bill
    North of Boston
    Fan shroud is easy. Just two clips, one on each side, holding the bottom half to the top half. Most you would need is an extra large catch pan for the coolant to replace those hose clamps and refill.
  14. Feb 8, 2026 at 12:10 PM
    wtrbrdm
    wtrbrdm New Member
    Ben
    Eastern VA
    2006 Tundra DC Limited
    Installed a DC Decked system....short write up thread in the other sub-forum.
  15. Feb 8, 2026 at 12:46 PM
    Sirfive
    SATX
    Roxanne
    Bassani cat-back
    Cousins crossover needs the MAF cleaned. Can i just hit it with pb blaster or a waterhose?, or do i need the little can of cleaner?
    G_unit3000 and oscardog86 like this.
  16. Feb 8, 2026 at 12:47 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Olive oil works best, or beef tallow if your bougie
  17. Feb 8, 2026 at 1:37 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    How thick do you apply the tallow?
  18. Feb 8, 2026 at 2:07 PM
    Sensitive electronics (sensors, pots, contact slides) require electronics/contact cleaner, specifically. :rofl:
    oscardog86, bmf4069, tpope and 2 others like this.
  19. Feb 8, 2026 at 2:13 PM
    Jack McCarthy
    Bill
    North of Boston
    Orange Juice. It both conducts and cleans with citric acid.
  20. Feb 8, 2026 at 2:18 PM
    Actually, I take that back for a sec. Do we like this cousin? :rofl:
  21. Feb 8, 2026 at 3:02 PM
    Sirfive
    SATX
    Roxanne
    Bassani cat-back
    well he bought the big can of berrymans instead of the pair of tiny cans with tb cleaner. but i’ll go get some better tb cleaner and use his sensor cleaner on any vehicle that’ll let me.
  22. Feb 8, 2026 at 3:05 PM
    Sirfive
    SATX
    Roxanne
    Bassani cat-back
    Just got the 1.5l ecotec warm and fogged the airbox with a spray bed liner while he held the throttle down.
    2 cans. According to the smoke cloud, that works way better than seafoam.
    G_unit3000, shifty`, Tlar25 and 4 others like this.
  23. Feb 8, 2026 at 9:12 PM
    455h0le_dachshund
    Coastal TX
    Penelope & Elvira
    Here's the video of it idling
    PNW15[QUOTED] and shifty` like this.
  24. Feb 9, 2026 at 4:46 AM
    BroHon
    BroHon Mew Nember
    2000 SR5 AC V8 4x4
    Just a little update with actual pictures. I don't go out at night very often, was out for SupaBowl party last night and remembered to take some pics (better late than never?)
    Trees about 40yds/120ft out, slightly uphill maybe 5-6' elevation rise. Harness used for Hella headlights.
    Dark
    Fogs only
    Hella on 90watt/lowbeam
    Hella on 130watt/Highbeam
    Mirror mounted ditch lights only
    Everything
    Tracks are from me fooling around trying to drive into the back yard :rofl:
  25. Feb 9, 2026 at 5:43 AM
  26. Feb 9, 2026 at 6:00 AM
    BroHon
    BroHon Mew Nember
    2000 SR5 AC V8 4x4
    Holy shit look at Dreyfuss, he's a kid!
    Yeah I think that reflection was from the switch I put on my dash somehow making it to the front windshield, the blue light correlates anyway.
    I wasn't seeing anything with my eyes, :notsure::alien: but you hear stories out here in the sticks.:rofl:
    bmf4069 and Tundraforever1 like this.
  27. Feb 9, 2026 at 10:19 AM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    You're foglights with the yellow Auxito LEDs are impressive..... clean cutoff.
    This is now added to my list!
    Right now I only have only one side of the wheel with SWC and a few extra buttons would be great. And I don't think that my SWC light up. That would be a nice addition too
  28. Feb 9, 2026 at 10:22 AM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Thanks much. Now I gotta remember how to log into Facebook.
    Tundraforever1 likes this.
  29. Feb 9, 2026 at 2:02 PM
    Tundraforever1
    Tundraforever1 Nobody rides for free
    2001 2WD AC 4.7l 2010 2WD CM Limited 5.7l
    @FrenchToasty,
    I'm considering buying 3 of these exact panels for an upcoming project. What was your experience with them before you mangled it? What sorts of items did you power with them?
    Thx
  30. Feb 9, 2026 at 2:05 PM
    FrenchToasty
    Mo
    Bone stock
    So I have two of the 100w Renogy panels that power a 100ah lipo battery; kinda want another 100ah
    I mainly run my 79qt fridge freezer, sometimes the max air fan and also my water pump for my water heater for showers. They work well; I would look at a DC to DC charge controller to take advantage of drive time charging of the batteries or magic box if it go that route
