  1. Jan 17, 2026 at 4:16 PM
    wtrbrdm
    wtrbrdm New Member
    Ben
    Eastern VA
    2006 Tundra DC Limited
    Tequila Customs OEM replacements with clear corners.....love them.
  2. Jan 17, 2026 at 4:47 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Thanks!
  3. Jan 17, 2026 at 5:41 PM
    wtrbrdm
    wtrbrdm New Member
    Ben
    Eastern VA
    TEQ not tequila lol
    Tlar25, dbittle and 455h0le_dachshund like this.
  4. Jan 18, 2026 at 1:00 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I had to do that one very recently. Crazy how such a little thing could make so much noise.
    Voss[QUOTED] likes this.
  5. Jan 18, 2026 at 4:21 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Did your new one have a little bit of wobble to it?
  6. Jan 18, 2026 at 5:37 PM
    Sirfive
    Sirfive Socially feral
    SATX
    Roxanne
    Bassani cat-back
    when i replaced moms, in her sequoia, it was squeaky, and the bearings felt chunky, but no wobble. I’ve still got it somewhere. The paint was worn on one side of the pulley, more than the other.
    Voss likes this.
  7. Jan 18, 2026 at 6:46 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    Late to answer.. but my rust bucket red 4WD had several crossmembers replaced. They used bolts and nuts. Had the bed off when doing it.. Weld the rivet..
    Gens[QUOTED] and whodatschrome like this.
  8. Jan 18, 2026 at 6:48 PM
    BroHon
    BroHon Mew Nember
    2000 SR5 AC V8 4x4
    Felt some funkyness while in 4x4 on snow covered road. Checked camber, was NOT where I set it (something moved). Back story, Pre forum repairs Movtech LCA, and Moog cambolts. So I reset my camber/Tack welded each front cambolt washer/Adjusted outer tie rods to re-centered the steering wheel.(string method)
    Good news was no apparent slop in the fresh MovtechSupreme outer tie rods yet, and with 350ish miles the jam nuts were easy peasy.
    Also replaced front door speakers with a set of pioneers, which sounded like hot garbage.
    Just cheap TS-F1634R. I run no sub, and no amp.
    They listed a decent low freak range, but driving them at even half volume with my Alpine UTE-73BT sounded like I was trying to run 500 watts through them. Already returned them to big girl.
    So I put the stock ones back in after I gave them a coating of PVA polyvinyl acetate/ AKA watered down gorilla glue to strengthen them back up. They were dry and brittle, It seemed to help, but it could be just one of those mental things.
    I chalk it up to experience, and the fact that I'm just not dumping premium anything into this rig.
    No hacking of the harness, I soldered the new ones in, and then the stock ones back in again.
    Stock before
    And after 2 coats of PVA (if you do this stay OFF the surround)
    bmf4069, kodyquist21 and shifty` like this.
  9. Jan 18, 2026 at 7:34 PM
    shifty` Got patience on my neck like a cold, cold knife
    There are a looooot of component options out there ~$100 ....
    With 6¾" mid-woofer:
    With 6½" mid-woofer
    bmf4069 and BroHon[QUOTED] like this.
  10. Jan 18, 2026 at 7:38 PM
    Sirfive
    SATX
    Roxanne
    Bassani cat-back
    What does the pva do? Make em last longer? Stiffer?
  11. Jan 18, 2026 at 7:50 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    Finally got around to buying some new sway bar links and got them installed today. The worst part about this was #1 the top nut on old links was a biotch on passenger side just enough rust on threads to make it difficult for a small impact so I just ended up using a long 17 mm ratcheting wrench. Man the old ones were either too short or the bushings being torched caused some carnage. Hopefully this takes care of a little clank I've been hearing now and again when backing out of the drive. To windy and cold to hear today...
    kodyquist21, oscardog86, Voss and 7 others like this.
  12. Jan 18, 2026 at 8:00 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Ditch the sway bar, we have a no sway bar club
    bmf4069, khooiii, oscardog86 and 7 others like this.
  13. Jan 18, 2026 at 8:16 PM
    455h0le_dachshund
    455h0le_dachshund NO MASTERS, NO CHAINS
    Coastal TX
    Penelope & Elvira
    bmf4069, Rezkid, oscardog86 and 8 others like this.
  14. Jan 19, 2026 at 1:23 AM
    BroHon
    BroHon Mew Nember
    2000 SR5 AC V8 4x4
    Thanks for the ideas. My door cards don't have the tweeter option, not that I wouldn't carve holes in them.
    I did it before on a brand new Accord.... that was a little cringe worthy, but I LOVED those things up there.
    Crispy sound stage, esp for my hearing... which at that time was Much better haha.
    If things are TOO nice I'll just end up moving them to the next rig I reckon :rofl:
    I didn't look close, but does that raised ring on the face of the stock speaker seal up against the door card?
    Still baffled why those new ones sounded So Bad :notsure:
    Yeah, both. They were so dry and almost dusty, and you can see the UV that got to them through the grate.
    I think it also adds a level of moisture protection as well.
    I didn't know what to use, I just started hammering Ai with questions about products I had on hand.
    At the time I had no idea what PVA was, or that it was sitting right next to me (Gorilla wood glue)
  15. Jan 19, 2026 at 1:50 AM
    455h0le_dachshund
    Coastal TX
    Penelope & Elvira
    I been running Sony 6.75" speakers all four corners in the 06. They were relatively cheap and sound damn good with my Pioneer AVH.
    Got em from Wally world
    BroHon[QUOTED] likes this.
  16. Jan 19, 2026 at 2:02 AM
    BroHon
    BroHon Mew Nember
    2000 SR5 AC V8 4x4
    Does the extra 1/4" take some modifications, or just plop right in?
    Do you remember the model number?
    Remember I don't have an amp.
  17. Jan 19, 2026 at 3:11 AM
    455h0le_dachshund
    Coastal TX
    Penelope & Elvira
    No to the part number and no modifications. This was in 2019 when I installed em.
    I didn't have an eternal amp with em on my Pioneer AVH-601EX.
    I do have the 5 channel amp in the 06 now, since I put that AVH601EX into the 03 and had an AVH-4000NEX with a blown amp. (Botched JBL premium audio amp bypass killed the Pioneer's internal amp, when the bypass harness got stabbed with floor trim screw).
  18. Jan 19, 2026 at 4:21 AM
    BroHon
    BroHon Mew Nember
    2000 SR5 AC V8 4x4
  19. Jan 19, 2026 at 5:44 AM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    :) Knew this was coming! Maybe I'll test in the spring winds and higher center of gravity on shit winter roads has me nervous about it lol. I did think about it though. Do I get a sticker for the club?
  20. Jan 19, 2026 at 5:51 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    2004 AC 2wd to 4wd conversion ABS delete
    I regularly haul well over 1 ton in my bed. I removed my swaybar a few years ago.
    Hutcheson, bmf4069, Tlar25 and 8 others like this.
  21. Jan 19, 2026 at 6:21 AM
    Chris948
    Chris948 New Member
    DFW
    2006 DC
    for you it won’t do anything. In the heat the surrounds are the first to go. Mine turned into little fish food size flakes I’m guessing 5-10 years ago.
    It’s important to get something easy to drive if you aren’t upgrading the HU, but even cheap and easy to drive speakers are a massive improvement over stock Toyota.
  22. Jan 19, 2026 at 6:59 AM
    Gens
    Gens Amateur Techpriest
    01AC5VZMT4WDrTRD
    5100/2884 Front SPC UCAs 5160/OEM Rear
    On this subject, is anyone running OME 2884 coils in the front with the swaybar disconnected? I've seen people talk about running 700# springs and ditching the bar, but not a more intermediate spring like the 2884 that sits between OEM and the stiffer options.
  23. Jan 19, 2026 at 7:12 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    Sold my old sliders I built a couple years ago and went to the metal yard and got some more scrap metal to build up some new ones.
    I wanted something simpler that weighed less but still gave me some protection from underneath. I havent really done enough "rock crawling" to warrant the weight and size of the typical sliders that I previously had.
    So I built some simple single tube style ones with 1.5" square tubing. Hopefully I dont dent my doors on the next trip, or at the grocery store lol.
  24. Jan 19, 2026 at 7:25 AM
    Just reinforcing a point, seems the stock opening for our trucks was actually to 6¾".
    No amp is fine. If you want a bit more boost, go with components that have a 3ohm load, I know JBL and Infinity have options, I find Infinity speakers to be too shrill/tinny.
    No clue on why the new ones sounded so bad. Also, not sure if that cardboard ring is intented to seal to the door or not, but mine are fine without.
    I'd almost prefer to not have tweeters in the door, so I could re-jigger things, mount the tweeters in my A-pillar pods, and keep the mids down in the doors. Would make for easier/better sound staging.
    But if you were to go OEM-like and convert your door, a tip: If you find Toyota left no indication of the tweeter position (embossed area, etc.) on the plastic of the back side of that panel, then cut a cardboard template shaped with some reference points on the backside of the door, something you can easily transfer between doors (flip/flop). Mark your center point, and holesaw your hole diameter based on your tweeter option. Go slow, let the hole saw pop your center hole thru the fabric on the other side, but stop your cut before going you start pushing thru, so the fabric remains fullyintact on the interior-facing side. You can use a dull non-fabric-cutting implement (snips, bone shears, etc) to finish the job the hole saw started.
    Once it's done, take scissors and cut an "X" in the fabric from the center hole the pilot makes, out to 2-3mm from the hole edge. Leaving that extra couple mm of fabric before the edge of the hole, and not blasting thru with the drill will serve multiple purposes:
    • The fabric will never pull back away from the hole or tweeter basket, exposing the door plastic
    • You'll get a smooth transition from tweeter to fabric
    • You should be able to avoid buckling, because the tweeter basket will hold the fabric in the hole
    • The tweeter basket should have a more-snug fit thanks to the fabric shimming out the hole a bit
    It's ultimately how we'd handle things with new door cards at the shop. Sometimes when creating the "X", we'd knock down the four triangles it'd make, so there wasn't fabric flapping around, and one of the guys in the shop would just glue the triangles back to the door panel because he hated cutting things.
    I wish someone made A-pillar tweeter pods pre-fit to our trucks, but fat chance. No demand. In a 4-speaker truck like yours, with the base radio, no amp, if I were to throw tweeters in the pillar, I'd de-pin the two speaker wires where the door harness snaps in behind the kick panels, pop their input wires into a new connector, and use that to feed the crossover, then feed the door speaker out of the crossover via the other pair I de-pinned, and feed directly up into the A-pillar for the tweeter...
    Chris948 and BroHon[QUOTED] like this.
  25. Jan 19, 2026 at 7:26 AM
    w666
    Maryland
    I like the couple extra logs on the roof rack...don't want to waste a trip!
    BluegrapeVr6, Tlar25, bmf4069 and 3 others like this.
  26. Jan 19, 2026 at 7:39 AM
    BroHon
    BroHon Mew Nember
    2000 SR5 AC V8 4x4
    TS F1634R/$25/88db/4Ω/31 Hz – 16 kHz/sounded like shite. Not better than stock... YMMV
  27. Jan 19, 2026 at 7:54 AM
    BroHon
    BroHon Mew Nember
    2000 SR5 AC V8 4x4
    Great tips. I am running an Alpine UTE-73BT, not the stock head unit. 50W x 4 MOSFET amplifier (18W RMS x 4), so low end stuff.
    bmf4069 likes this.
  28. Jan 19, 2026 at 8:03 AM
    Believe it or not, that's more powerful than my W770, which is currently powering all six of my speakers, my OEM amp is bypassed. Specs on my ilx W770 per Crutchfield (Alpine also lists the peak 50x4 power, this is RMS):
  29. Jan 19, 2026 at 8:09 AM
    Only worth mentioning, speaker composition varied across year/cab/stereo option. Some had UV-friendly, robust surrounds. Some were susceptible to dry rot. It varies.
    My OEM speakers in the later-year AC trucks with premium (but not JBL) audio was a woven coated fabric, mine were fully intact, and whatever they coated the fabric with was still very pliable. Pictures of mine after 15+ years in the south are here: https://www.tundras.com/posts/2336915
    Note the front ones are sunbleached (right speaker here) to hell because my previous owner parked the truck outdoor in the sun, all day, every day. Surrounds are still mint. The other ones look like new, from the rear doors.
    The JBL systems in later-year trucks used a pure foam surround that dryrots and turns to dust.
    I've seen one other style of OEM speaker in our trucks that also crumbles. But in general, if you have the fabric-backed surrounds, they hold up exceptionally well.
    BroHon and Chris948[QUOTED] like this.
  30. Jan 19, 2026 at 8:47 AM
    Chris948
    Chris948 New Member
    DFW
    2006 DC
    yeah, I dunno. Those don’t seem crazy sensitive despite being marketed for stock replacements. The ones shifty sent are more in the 92db range which I look for without an amp.
    To try to be more helpful, I put these in a Honda Odyssey a few years ago, it was a “be done in an evening” project, no custom a pillars or anything, and I was really surprised at how much better they sounded without touching the head unit, but they also advertise a 93db sensitivity rating.
    https://www.crutchfield.com/S-bZBGyou4SJD/p_108R607FSL/Infinity-Reference-REF607FSL-shallow-mount.html
    I couldn’t care less about brand loyalty, the specs were good. Went with JL audio last time.
    shifty` and BroHon[QUOTED] like this.
