  1. Nov 30, 2025 at 2:04 PM
    shifty` Got patience on my neck like a cold, cold knife
    Can always talcum powder/baby powder the back wall of the cab under the rear window to see if it's coming from around the rear window seal.
    tpope likes this.
  2. Nov 30, 2025 at 2:24 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    Thanks for the suggestion. I found some puddling in my rear passenger corner of the cab..
  3. Nov 30, 2025 at 2:29 PM
    If you have one of those classic white Johnson & Johnson bottles, with all the tiny holes in the cap, you can twist the cap to open the holes, then feather the bottle in front of the panel. This'll send dust up toward the panel, and it should stick to the interior paint.
    After the next rain, shine a flashlight on the panel, and look for water runs thru the talc dust. I'm sure there are other ways to do this, potentially smarter ones, but it's an option using something a lot of households have in it.
    G_unit3000 and tpope[QUOTED] like this.
  4. Nov 30, 2025 at 3:20 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Went out to Rice Peak in the Santa Catalina mountains today with @AZBoatHauler
    We both attempted this trail 2-3 years ago right around this time and couldn’t make the summit due to trail conditions. People have definitely done some “trail maintenance” since then; and that helped out a lot this time. The trail was short but the views were spectacular! IMG_8646.jpg IMG_8647.jpg IMG_8649.jpg IMG_8651.jpg IMG_8652.jpg and what’s wheeling if someone doesn’t break something?! I’m super thankful I only destroyed a solar panel vs breaking my rear glass!
  5. Nov 30, 2025 at 3:29 PM
    Great views, bummer on the panel, those aren't exactly cheap either. A lot of them that size I was looking at recently cost more than a new rear shell window. Although I think that rear window is NLA.
    FrenchToasty likes this.
  6. Nov 30, 2025 at 3:31 PM
    Upshot Knothole
    Upshot Knothole This space for rent.
    In a van, down by the river. PNW
    2003 SR5 V8 AC TRD 4x4
    New bulbs to test out showed up yesterday, and I installed my antenna delete today. Waiting on more packages to show up this week before I spend an afternoon doing electrical work under the hood. So the headlights will need to wait till then.
    16377071-5A4D-4BD0-86E4-33CB30E3E562_1_105_c.jpg A6047978-DE16-487C-9D2C-36314CD49CF1_1_105_c.jpg
  7. Nov 30, 2025 at 3:33 PM
    FrenchToasty
    Mo
    Bone stock
    https://www.amazon.com/Renogy-Monocrystalline-Solar-Compact-Design/dp/B07GF5JY35
    Voss and shifty`[QUOTED] like this.
  8. Nov 30, 2025 at 3:35 PM
    Upshot Knothole
  9. Nov 30, 2025 at 3:39 PM
    FrenchToasty
    Mo
    Bone stock
    I’m sure I have long enough self tappers……. But the rack is what my shade and shower awning are mounted too. The brackets I used were the lowest profile I could find
    It was a stupid move on my part, I was backing up blindly and a tree sprouted out of no where
    G_unit3000, bmf4069, Voss and 3 others like this.
  10. Nov 30, 2025 at 4:02 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 V8 4wd + 06 SEQUOIA LTD 4wd
    So you're going to try both the 130/90 and 100/80 and see which one you like better?
    I'm installing the 100/80 tomorrow. I hope it's a noticeable improvement.
  11. Nov 30, 2025 at 4:12 PM
    AZBoatHauler
    So.Arizona
    Great pics!! Thanks for leading the way.
  12. Nov 30, 2025 at 4:21 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    Noticed my sway bar bushings are shot so went to replace today. One of the bolts that goes through a welded nut on the R bracket was really fighting me and sure enough the nut broke off. Had to get the angle grinder out to cut it off. Ordered new bushing brackets from Toyota parts online with the BF discount ($30 each). Old one could have been fixed or just use a loose nut, but they were getting pretty crusty. Since I was going to be waiting for new brackets figured I'd remove and order new sway links as well. Those didn't want to come off either so also got the angle grinder treatment... ordered new sway links from rock auto ($100 each for OEM, nope).
    I've never driven without the sway bar installed. Pretty sure that's not a big deal as long as I don't take any corners too fast yeah?PXL_20251201_001738354.jpg
  13. Nov 30, 2025 at 4:28 PM
    Myself and plenty of others have deleted our swaybar. Don't corner too fast (like taking 270° interstate offramps above 35-45mph). You're going to be fine.
  14. Nov 30, 2025 at 4:28 PM
    FrenchToasty
    Mo
    Bone stock
    Heard
    AZBoatHauler likes this.
  15. Nov 30, 2025 at 4:32 PM
    Upshot Knothole
    Yup, I also ordered a couple sets of the Osram 100/90w bulbs. Gonna try them all out and see which one gives the best light and without being too annoying to look at.
    abcinv likes this.
  16. Nov 30, 2025 at 4:36 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    Annoying to look at? Like annoying for oncoming traffic because they are too bright?
  17. Nov 30, 2025 at 4:43 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    Are there any other benefits of not having it on besides off road improvement? I haven't done any true off roading in a long time, so haven't put much thought into sway bars.
  18. Nov 30, 2025 at 4:56 PM
    Upshot Knothole
    Yeah, trying to find a balance between bright conventional lights but not quite LED annoying. I already added one pair of off road spots, and have another set to install. Figure I can tone down my headlights a little and make up for it with the additional lights when I'm off road or way out in the country and on the lookout for deer.
  19. Nov 30, 2025 at 5:13 PM
    It's a travel extension limiter, which may be a plus for some folks. It helps with body roll when turning at speed, it truly does kill sway. I've thought about reinstalling, I have new bushings, I'm just ... lazy, I guess.
  20. Nov 30, 2025 at 5:36 PM
    455h0le_dachshund
    455h0le_dachshund NO MASTERS, NO CHAINS
    Coastal TX
    Penelope & Elvira
    https://youtu.be/wJoU6Vbf-_o?si=aPPZoSgmUYIM7gsw
    Sorry I never got a pic of the seat mount temp fix. Got it handled good 'nuff and took off for Hidden Falls by lunch Friday. Got there about 5pm and setup camp near some hill country friends. Then went night wheeling on some 4's and 5's. Saturday I took my buddy Simon on some 1's and 2's in his stock 5th gen T4R. Then back to 4's and 5's, followed by more night wheeling.
    I bent my Alcans leaf springs on the driver side. Looks like the main leaf might be fixable and the second leaf looks like it would probably need to be replaced.
    I'm thinking about buying the Archive Garage leaf packs or building Alcan bastard packs 2.0.
    I want to say my rear bumper is 200lbs, cap is 200lbs and spare tire is 70lbs. So I guess I could go with the medium leaf packs from Archive Garage. I'm interested to hear from anyone with these or their HD packs.
    https://youtube.com/shorts/mx-yCFWKxk8?si=_c9CtlQAS6AAv3SQ
  21. Nov 30, 2025 at 6:00 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Wjat tails are those? And the side markers are clear?
  22. Nov 30, 2025 at 6:01 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I went down this rabbit hole a few months ago. I went back to the colight projectors. I tried LED, high output halogen, a dedicated headlight harness, all of it. Hope one of them works for you, but they were not up to snuff compared to the mini projectors.
  23. Nov 30, 2025 at 6:02 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Damn dude what did you bend it on?
  24. Nov 30, 2025 at 6:04 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Gotta love marketplace. Absolutely did not need this, but for $75 bucks and close by… you just can’t say no.
  25. Nov 30, 2025 at 6:06 PM
    Upshot Knothole
    The bike or the rack?
  26. Nov 30, 2025 at 6:08 PM
    Upshot Knothole
    I've got a set of colight Y6s sitting on a box untouched. Gonna try the high wattage bulbs first, and if none of them really make me happy, I'll tear the reflectors out of my housings and try the Y6 projectors. I've got other vehicles that use H4s, so all of the bulbs I'm trying will get used eventually.
    khooiii[QUOTED] likes this.
  27. Nov 30, 2025 at 6:11 PM
    ToyotaDude
    ToyotaDude Member
    Thanks for doing this....for science.... trying to decide which way to go as well, bc HB are important.
  28. Nov 30, 2025 at 6:13 PM
    455h0le_dachshund
    Coastal TX
    Penelope & Elvira
    Your mom. :rofl::p
    Nah man I don't know. I didn't notice until the ride home.
    If I had to guess... it was one of the loud noises I heard last night. o_O
    Could've been Carnage Canyon. Could've been the deep rutted S drop into The Falls. Could've been Green Horn. It's all a blur. :oops:
    oscardog86 and Jack McCarthy like this.
  29. Nov 30, 2025 at 6:15 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    The rack.
  30. Nov 30, 2025 at 6:17 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    How?
    Nvm, just saw you explain. That's wild.
