  1. Nov 29, 2025 at 2:57 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    @Jack McCarthy I checked this morning and found that the block mounted to the frame is indeed brass. I have no idea about keeping the brake pedal depressed.
    Jack McCarthy likes this.
  2. Nov 29, 2025 at 2:58 PM
    Jack McCarthy
    Jack McCarthy I’ve got my eye on you.
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Thanks for checking. I appreciate it.
  3. Nov 29, 2025 at 3:01 PM
    Dook55
    Dook55 RCLB Guy
    Montana
    2004 4x4 V8 RCLB 2006 4x4 V8 RCLB
    If a brake line bursts, wouldn't the anti-lock brakes redirect enough fluid so you could get it stopped?
  4. Nov 29, 2025 at 3:04 PM
    Jack McCarthy
    Bill
    North of Boston
    No anti-lock present. Makes it much simpler.
    Dook55[QUOTED] and BroHon like this.
  5. Nov 29, 2025 at 3:07 PM
    bing5
    bing5 Fight the powah
    New Mexico
    2004 DC SR5 4WD V8
    Performed a power steering flush today using @RustyShackle323 method. Worked like a champ! Sorry, didn't have pics in me today. Old stuff looked like a light cola.....cherry syrup now.
    Power steering return hose was reasonably crunchy after 275k miles - pump to reservoir section.
    Next up, transmission drain and fill.
  6. Nov 29, 2025 at 3:11 PM
    Jack McCarthy
    Bill
    North of Boston
    Went crazy today coating the exposed rusty sections of frame and underside of the bed to prevent anything beyond the current surface rust. Also sprayed a can into both boxed frame rails since that’s the area I have the most problems covering internally.
    I think I huffed a little of that mist. Probably should wear a mask next time.
    bmf4069 likes this.
  7. Nov 29, 2025 at 3:13 PM
    BroHon
    BroHon Mew Nember
    2000 SR5 AC V8 4x4
    Fluid film = Nose Candy :hearteyes:
    bmf4069 and Jack McCarthy like this.
  8. Nov 29, 2025 at 3:21 PM
    bing5
    New Mexico
    2004 DC SR5 4WD V8
    Looks like 27411-0A050, but double check me.
    Voss[QUOTED] likes this.
  9. Nov 29, 2025 at 7:11 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    Pulled the single axle and picked up then delivered a new bed to a friend's house. This was the first time anyone sat in the backseat. My wife rode back there while my friend sat up front with me. :hattip:
    Dangit! My super cool vintage-looking Toyota keychain for the Tundra broke! :mad:
    Now I must find a new cool looking keychain as a replacement. :cool:
    Steve4X42002 likes this.
  10. Nov 29, 2025 at 7:47 PM
    Steve4X42002
    Steve4X42002 New Member
    Minnesota
    2002 Tundra Limited Access Cab 4x4 V8
    Am I crazy or? My water pump clearly has 6 bolts and 2 studs with nuts. I have watched at least 2 videos where they said remove the 5 bolts and 2 nuts with studs. My Aisin timing belt, water pump kit came with 5 new bolts. The 6 bolts I removed are all the same and the same as the 5 new bolts in the kit. The old and new water pump match up perfectly. I put the 6 old bolts in the same holes of the new pump as I removed them from the old pump. I know I should have probably finished this project today but I had an interruption and will get back to it tomorrow. I plan to just pick one of the old bolts and reuse it. <edit> looking at the FSM I see where it says 'nut" I have a bolt. So the mechanic at the dealership that did this job 05/06/2015 must have replaced a stud and nut with a bolt.
    Bought2Pull likes this.
  11. Nov 29, 2025 at 8:17 PM
    Steve4X42002
    Minnesota
    Here is the bolt in a photo I took before taking the water pump off. The question is do I or should I care?
  12. Nov 29, 2025 at 8:31 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    That stud makes the gasket alignment easier. Just slip it in and install the water pump. That said... as long as it seals. Job done...
    Nice attention to details... This illustrates why I do my own mechanic work.
    Steve4X42002 and Bought2Pull like this.
  13. Nov 29, 2025 at 11:14 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    I compliment your attention to detail in posts. I need to learn how to be as exact as you in describing and illustrating situations. I am not picking on you, I am legit complimenting your communication abilities. :thumbsup:
    Steve4X42002[QUOTED] likes this.
  14. Nov 30, 2025 at 3:28 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    You should be able to buy that brake line section from toyota pre-bent but depending on routing it may be easier to re-flare and add in a small section.
    In regards to bench bleeding, remember your truck is a bench, with a perfectly shaped vice to hold down your master. You just unhook your lines and bleed it like you would on a bench.
    When you unhook the line though, it's gonna start dripping and it won't stop till you're done. Keep the reservoir topped off during this and you should be good.
  15. Nov 30, 2025 at 5:12 AM
    M14 EBR
    M14 EBR Team Precision
    USA
    Yesterday I took my 2002 out on the road to run a couple service calls an hour northeast of me and earned myself a couple of paychecks, and I topped off the tank with some Shell gasoline before parking it. I plan to run one last service call more than an hour south of me on Wednesday, and then it will sit for at least a month while I recover from back surgery.
  16. Nov 30, 2025 at 5:46 AM
    Sorry to hear about the back surgery, here’s hoping for a quick recovery recovery!
    bmf4069, bing5, BroHon and 2 others like this.
  17. Nov 30, 2025 at 8:13 AM
    M14 EBR
    USA
    Thank you.
  18. Nov 30, 2025 at 9:34 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Don't like pinching vehicle soft hoses to stop flow. Usually cap the line at the disconnection point(s) with a plastic/rubber cap to at least minimize draining (like when swapping calipers or cylinders). But if master drains then have used a bench bleed nipple and tube kit to bleed it without removing from vehicle. When doing major replacements (like replacement of all soft lines), have removed the hard lines at the master and installed the bleed nipples on the master with the temporary short return hoses pinched to keep it from draining. Once the new parts have been installed can reconnect the main hard lines to the master and bleed the system.
  19. Nov 30, 2025 at 10:21 AM
    Jack McCarthy
    Bill
    North of Boston
    Any idea what sort of cap I need?
    I’ve at least read up that the pedal should be depressed to isolate the rest of the master cylinder from the line being partially drained when replacing a section. May need to use propane heat, but for now I’ll just soak it with penetrant daily.
  20. Nov 30, 2025 at 10:25 AM
    Jack McCarthy
    Bill
    North of Boston
    Any idea who makes a decent bench bleed kit for the master cylinder if necessary?
  21. Nov 30, 2025 at 10:53 AM
    ToyotaDude
    ToyotaDude Member
    I collect a variety of caps from new parts usually. Some come from the master/brake line themselves. Have even wound a rubber band around some plastic (like from a zip lock bag) to make a cap...
  22. Nov 30, 2025 at 10:54 AM
    ToyotaDude
    ToyotaDude Member
  23. Nov 30, 2025 at 10:57 AM
    NickB_01TRD
    Nick
    KY
    This is also what I would recommend for someone that isn't doing this on a super regular basis. It's the one I've used a few times. This kit will be $20+ at a parts store though
  24. Nov 30, 2025 at 11:02 AM
    Jack McCarthy
    Bill
    North of Boston
    I think I’m going to take off the 2nd week of December so I can tackle this in the sh!tty weather and not worry about traveling until the 5th of January. Already stocked up on water, juice, fish and canned goods just in case I’m stranded for a bit.
    Was hoping to wait until the 3rd week to take off but I guess I’ll have to burn my carryover PTO so I don’t run the risk of rear ending someone or hitting a tree/jersey barrier.
    Figure I’ll just get the 6-8” inch section to replace and the rubber brake line in case the heat destroys the original. I should be able to return it if I don’t use it.
    Tomorrow I get the umbrella insurance coverage just in case.
    Not a merry Christmas for me. :(
    G_unit3000 and 455h0le_dachshund like this.
  25. Nov 30, 2025 at 11:30 AM
    BigRig7
    BigRig7 New Member
    TX
    New headlights fogs and tails!!!!
  26. Nov 30, 2025 at 11:31 AM
    Nicklovin
    Nicklovin Yap Yap
    Nick
    Huntington Beach, CA
    00’ 4.7 AC 4x4 - GFC
    Sweet grille
  27. Nov 30, 2025 at 11:35 AM
    BigRig7
    BigRig7 New Member
    TX
    Thanks! May add this to it.
  28. Nov 30, 2025 at 11:40 AM
    ToyotaDude
    ToyotaDude Member
    Examples (not from a Tundra)
    oscardog86 and whodatschrome like this.
  29. Nov 30, 2025 at 11:43 AM
    DeejayK
    DeejayK That's a HORRIBLE idea. What time?
    Keith
    '03 Tundra DX (base) RC LB 3.4L V6 A/T Phantom Gray Pearl
    Is yours a Darrell Waltrip model, or do you just have the DW grille?
    What headlights did you go with?
    - K
  30. Nov 30, 2025 at 11:56 AM
    BigRig7
    BigRig7 New Member
    TX
    Yeah it’s a waltrip. They are ones from Amazon. Took out the housings and added LEDs
    G_unit3000 likes this.
