What fuse for DRL?
Discussion in 'Lighting' started by Danimal86, Jun 26, 2020.
  1. Jun 26, 2020 at 10:21 AM
    Danimal86
    Danimal86 [OP] Looks clean even when its dirty!
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I've been troubleshooting a drl problem with my Triton V6's, they stopped working as drl lights, but they still work as switchback blinkers and are always on when i turn on the headlights.
    I talked a bunch with Vled and they thought the HDRL modules were bad. I ordered some new ones and still have the same problem. I figured that it would be smart to try to put the stock bulb back in, and see if its working (i cant believe i didn't do this before i ordered the new modules). No drl, but it turns on with the headlights, so its gotta be a fuse.
    Note: i've got retrofitted headlights and the halo and strip under the headlights are working perfectly as drl.
    I thought id better go through and start checking fuses, and cant really seem to find the one that is for the drl.
    Anyone know?
  2. Jun 26, 2020 at 11:51 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    LED DRL have a relay and a fuse in the underhood fuse box: (Edit: Nevermind, if you had the LED DRL you wouldn't have the Tritons.) Other fuse box is under the driver side dash, try there.
  3. Jun 26, 2020 at 12:41 PM
    Danimal86
    Daniel
    Sacramento, CA
    Yeah, i saw the "led drl" fuse, but dont have those (interesting that its there on my 17'.
    I'll check under the drivers dash
  4. Jun 27, 2020 at 7:52 AM
    Danimal86
    Daniel
    Sacramento, CA
    I've never actually tried to look under the dash for that fuse box. Holy hell, it's up there.
    It was 102 yesterday and I got as far as pulling the cover and looking at the diagram. Nothing really screamed DRL. It was way too hot and I abandoned ship.
    Only in the 80s this weekend. Hopefully I can give it a second look.
    Anyone know which one?
  5. Jun 28, 2020 at 12:11 PM
    Danimal86
    Daniel
    Sacramento, CA
    Its cool enough to mess around with the truck again. i went under the steering wheel and pulled the fuse box cover. I went through with a fuse tester pen and everything had power to both sides of the fuse except for a 7.5a Tow BK/UP and the 15amp TAIL. I swapped both of those with new fuses, and still no drl's. Anyone know if those are supposed to have power to them when the truck is running (without the headlights on)? I tested them with the headlights on, and there's power to both sides.
    Now i'm trying to go through the install instructions for my projectors to see if there's anything missing. Maybe @iHacker can chime in?
    here's the instructions i followed for the wiring.
    https://www.tundras.com/threads/how-to-retrofit-install-guide-by-eledobleu.9086/
  6. Jul 13, 2020 at 9:16 PM
    BigArt
    BigArt New Member
    2008 Tundra Crewmax Limited
    Did you ever figure this one out?
    I ran into the same problem when I upgrade my headlights. Figured out it needed to be reset by disconnecting the battery.
    Something about the computer needing to be reset. no fuse to be found.
  7. Jul 20, 2020 at 7:21 AM
    Danimal86
    Daniel
    Sacramento, CA
    i haven't tried disconnecting the battery, i'm running out of things to check, so i might give it a try.
  8. Jul 20, 2020 at 2:51 PM
    Danimal86
    Daniel
    Sacramento, CA
    it was worth a shot, i let it sit with the negative disconnected for a few hours. Still no drl.
  9. Jul 20, 2020 at 6:48 PM
    BigArt
    BigArt New Member
    sucks, sorry to hear that.
  10. Dec 5, 2020 at 6:17 PM
    Macbanjo3
    Macbanjo3 New Member
    Bay Area, Ca.
    2016 White DC SR5 5.7 4x4
    Was this issue ever resolved? I’m in the same situation. Thanks.
  11. Dec 5, 2020 at 7:27 PM
    Danimal86
    Daniel
    Sacramento, CA
    I was mistaken and the v6's dont work as drl's (in my case, i thought i remembered them doing it, but nope). Its a downside to the retrofit's i'm using. The motocontrol doesn't allow it.
    If you just lost your regular drl's there's a fuse box under your glove compartment that you can check for blown fuses.
  12. Dec 6, 2020 at 8:24 AM
    Macbanjo3
    Bay Area, Ca.
    Thanks for responding!
  13. Dec 6, 2020 at 9:27 AM
    Danimal86
    Daniel
    Sacramento, CA
    You got it.
    Did you find a blown fuse?
  14. Dec 6, 2020 at 3:02 PM
    Macbanjo3
    Bay Area, Ca.
    I haven’t checked it, yet. Although, My issue is a little different from yours. I have a ‘16 with the ‘19 pro headlights with ihacker harness. DRL doesn’t work with lights off and truck running. But, it works with lights on.
  15. Dec 6, 2020 at 3:09 PM
    Danimal86
    Daniel
    Sacramento, CA
    Gotcha. you should pm ihacker. I ended up reaching out to him about my (non-existant) issue and he was really helpful.
  16. Dec 6, 2020 at 3:10 PM
    Macbanjo3
    Bay Area, Ca.
    Sweet! I will. Thanks, Man!
  17. Dec 6, 2020 at 4:46 PM
    Macbanjo3
    Bay Area, Ca.
    @iHacker replied super quick and knew the exact issue I had. The wire that was fed through the firewall had a loose connection under the dash. I must’ve inserted the pin wrong. Re insert the correct way and now got a solid connection. DRL back in action. Thanks ya’ll.
    iHacker likes this.
  18. Dec 6, 2020 at 6:21 PM
    Danimal86
    Daniel
    Sacramento, CA
    That's awesome! He really knows his stuff!
  19. Mar 20, 2022 at 8:12 PM
    New_to_tundra
    New_to_tundra New Member
    Connor
    2007 toyota tundra tdr offroad
    What if my truck doesn't have the drl fuse which one would be best
