What does the center speaker do ... 2018 Tundra ...
Discussion in 'Audio & Video' started by RB1, Nov 24, 2018.
  1. Nov 24, 2018 at 7:53 AM
    RB1
    RB1 [OP] New Member
    2018 Tundra Sport DoubleCab 5.7
    Just curious ... is the center speaker a separate channel from the HU or just some kind of hybrid of the left and right channels?
    Also, when I have had the tweeters out I note there is a sound tube that I initially thought ran from the back of the tweeter to the front dash port ... however after taking out the tweeter I see it looks like the tube travels toward the center speaker, is that true or where does it actually go?
    Pic - red arrow is the mouth of the port, blue is the path the tube seems to take toward the center ...
    Thanks
  2. Nov 24, 2018 at 7:58 AM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    Not sure about the center speaker, but the port in front of the side speakers is an air vent for the defrosters that is aimed at the side windows.
  3. Nov 24, 2018 at 8:01 AM
    RB1
    RB1 [OP] New Member
    Ha, well there you go, here I thought it was some kind of engineered audio feature ... shows how much I defrost in the desert! thx
  4. Nov 24, 2018 at 8:33 AM
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
  5. Nov 24, 2018 at 8:41 AM
    RB1
    RB1 [OP] New Member
    Ya ... don't ya love it when you make yourself look dumb ... DOUGH!
    Still like to know about the center speaker tho ...
  6. Nov 24, 2018 at 8:55 AM
    AustinGS
    AustinGS New Member
    Austin
    2014 Tundra
    K&N, level and tires
    I’m curious as well. I think it’s a separate channel
  7. Nov 24, 2018 at 4:48 PM
    styx
    styx New Member
    Larry
    Knoxville, TN
    2017 SR5 DC TRD Offroad Magnetic Grey
    Raptor OEM Nerf Bars Leer Hard Tonnaeu Weathertech Vents Driver assist handle
    Center speaker is a dual voice coil. Both right and left channels feed this speaker to create a center channel. You can simply unplug it to achieve better stereo separation. I run mine disconnected.
  8. Nov 24, 2018 at 7:22 PM
    RB1
    RB1 [OP] New Member
    Interesting ... thanks ... is the better separation due to no sound coming from it or that the signals are not getting mixed at the connection between R/L?
    Rica25 likes this.
  9. Nov 25, 2018 at 1:01 PM
    styx
    styx New Member
    Larry
    Knoxville, TN
    No sound out of the speaker. The Tundra dashboard is not wide enough to effectively make use of a center channel. The recommended spacing between normal stereo speaker systems is 5 to 6 feet. Greater than that will allow the center channel to be used most effectively. I found the Tundras center speaker to blur or muddy the spaciousness of the music. The speaker cone is where the mixing takes place as it plays the sounds of both left and right channels.
