What Do You Tow With Your '22?
Discussion in 'Towing & Hauling' started by Mattedfred, Feb 8, 2022.
  1. Feb 1, 2023 at 5:50 PM
    #91
    FSS
    FSS New Member
    PBNB. You shouldn't notice the Timbrens at all unloaded. Check for space between the timbren and axle. They will send you a shorter base a no charge if you need it. I have about an 1" of space.
  2. Feb 1, 2023 at 6:17 PM
    #92
    saleen079
    saleen079 New Member
    22 Tundra Limited TRD
    Lots of DIY stuff
    I have them as well. No issues without a load. I've only bottomed out a couple of times on the terrible roads in California. They definitely help when towing.
  3. Feb 1, 2023 at 6:21 PM
    #93
    PBNB
    PBNB TRD Crew
    Peter
    Vancouver, BC
    2022 Limited Crewmax L
    MBM - TRD Offroad
    Thanks, I have about 1/2" of space. What I am feeling is the Timbren contacting the axle under some suspension movement so the little gap is taken up and then the stiff Timbren stops the suspension making the ride stiff. That's why I was wondering if they soften up over time.
  4. Feb 1, 2023 at 6:34 PM
    #94
    FSS
    FSS New Member
    PBNB. Contact Timbren to get the shorter base sent to you. You don't have to send your current ones back. You'll be able to compare.
  5. Feb 1, 2023 at 8:37 PM
    #95
    Screwy Louie
    Screwy Louie New Member
    2022 Tundra limited double cab with TRD pkg white
    I like them, I have a good inch clearance, so don't really feel them unless driving on a bad road, whether they'll soften, not sure. I hope not.
  6. Aug 16, 2023 at 4:19 PM
    #96
    saleen079
    Lots of DIY stuff
    Looks like some nice weather you're havin.
    FI460, PBNB and Mattedfred[OP] like this.
  7. Aug 16, 2023 at 4:51 PM
    #97
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    24RLXLX? I have the same trailer!
    When we picked it up in January.
    FI460, PBNB and Hella Krusty like this.
  8. Aug 16, 2023 at 4:55 PM
    #98
    Jsmittyy
    Jsmittyy New Member
    2022 magnetic gray platinum
    Tows like a champ!
    FI460, 22whatwedo and PBNB like this.
  9. Aug 16, 2023 at 6:04 PM
    #99
    Daviscamper
    Daviscamper New Member
    2023 limited AG crewmax 6.5
    23 crewmax 6.5 with air bags and equalizer weight distributing hitch. 1972 23’ Airstream ~5000lbs, and a bed full of gear. About 1600 mile round trip from outside Sacramento (75’ above sea level) over the Sierra (~7300’), across the desert and again back uphill into the sawtooth. Did pretty great. Overall was close to 12.5-13 mpg which I was pleasantly surprised at. Towing between 60 in CA and 65-70 in NV and ID when freeway conditions allowed.
  10. Aug 16, 2023 at 6:47 PM
    #100
    TundraMoe
    TundraMoe New Member
    2022 Tundra Crew TRD Off-road
    Falken WildPeak tires Bora 1.25" wheel spacers Rough Country tonneau Go-Rhino steps
    IMG_4941.jpg At our lake spot in NW Wisconsin. 34’ TT I pulled up in May and parked for the summer, Suzuki z400 in the bed pulling my 17’ boat. Boys and their toys…the Tundra tows great.
  11. Aug 16, 2023 at 7:50 PM
    #101
    Hella Krusty
    Hella Krusty New Member
    You have that adjusted perfect......well done.
  12. Aug 17, 2023 at 10:32 AM
    #102
    4genRunner
    Southwestern MO
    So far, no. There were a few minor cosmetic things that I resolved myself, but have not had anything that required me to have warranty work done.
  13. Aug 19, 2023 at 6:51 AM
    #103
    Jorts
    Jorts New Member
    Jordan
    Raleigh, NC
    2023 MBM Platinum
    Just picked up our Imagine 2670MK yesterday, it towed great to the house! Our first trip is next weekend. We upgraded from an Apex 215RBK, which I couldn't even tell that it was back there.
    And yes, I know it's a 23 not a 22, close enough.
  14. Aug 19, 2023 at 2:15 PM
    #104
    ryanjay11
    ryanjay11 New Member
  15. Aug 19, 2023 at 2:57 PM
    #105
    nmmike
    nmmike New Member
    2022 Tundra CrewMax SR5 TRD
    We tow a 5500 lb travel trailer with 500 lb tongue weight, tandem wheels and Blue Ox WDH. We have approx 1300 lbs Payload with our SR5 CM as built, and with our camping gear, dogs, and us we are probably OK. The Tundra tows great, squats a bit, and has pretty low actual payload lbs the way they are actually equipped. But overall, except for having to be careful with the payload, it is a good light duty half ton TV.
    Jorts likes this.
  16. Aug 19, 2023 at 2:58 PM
    #106
    nmmike
    nmmike New Member
    Looks like a pretty large trailer for the Tundra? What is the hitch weight?
  17. Aug 20, 2023 at 5:34 AM
    #107
    Jorts
    Jorts New Member
    Jordan
    Raleigh, NC
    2023 MBM Platinum
    Listed as 690lbs, but realistically probably closer to 900lbs fully loaded. I’ve ran the numbers (https://www.towing-calculator.com/) and I’m cutting it close on payload, so I just need to be careful about how I load up. I want to get it to a scale at some point to get the real numbers, but so far the Tundra feels fully capable to pull it and stop it.
  18. Aug 28, 2023 at 10:37 AM
    #108
    TRD-JP
    TRD-JP New Member
    Winnipeg, Canada
    2023 Tundra CM Limited TRD OR Midnight Black
    I wanted to come back to this thread after our big two week adventure. I hope my review and some of my numbers might help people with future purchase decisions...
    We travelled from Canada down to Yellowstone, then over to the Bighorn Mountains, then over to the Black Hills, then back up home. We had a lot of diverse terrain and driving conditions: interstates, rolling hills, long steep up and downhill grades, etc.
    We pulled an Imagine 2400BH with a 2023 Tundra Crewmax TRD OR and Andersen WDH. There were two adults and two older teenagers in the vehicle but nothing in the bed. The trailer was fairly loaded but tanks were all empty most of the time. I used Tow+ quite often given a lot of the trip was on rolling areas with constant changes in gears. Sure, 2000 RMPs for long stretches is hard on gas, but I think it kept the transmission happy for all 3000 miles of the trip. I used 91 Octane for the whole trip.
    Here are my weights (WDH not engaged on top and WDH engaged on bottom). Truck was full of gas:
    Converted
    Without WDH
    Steer - 3,373 lbs
    Drive - 4,012 lbs
    Trailer - 6,504 lbs
    Gross - 13,889 lbs
    With WDH
    Steer - 3,571 lbs
    Drive - 3,725 lbs
    Trailer - 6,592 lbs
    Gross - 13,889 lbs
    Truck Specs
    GVWR - 7231 lbs
    Front Axle - 4079 lbs
    Rear Axle - 3858 lbs
    Trailer Specs
    Dry Weight - 5809 lbs
    GVWR - 7494 lbs
    Length (bumper to hitch) - 28'11''
    The numbers say I was 154 lbs over payload - and without WDH, 154 lbs over the rear axle rating. With the WDH engaged, I am still 154 lbs over payload (the 88lbs transferred to trailer axle doesn't count if you want a proper payload calculation), but I am within the rear axle limit by 133 pounds. It is pretty amazing that the WDH transfers 198 lbs to the front axle and 88 lbs to the trailer axle.
    Impressions
    The truck tows great and was able to handle everything I asked it to do. I was really impressed with the performance of the Andersen WDH. There was never any sway, even on some windy stretches of prairie. When the wind kicked the trailer, it bounced right back in line immediately. The Andersen is a very light WDH, so the marginal implications to payload were very nice. It was also really easy to adjust with some simple turns of the nut.
    The WDH got the truck extremely level - the wheel well heights between the front and back were within half an inch. I originally thought I might want air bags or springs but am now glad I saved my money. The rear squat was entirely equal to the front and the ride/bounce was fine.
    The Imagine 2400 has a huge crawl through that we packed pretty full, but the under bunk storage at the back was used for things as well. I think we balanced it quite well because we didn't experience any "porpoising".
    I tried using cruise control in various situations and found myself cancelling and getting back in control more often than not when dealing with rolling hills and steep grades. I found it braked too much and didn't downshift as soon as I would like. Otherwise, I felt the truck handled grades amazingly, and I didn't smell any brake stress at the brake checkpoints coming out of the long downhill stretches. Uphill was equally as impressive - the sounds of the turbos singing while pulling uphill became a nice soundtrack to the drives through mountain areas.
    I've heard a lot of people note that they "barely notice" their trailer while towing. I think this is true in some sense, but most of the time I was very conscious of the trailer and could tell it was a lot of extra work for the truck to pull. I really didn't go over 65 mph on any interstates because it quickly became noticeable that I wouldn't be in full control. I also had to really slow down on sharp mountain turns if I wanted to be sure I was in full control.
    My conclusion is that this is the maximum size of trailer I would ever want to tow with this truck given the type of camping we want to do and a cab full of passengers. I know some people "max out" at a 22 foot floorplan with a half ton, but a 24 foot floorplan is absolutely fine if you drive appropriately. I would pull upwards of a 2800BH if I just had short trips to local campgrounds, but I would not want to pull something like that on the type of trip we just had.
    Hope this helps.
    Shot is from Boulder Park Campground in the Bighorn National Forest. One of the best little campgrounds I've ever seen.
    Mattedfred[OP], t300, FI460 and 6 others like this.
  19. Aug 28, 2023 at 12:24 PM
    #109
    PBNB
    PBNB TRD Crew
    Peter
    Vancouver, BC
    MBM - TRD Offroad
    Sounds like a fun trip!
    That looks like you got a decent amount of weight returned to the front axle. The weight to the trailer axle looks light. I know that with some larger trailers, the Andersen had a hard time getting the weight shifted. This is not my experience but some of the Airstream folks with the larger trailers have had that happen.
    Do you know what the trailer tongue weight is?
    Did you use the various tow modes. I found that Tow Max (if I recall) did a good job of adding engine braking on hills. Recently, I have been using the manual shift when starting up with the trailer onboard as it pulled the transmission into 1st rather than starting in 3rd.
  20. Aug 28, 2023 at 3:43 PM
    #110
    4genRunner
    Southwestern MO
    Awesome report! I also tow a 24' travel trailer and can report the same experiences you had. I also agree that 24' is the largest I feel comfortable with for long trips in a 1/2 ton. The Tundra handles it really well and pulls like freight train. Heading up steeper inclines, you'd think it was a diesel the way it pulls. Very happy with the towing ability.
    TRD-JP likes this.
  21. Aug 28, 2023 at 3:46 PM
    #111
    TRD-JP
    TRD-JP New Member
    Winnipeg, Canada
    The tongue weight is somewhere around 780 pounds based on comparing these scale tickets to ones I did previously with just the truck full of passengers. This is closer to the 10% of GVWR range which makes sense for the trailer design. It’s marketed as a low tongue weight trailer.
    I used both Tow modes and found very little difference between Tow/Haul and Tow+, so I just used Tow+ mostly given the over 5000 lbs weight. The engine braking didn’t seem to be super noticeable, but maybe I was using manual gears too much so it didn’t have to engage that much.
  22. Aug 28, 2023 at 4:17 PM
    #112
    4genRunner
    Southwestern MO
    Last trip a week ago.
    Mattedfred[OP], FI460 and TRD-JP like this.
  23. Aug 28, 2023 at 6:37 PM
    #113
    bluemoon737
    bluemoon737 New Member
    Jeff
    2023 Blueprint Tundra Platinum
    Just picked up the 2500RL. My non-hybrid Platinum with air bags performed very well during our inaugural trip. Don't know that I would want to go with much more load though.
    FI460, 4genRunner and TRD-JP like this.
  24. Aug 28, 2023 at 10:17 PM
    #114
    Adventurer
    Adventurer New Member
    2023 1794 TRD 6.5 Celestial Siver
    Just added brakes to trailer. Coming from a dually Ram/Aisin with exhaust brakes, the Tundra brakes feel sketch to me even with this light load. I have a 33' bumper pull travel trailer, but it stays in OR. when I'm in AZ. for the Winter.
    FI460, 4genRunner and TundraMoe like this.
  25. Aug 29, 2023 at 1:51 PM
    #115
    Jorts
    Jorts New Member
    Jordan
    Raleigh, NC
    2023 MBM Platinum
    I wanted to report back after my first trip towing my Imagine 2670MK. It was a short trip from Raleigh, NC to Holden Beach, NC; about 2.5 hours of completely flat mostly straight highways. Compared to my previous Apex 215RBK, I could absolutely tell it was back there. No shortage of power or brake control, but it just felt heavier (as expected with a much bigger trailer). The Blue Ox WDH did a great job of managing sway, I think only once did I feel the trailer move and it was quickly right back in line. I do have more sag than I would like (I forgot to measure), so I'll probably be looking into Timbren SES bump stops and maybe eventually air bags. I had a little porpoising on some stretches, but overall a pretty consistently smooth ride. I had a similar experience to @TRD-JP, holding right around 2k RPMs and I was in TOW+ the whole time and had cruise control set to the speed limit the majority of the time. I don't think I'd want to take this up any steep mountain runs, but I don't really have any concerns with the short trips we have planned up and down the east coast.
  26. Aug 31, 2023 at 3:56 AM
    #116
    bluemoon737
    Jeff
    Jordan,
    I was very tempted to go with the MK but decided it was just pushing it a bit too much. The rear air bags on my Platnium are great so I suspect you would be happy with getting a set.
    Jorts likes this.
  27. Aug 31, 2023 at 7:52 AM
    #117
    Jorts
    Jorts New Member
    Jordan
    Raleigh, NC
    2023 MBM Platinum
    Yea, we probably are pushing it numbers-wise, you'd never know driving it though. Air-bags are definitely on the list, I wish I would have gotten them from the start but none of the Platinums near me had them.
  28. Jan 5, 2024 at 11:57 AM
    #118
    Spartanfam
    Spartanfam New Member
    West Michigan
    2024 Tundra Limited TRD Off-Road
    Great info! I looked up the 2400 BH… it’s 28’11” long, correct? That’s a big boy.
  29. Jan 8, 2024 at 11:27 AM
    #119
    TRD-JP
    TRD-JP New Member
    Winnipeg, Canada
    Yes, just under 29'. I don't have any regrets and feel quite confident towing. I am pretty OCD and spent a lot of time calibrating my WDH at a CAT scale. With a good WDH that is calibrated properly, you will love this trailer and feel comfortable towing.
    I know others on here push as far as 2800BH, but 2400BH is the max I would ever want to tow. We want the freedom to explore various landscapes.
    Dfrink and Spartanfam[QUOTED] like this.
  30. Jan 8, 2024 at 2:23 PM
    #120
    Mattedfred
    Mattedfred [OP] Toyota Fan Boy Since ‘04
    Ted
    Cambridge, Ontario Canada
    2023 SR5 TRD Sport DC 4X4 in MGM
    TRD Skid Plate/Running Boards, Bison Soft Rollup Tonneau, Thule Canoe Rack, Bedmat, Tailgate Black Insert Badge, Northwest Seat Covers Neoprene Custom Fit Front Row Seat Covers. Tailgate Mat
    I totally forgot that I started this thread then I never ended up posting what we tow after we got our 2023.
    FI460, 22whatwedo, TOYOTARIG and 2 others like this.
