what do you do to protect new engine / compartment
Discussion in 'Detailing' started by Nightshade01, Apr 7, 2021.
  1. Apr 7, 2021 at 10:09 AM
    Nightshade01
    Nightshade01 [OP] New Member
    2021 Tundra Crewmax/ Nightshade
    newbie here with a new truck..trying to be proactive .. what is the best way to keep engine and compartment clean and shiny..do you have to use special products ..or just wax..or what ?
  2. Apr 8, 2021 at 8:23 AM
    briarpatch
    briarpatch New Member
    Are you speaking of the plastic under the hood?
  3. Apr 8, 2021 at 8:33 AM
    RdKing
    RdKing Not A Roll Model
    Rich
    Eastern Seaboard
    2019 Tundra Platinum 3R3 / Barcelona Red
    Roadtunes By: Taylor's Audio/Tech12Volts Alma GA. JBL Complete System
    I just use a bucket, sponge and some Simple Green Cleaner under my hood when I do,
  4. Apr 8, 2021 at 8:36 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    You can use some Perl or a similar product on your plastic engine parts. Recommend applying it with a brush. Concentrated or diluted will work just fine. No more than 5 to 1.
  5. Apr 8, 2021 at 9:23 AM
    Nightshade01
    Basicly everywhere under hood..its clean now ..should i be putting a protectant to keep it clean ..clean on a reg basis..??
  6. Apr 8, 2021 at 9:27 AM
    RdKing
    Rich
    Eastern Seaboard
    Nightshade01,
    that is a personal preference, like if you appreciate the look of 'shiny amour-all' appearance.
    I clean under mine if Im under there for washer fluid or maintenance time.
  7. Apr 8, 2021 at 9:29 AM
    Convertedman
    Convertedman New Member
    Scotty
    Cumming, Ga
    2021 CM 4 wheeler Limited Cavalry Blue
    6in Ready lift, Toyo 35/12.50/20
    following this. I know on the chevelle I had once upon a time, I used degreaser if it got too bad. most of the time just a pressure washer. kind of afraid to hose down the engine compartment on my truck.
  8. Apr 8, 2021 at 9:35 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Just use some dawn detergent and wash it when it is dirty. Degreaser if needed at times. Rinse with soft spray with hose and after run the engine with the hood open for 15 min or so to help dry everything. If you want to get crazy you can certainly wax the painted parts under the hood and you can use cerakote on the plastic parts to keep them looking brand new for a long time. Nothing difficult or expensive, just some of your time.
    Nightshade01[OP] likes this.
  9. Apr 16, 2021 at 12:12 AM
    reimord
    reimord New Member
    I use Meg's hyper dressing to add a nice shine.
  10. Apr 27, 2021 at 3:40 PM
    Rocko9999
    Rocko9999 New Member
    Protectant attracts dust. I hose my engine compartment off about 3-4x per year.
