Westscott lift- Lca bolt not lining up
Discussion in 'Suspension' started by cctxquicksand, Feb 23, 2021.
  1. Feb 23, 2021 at 5:09 PM
    cctxquicksand
    cctxquicksand [OP] IG - TRDistheWrd
    Anyone got any tips on this? This kit is kicking my ass today. 5 hours on one side ( 1/3 of that looking for right size tools :mad:)
    Gotten to reassembly part and now the shock is not lining up with the lca. I have removed the skid plate and loosened the lca so it swings freely but it seems the shock is pulling out further than it was prior. Not wanting to put a ton of pressure on the shock itself
    jeremyd likes this.
  2. Feb 23, 2021 at 5:11 PM
    cctxquicksand
  3. Feb 23, 2021 at 5:12 PM
    Mr Badwrench
    Mr Badwrench New Member
    Do have a picture?
    The LCA is going to be tough to line up. Get a pry bar and pull down on the UCA, it will take some force... if I am envisioning what you are saying.
    I have had to bull-pin struts to get them on without damaging the strut mount.
    cctxquicksand[OP] likes this.
  4. Feb 23, 2021 at 5:18 PM
    cctxquicksand
  5. Feb 23, 2021 at 6:10 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    You did all the hard work already: loosened LCA, disconnected the sway bar, lower ball joint and even the tie rod....It should pop right into the LCA. Did you already tighten any of the 4 nuts on top of coilover? Ive done that before and I couldn’t get the assembly into the bottom, loosened them up and all was good.
    And don’t reverse the coilovers, there is a specific left and right ones.
  6. Feb 23, 2021 at 6:37 PM
    cctxquicksand
    Got it guys thanks for the help
    I think I just needed to step away for a bit
    eccracer104 likes this.
  7. Feb 23, 2021 at 6:41 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You didn’t accidentally pull out the cv right?
    Edit i refreshed the page! You made it!
