Weight rating for bed anchors?
Discussion in 'Towing & Hauling' started by miketundra4411, Oct 22, 2019.
  1. Oct 22, 2019 at 7:40 PM
    miketundra4411
    miketundra4411 [OP] New Member
    mike
    2019 tundra
    anyone know weight rating for bed anchors.
    Pinay and OR18TRD like this.
  2. Oct 22, 2019 at 8:12 PM
    Welcome from NY.
    Hopefully someone will chime in with the answer.
  3. Oct 22, 2019 at 8:57 PM
    BB Stacker
    BB Stacker New Member
    So. Cal
    2016 White 1794 TRD 4X4
    Sway Bar, TRD Catback Exhaust, Morimoto LED fog lamps, running boards, paracord wrapped oh-shit handles, Bak-Flip bed cover.
    are those the safe working load for each? or a pair?
    miketundra4411[OP] likes this.
  4. Oct 22, 2019 at 9:35 PM
    miketundra4411
    mike
    2019 tundra
    20191020_145816.jpg hope 440 lbs apiece for the d rings? have this rack with about a 700 lbs wheeler
    OR18TRD likes this.
  5. Oct 23, 2019 at 5:52 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    A 700 lb four wheeler will have a high center of gravity on that rack. Makes me pucker to think of the "loaded" rack overturning. How much does that rack weigh?
    Loads at those cables and D-rings rings will be increased substantially by the overturning moment. If it were me, I would engineer some 2X2 (same as rack?) steel tube braces running from the top of the rack to the stake holes in the top of the bed sides to counteract that overturning moment. They should have bolted ends so they can be installed and tightened AFTER the rack is positioned in the bed. Little bit more trouble to install, heck of a lot safer for everybody. Are you going to DRIVE that 4wheeler up that rack to load it? :D
    If that's not a commercially available rack, that's some dang nice fabrication. :thumbsup:
