Weboost worth it? Or Garmin InReach?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2point5seconds, Jul 13, 2022.
  1. Jul 13, 2022 at 9:42 AM
    2point5seconds
    2point5seconds [OP] Wish I didn't have so much money
    Sensei
    Nor Cal
    2019 Tundra SR5 TRD 4WD Double Cab
    Icon Stage 9 lift, 700 pound rated Eibach spring, Sumo Springs (rear), RCI engine skid plate. RCI Lower Control Arm Skid Plates, RCI Transmission Skid Plate, RCI Cat Guards, Rago dash plate. RAM phone holder. Bed rails. Tint. 17x8 Icon Rebound wheels. 315/70/r17 Falken Wildpeaks. AAC Trigger 6 Shooter, midland MTX-115 radio, Chassis Unlimited front bumper, OLB Bar light and ditch lights, Baja Fog lights, Smittybilt winch, Husky floor liners, bed rail, Cali Raised Bed Stiffeners, driver's side grab handle, Wheeler's Offroad front bump stops, Decked Tool Box
    2019 Tundra TRD SR5 5.7l 4WD DC
    I've been looking at the WeBoost Reach OTR. I've also been reading some of the posts on this site and others. Watching Youtube videos on reviews of the WeBoost. Alot of times people are talking about using Data to get online to work. I haven't seen anyone talk about using the WeBoost to make calls. Is the WeBoost a good investment if you're working remotely and need Data?
    But I'm not sure if these individuals are going to the same environment I usually go to. I'm usually in the middle of nowhere with mountains everywhere. I'm pretty sure that cell phone coverage needs a line of sight to grab the connection. So, if I'm in a valley and the cell phone tower is being blocked, I may not get connection. Someone in a thread was saying they live near Denver and it didn't work when they go into the mountains.
    Anyone use the WeBoost and have luck with being in a environment with Mountains? I know there's times that there will not be a connection, no matter what. Just weighing what I should get. Because it's not cheap. LOL
    Looking at the Garmin InReach 2. I know there's a subscription, but I'd mostly be using it for Emergencies. This is also not cheap. LOL.
    Looking for reviews about each of these items worked for you. Thanks!
  2. Jul 13, 2022 at 9:52 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I don't know what set up you are using, but some peeps I know that are in Northern Ontario which is about as middle of nowhere as it gets has good luck with Starlink RV.
    https://www.starlink.com/rv
  3. Jul 13, 2022 at 9:57 AM
    2point5seconds
    Sensei
    Nor Cal
    Thanks! I'll look into this.
  4. Jul 13, 2022 at 10:16 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    For the price of a drive OTR you might as well pony up for starlink. People are getting quite fast speeds.
    if you YouTube Mav, he has a setup. Says he gets 300up and down which is insane.
    2point5seconds[OP] likes this.
  5. Jul 13, 2022 at 10:16 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    WeBoost won't help when there isn't a signal, but it help when there's a patchy signal. I put one in my work pickup last winter while doing work on the dams in the Cascade Mountains. You could sometimes get a call out if you stood in a certain spot, balanced on one foot, and held your breath. With the WeBoost Fleet (I drilled an NMO antenna into the roof) I could easily make calls in my pickup and even in my trailer next to the truck, when it was still powered on. It worked good enough I'm considering one for my personal truck.
    That said, if there's no signal, then you need a satellite option.
  6. Jul 13, 2022 at 10:23 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Starlink is where its at from people I know that have it. I'll be doing that and a Garmin InReach
