Weak sounding start up?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Adams awesome screen name, Jun 15, 2016.
  1. Jun 15, 2016 at 3:08 PM
    Adams awesome screen name [OP] New Member
    Hi everyone,
    New to this forum, but definitely not new to Toyota tundras. Recently picked up a 2016 CM. Prior i had a 2014 and a 2012 DC, all with the 5.7. So i feel fairly confident when i say, i know what these engines sound like when the start.
    Which brings me to my concern. My 2016 has maybe 2500 miles on it, and probably since 700 miles in, on a cold start (first thing in the morning) it seems very weak when it starts- like it sputters to start. Almost as if its misfiring? But it never throws a code and it does always start, idle, and drive fine. Its only on cold start. After its warmed up no issue, normal start.
    Any thoughts? Any one else experience this? Does this warrant a trip to the dealer?
    Any thoughts would be appreciated.
  2. Jun 15, 2016 at 3:40 PM
    Mike Tread lightly.
    south carolina
    Take it to the dealer it's under warranty.. could be a bad cell on the battery going out.
  3. Jun 15, 2016 at 4:01 PM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    My suggestion is to use your cellphone and film your condition during these cold starts. If what you say is happening only during cold starts the dealer might not be able to replicate your conditions without letting your truck sit around to cool off. (I hate when the shops say they can't replicate the issue). I don't know if there's a simple battery test they can perform to check for a bad cell, but hopefully that's all it is.
    NewImprovedRon likes this.
  4. Jun 15, 2016 at 4:05 PM
    Mike Tread lightly.
    south carolina
    Any auto parts store has a battery checker to check for bad cells. They do it for free.
  5. Jun 15, 2016 at 5:47 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Sometimes when I start mine it will start, then go to a low RPM for a two or three seconds and then the RPM's will jump back up. Never thought to look at the RPMs while it's doing it but it only does it about 1 out of 20 starts. Doesn't sound like what you are experiencing. Been meaning to ask on here if anyone else's does it? Maybe @LOTSOFTOYS knows?
    nkinney04 and PermaFrostTRD like this.
  6. Jun 15, 2016 at 5:58 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Haven't really heard of this concern. Might need the battery tested... if your worried about the dealer not duplicating it, drop the truck off. Leave it over night and show up in the morning. Start it up in front of the tech and see if it does it. That takes all your mystery out of it. Can't tell u how many times customers start their own car in front of us, and it doesn't do a damn thing. They get so pissed, but atleast it's not at me. They are frustrated with their car... but they believe us then that we could not duplicate it.
    Just to give you the other angle at the equation
    T-Rex266 likes this.
  7. Feb 11, 2018 at 1:30 PM
    PranRai
    PranRai New Member
    Pran
    2014 !974 Crew Tundra
    None
    @LOTSOFTOYS @Mike Battery died, replaced it and when we started it back up it starts up fine, no problems but the engine note is quite weak even on a cold start, its like it lost a cylinder it seems weak. Then it idles fine and runs completely fine, what could be the problem.
    Eclipsed & Floating likes this.
  8. Feb 11, 2018 at 2:50 PM
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    Flex fuel problems. Mine does the same thing on cold starts. Sometimes it drags the starter out and takes a hot minute to actually start.
  9. Feb 11, 2018 at 5:56 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Like others said get battery tested. When my Tacomas have acted this way both needed a new battery. I think average battery life in hot climes is about 3 years.
  10. Feb 11, 2018 at 7:29 PM
    Stock batteries suck ass
    Eclipsed & Floating and GNTundra like this.
  11. Feb 11, 2018 at 7:35 PM
    What batt you run?
  12. Feb 11, 2018 at 7:42 PM
  13. Feb 11, 2018 at 7:42 PM
    Where are they sold?
  14. Feb 11, 2018 at 7:54 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    What are you referring to? Are you using flex fuel or are you saying it is because its a FFE truck?
    Mine is FFE but I don't use that stuff; my trucks starts just fine even in single digits.
  15. Feb 11, 2018 at 8:03 PM
    Probably Amazon. I called a buddy who had one on the shelf.
  16. Feb 11, 2018 at 8:04 PM
    Thanks!
  17. Feb 12, 2018 at 12:32 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    My son got one at 4WheelParts...
  18. Feb 12, 2018 at 6:50 AM
    Berettafan
    Berettafan New Member
    2017 CM
    once in a very great while mine will do this too! hasn't happened enough for me to figure out why.
  19. Feb 12, 2018 at 6:52 AM
    Berettafan
    2017 CM
    I wouldn't support this recommendation. Read deep into battery tech/reputations/longevity a couple years ago when I was worried about power problems in a Suburban. The Odyssey batteries were generally considered overpriced AND underperforming.
  20. Feb 12, 2018 at 7:06 AM
    What do you run?
  21. Feb 12, 2018 at 7:09 AM
    Berettafan
    2017 CM
    Factory battery works 100% fine for me. Had temps down to single digits already this year and zero troubles.
  22. Feb 12, 2018 at 3:20 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    I installed the X2 POWER AGM 27F from Batteries Plus which is a Northstar battery. My truck actually sounds different when starting (stronger?). I wanted an AGM battery due to the deep cycles it goes through when sitting for extended periods.
  23. Feb 12, 2018 at 3:59 PM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    where you get that tie down??
  24. Feb 12, 2018 at 5:06 PM
    @Coupe makes them
  25. Feb 14, 2018 at 10:15 AM
    cd121082
    cd121082 New Member
    chris
    Washington State
    2016 Silver Tundra TRD OffRoad
    none yet
    4wheel parts can get it for you.
  26. Feb 14, 2018 at 1:26 PM
    nodak67
    nodak67 New Member
    JR
    I don't have any issues with our 5.7L FFE using 87 octane w/ ethanol in -20F temps. starts right up in 1-2 secs tops.
  27. Feb 14, 2018 at 3:27 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I know this is late to the game, but I have had something similar happening to me. My truck (reg gas) has actually stalled out 4-5 times upon starting, with no consistency of when or why. The dealer looked at it tested the battery, which was fine and told me they would need the truck for an indefinite time so they could put it through a series of tests. I have not done this because that is another way of saying "we have no clue". The truck has 9k miles, and has done it randomly since new. It cranks no problem, revs up to start, then as the rpms drop, they just continue to drop until sputtering out and stalling. It starts right up again, and never has pulled a 2 in a row stall. I told the dealership they can test the truck, but I need a Tundra for a loner... They haven't responded yet but I have my 10k service coming up and will address it then.
  28. Feb 28, 2018 at 7:42 AM
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    I don’t use flex fuel at all. I’ve heard it’s the FFE engines/ computer acting up when it’s cold out. Could be the battery tho. I haven’t changed mine out yet
  29. Feb 28, 2018 at 8:53 AM
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    This place. I have it on both Tundras and my boat too.2018-02-24 13.48.50.jpg
  30. Feb 28, 2018 at 6:13 PM
    RW-3
    RW-3 May the Mods be with you
    Rob
    16 Black TRD CM 4x4
    Lights: 2018 OEM Black Chrome LED’s Morimoto XB Fogs Interior LED upgrade - VLED’s LED reverse / cargo - VLED’s Footwell lights, vanity lights, break lights, rear turn signals, 3rd break light - All VLED’s 30” Rough Country light bar hidden in bumper w/ Rago Fab Brackets Matt Gecko LED bed lights (red & white) and hood lights Exterior: Truxedo Lo Pro QT WeatherTech in-channel window deflectors Interior: Husky X-Act Contour front & rear Front, back and rear windows all tinted 10% Ceramic Heat Film on Windshield 70% OCD console organizer OCD console tray TRD 4x4 inserts on Husky mats by Achuop Tacoma TRD Pro shift knob with TRD leather boot AJT Design vent ring trim - chrome delete Center console wireless charger Drivers side grab handle Performance: Dirty Deeds BA Muffler 12” Budget Standard System TRD Rear Sway Bar AFE Pro Dry S Air Filter Bilstein 6112 1.9” clip Bilstein 5100 - rear Coachbuilder +1’s Nitto Ridge Grapplers 285/70/18 Audio: Infinity dash speakers Tech12Volts custom center dash speaker Hertz Uno door speakers JL Audio RD 900/5 amp 2 JL Audio 10w-0 v3 10” subs in custom Tech12Volts box Protection: McGuard Tailgate Anti theft lock OEM tailgate lock w/ Dynamat TRD Pro skid plate SNS ARB sensor guards Misc: TRD key fob case AJT Designs Rear diff breather mod Fortin remote start with Car Link CL6 TRD battery bracket by Coupe TRD valve stem caps TRD interior handle inserts by abomb60 (Adam)
    I have this exact issue. Posted about it on here. In the middle of last summer I drove about 100 miles let it sit for an hour, went to crank it and it would turn over rev up and die. Happened about 7 times in a row. About 30 min after that, it was fine again. Fast forward to this winter, it would crank, rpms dip and then It levels off. Or it starts very low and slow almost sluggish and then the rpms level off. Took it to the dealer and the assistant manager immediately said they’ve seen this a lot with the flex fuels. It’s something to do with the alcohol content when using 87 octane. They tested my alcohol levels and guess what???? They were off slightly. Their recommendation was to use 89 octane at least in the winter. I filled up 3 consecutive times with 89 and could only tell a very very slight difference. Not enough to keep me paying the 89 prices.
    I’ve switched to 87 and think they are slightly full of shit. I live in South Carolina where temps don’t get crazy low and this happens in the morning in my garage which is usually between 62 and 70 degrees in the winter. I’d me more inclined to buy this story if it happened when I was starting in 20 degrees and didn’t happen in my 65 degree garage.
