Warn zeon platinum 12 s controller mount location
Discussion in 'Electrical' started by Moeenulhaq, Jul 5, 2021.
  1. Jul 5, 2021 at 7:45 PM
    Moeenulhaq
    Moeenulhaq [OP] New Member
    2020 Tundra TRD Pro
    Wondering where you all mount the controller box for Warn zeon platinum winch. I got a fabfours matrix bumper and there is not enough space to mount the winch with a light bar. Controller has be relocated using relocation kit. Just looking for idea where to mount the Controller... Please share pictures ..
    2020 Tundra TRD Pro
  2. Jul 5, 2021 at 8:23 PM
    Ry24000
    Ry24000 New Member
    Ryan
    Carson, WA
    2019 Tundra SR5 TRD offroad Quicksand
    Debadge, ARE z series top, Ironman Foam cell pro 3" lift, SPC UCA's, ICON vector 5 & Toyo ATIII 285 75R 17, Warn 9.5XP mounted in a Victory Blitz bumper. GTR 1000LM+XTR LP Reverse Light System
    I relocated the driver side horn, made a bracket and used the horn bolt spot to mount my controller.
  3. Jul 6, 2021 at 4:59 AM
    Moeenulhaq
    2020 Tundra TRD Pro
    Do you have a picture?
  4. Jul 6, 2021 at 5:09 AM
    Ry24000
    Ry24000 New Member
    Ryan
    Carson, WA
    Not a very good one. I took a few pictures while I installed my bumper/winch. Now I open the access panel at the top right of the grill to attach my remote.
    You can see the control box with the wires existing to the left.
  5. Jul 6, 2021 at 5:14 AM
    timsp8
    NY
    I have the same bumper but a smittybilt x20 winch. I got a bracket and mounted the control box inside the bumper next to the winch on the passenger side. That way I can still reach it and plug in the remote if I need to. That winch had the same clearance issue with a light bar. I can take a pic when I get home if you want.
  6. Jul 6, 2021 at 1:53 PM
    Moeenulhaq
    2020 Tundra TRD Pro
    Thanks , would love to see a picture.
  7. Jul 6, 2021 at 1:53 PM
    Moeenulhaq
    2020 Tundra TRD Pro
    Thanks for sharing
  8. Jul 7, 2021 at 12:05 PM
    Moeenulhaq
    2020 Tundra TRD Pro
  9. Jul 7, 2021 at 12:20 PM
    Ry24000
    Ry24000 New Member
    Ryan
    Carson, WA
    What are your thoughts on location? Do you have any ideas or do you just want to see what others have done?
    I pondered a controller location or quite some time. Was considering the area to the front of the battery. There's kind of a little space where you can locate the contactor without the box. I considered that area but I wanted to keep the contactor enclosed. I could have kept the contactor mounted to the winch, but on my setup the winch is low to the ground and I wanted to keep at least some of the terminations above possible water and mud. The left side of the radiator has some space, but may require bracket fabrication. The firewall looks good ,but that is a lot of wire running around.
    28 years of electrical experience basically told me that there was no "great" place to mount the contactor pack in the Tundra without bracket fabrication and possibly moving a few things around in the engine compartment!
  10. Jul 7, 2021 at 1:09 PM
    Moeenulhaq
    2020 Tundra TRD Pro
    Thanks, no ideas yet but wanted to see where others may have placed it.
  11. Jul 7, 2021 at 1:33 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I have a smittybilt winch, controller was relocatable from top to side. I made a little bracket and got longer cables and mounted it in the engine compartment to the left of radiator. The control box can be mounted anywhere with longer cables. The clutch lever I left alone as my bumper had an acces opening for it. 6472E09A-E324-4199-B81C-00FDFED9A902.jpg
  12. Jul 7, 2021 at 6:53 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I’ve got the Rago twin ARB compressor mount where I mounted the ARB relocation pack along with a contactor for a kill switch.
