Wanting to swap out interior yellow lights for white ??
Discussion in 'Lighting' started by Mejarrett9, Jun 16, 2017.
  1. Jun 16, 2017 at 7:14 AM
    Mejarrett9
    Mejarrett9 [OP] New Member
    Charlotte, NC
    16 Crewmax 1794 super white
    More on the way
    Hey guys I know that a number of you have swapped out the stock interior lights for some brighter white LED lights. I don't feel like reinventing the wheel and would prefer to lean on someone else who has already done the research.
    1. Which company will make a good LED light for this purpose? Where is the best place to purchase them from?
    2. Does anyone have any write ups or videos of how to pop off the light covers without breaking them?
  2. Jun 16, 2017 at 7:18 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Some guys have had good luck with LEDs inside, others ended up shorting things out and/or burning through fuses. I left mine as is because I didn't want the headaches, so I can't be of much help.
    I'm sure the guys will chime in soon and get the you complete scoop.
    NewImprovedRon and Law323 like this.
  3. Jun 16, 2017 at 7:25 AM
    Primo
    Primo White Tundra
    Primo
    San Antonio, Texas
    2016 SR Double Cab
    Level kit and TRD Pro Grill Installed.
    https://www.amazon.com/gp/product/B0186P1MUW/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
    Actually its pretty easy to pop up the light covers. In order not to break the lights, I used plastic gloves in order to pry out the lights from the socket in install them. I installed 10 lights. four in the overhead, two in the front doors, two in the back doors, two for the rear license plates. Took me about 30 mins.
    Watch out for the overhead compartment. If you push too much or struggle, you might push the switch out of the socket and then you would have to remove the whole overhead compartment. if your fingers are too big, use needle point pliers with electrical tape on the ends to remove them.
  4. Jun 16, 2017 at 7:26 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Headlight revolution for almost a year, no provlems whatsoever
  5. Jun 16, 2017 at 7:34 AM
    T_dublecab14
    T_dublecab14 New Member
    RC
    2014 doublecab 4x4
    TRD
    one of the best mods I've done. I got mine online Amazon as well.
  6. Jun 16, 2017 at 9:28 AM
    AxelsHumanDad
    AxelsHumanDad I am Groot
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
  7. Jun 16, 2017 at 11:29 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
  8. Jun 17, 2017 at 1:25 AM
    trainracer
    trainracer New Member
  9. Aug 10, 2017 at 2:18 PM
    BenAZ
    BenAZ New Member
    Ben
    Prescott Valley, AZ
    2007 Slate Metallic Double Cab
  10. Aug 10, 2017 at 2:32 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    5100s all around, 295-70-18 Defenders, 1.25 Spidertrax spacers, BD reverse lights, de-badged, interior LEDs, footwell LEDs, reverse LEDs, ARE cap, front receiver hitch for cooler holder, cooler holder/rod rack, backup camera, Kenwood HU, Westin nerf bars, Husky floor liners, folding rear seats, remote battery posts, plastidip grill chrome, Powder coat bumpers.
    Everything he said. I've had these for more than 3 years and never a problem.
  11. Aug 10, 2017 at 7:08 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    I switched all of mine out to Sylvania Zevo LED's a year ago and haven't had any issues. I swapped the cargo and reverse lamps at the same time for Zevos as well. The only bulb that's different is the footwell bulb, #74 I believe, ordered from SuperBrightLED's.
  12. Aug 10, 2017 at 7:15 PM
    Headlight Revolution
  13. Aug 10, 2017 at 7:39 PM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    Headlight Revolution is the way to go. I ordered some generic ones off Amazon for my 2014 in red (allows you to keep your night vision and see outside) but they were so dim, you couldn't see inside. I got the Headlight Revolution kit for my 2017 in red and they perform as advertised... check out the video trainracer posted earlier in the thread.. gives step by step instructions.., piece of cake!
  14. Aug 10, 2017 at 7:57 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I've had bad luck w Amazon no name brand leds.
    In order that I prefer.
    1. Vleds.com
    2. Superbrightleds.com
    Tundra Fan likes this.
  15. Aug 12, 2017 at 5:08 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Can't go wrong with either of these companies.
    BlueBottle[QUOTED] likes this.
  16. Aug 16, 2017 at 11:48 PM
    Fiestee23
    Fiestee23 A CHICK'S TRUCK
    SOCAL
    White sr5 4wd
    how do you take off the front uppers? I did the back seat uppers but I'm afraid to break the front ones
  17. Aug 17, 2017 at 9:36 AM
    BenAZ
    BenAZ New Member
    Ben
    Prescott Valley, AZ
    See the video posted above. It has ALL of the interior lights, event the vanity lights.
    Fiestee23[QUOTED] likes this.
