want to convert tundra bed cargo light to camper shell 3rd brake light
Discussion in '2.5 Gen Tundras (2014-2021)' started by SiberianTundra, Apr 18, 2019.
  1. Apr 18, 2019 at 8:28 AM
    SiberianTundra
    SiberianTundra [OP] I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    Just wondering if there are any options to use my cargo bed lighting on my camper 3rd brake light.
  2. Apr 18, 2019 at 8:53 AM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    To have it always on? If you want to use it as a brake light, just run a wire down to one of the tail lights.
    Black Wolf likes this.
  3. Apr 18, 2019 at 9:13 AM
    SiberianTundra
    Greg
    War Machine
    I actually want it to turn on with the switch in my cab. Also Auto on. Just like 2018 cargo lights behave. But since they are now covered with my camper shell. No use out of that light and the switch.
    See cargo light just useless now. But since I am wired might as well extend it to the back of the camper shell. I already got the 3rd brake light wired to brake lights.
  4. Apr 18, 2019 at 2:50 PM
    apwisher
    apwisher New Member
    Everett, WA
    ah, I see. I misunderstood. IIRC, the wires to the high mounted cargo light go through the headliner. I was thinking about doing the same thing, but didn't want to pull the headliner to get at them. I thought that if I connected the wire to the fuse under the dash for the cargo lighting it would work, but it does not. it is always on, so there must be some other relay controlling it. In the end I just ran a fused wire to the battery and use the switch in my canopy, I may revisit it later if I find new info.
    SiberianTundra[OP] likes this.
  5. Apr 18, 2019 at 2:56 PM
    SiberianTundra
    Greg
    War Machine
    Yes I would love to have the switch turn on light in the Camper or outside of it. Still trying to figure it out. Most likely will pull down the headliner from the back to get to the wire. Perhaps find a diagram.
  6. Apr 18, 2019 at 4:42 PM
    apwisher
    apwisher New Member
    Everett, WA
    I did find --this-- maybe it will point you in the right direction.
  7. Apr 18, 2019 at 5:32 PM
    SiberianTundra
    Greg
    War Machine
    that is exactly what I needed! Thank you man!
  8. Apr 19, 2019 at 8:14 AM
    apwisher
    apwisher New Member
    Everett, WA
    I would just check it before you get too far along, and see if it is always hot, or switched.
  9. Sep 12, 2019 at 2:26 PM
    SiberianTundra
    Greg
    War Machine
    OK ordered lights and will finally do this. Using white LED flood lights for rear.
  10. Dec 22, 2021 at 9:39 PM
    dybang
    dybang New Member
    2005 Black DCB Tundra TRD
    Hi Siberian Tundra, wondering if you ever got that cargo switch hooked up to an LED in your topper. I was thinking something similar so please share if you have any info. Thank You!
    Nickels9 likes this.
