VSC trouble after 3 - 1 lift
Discussion in 'Suspension' started by birdslayer, Nov 13, 2017.
  1. Nov 13, 2017 at 4:25 AM
    birdslayer
    birdslayer [OP] New Member
    MARYLAND
    2018 DC SILVER SKY LIMITED TRD
    Not yet but scratches and dents are sure to come 3/1 TOYTEC LIFT, SPC UCA'S, EIBACH SHOCKS, EXTANG TRI FOLD TONNEAU COVER
    After installing a 3/1 leveling kit, with uca's I now have my PCS, slip indicator, radar cruise control malfunction and trailer brake error all staring at me. HELP! 2018 d/c
  2. Nov 13, 2017 at 5:54 AM
    Are you sure the ebrake and or abs cable weren’t stripped during install?
    831Tun likes this.
  3. Nov 13, 2017 at 7:42 AM
    birdslayer
    MARYLAND
    Cables are all good. All the warnings disappear with a key cycle but show back up after 15 - 20 miles.
  4. Nov 13, 2017 at 8:46 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    You probably need a zero point calibration done. Toyota dealer can do it. After I lifted it myself, I took it to big o tires because the alignment dude was a Toyota guy and new how to do it. There are threads on the forum on how to do it as well.
    BlueBottle, Quebec and TheBeast like this.
  5. Nov 13, 2017 at 8:48 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    We did a 3/1 on my 18 with no issues.....I did not do UCA's though.....It was done at a Toyota Dealership...wonder if they would have done a zero point as part of the install?
  6. Nov 13, 2017 at 8:51 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Most likely. The traction control system on our trucks are very sensitive. If you don’t reset the parameters with the new lift, the computer senses that something is different and causes all sorts of issues. I would look up the procedure myself but I’m at work. I know there’s a thread on it though.
    Coachbuilder1 likes this.
  7. Nov 13, 2017 at 9:11 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    Gotcha...they must have as I have had zero issues with the lift.
  8. Nov 13, 2017 at 9:38 AM
    birdslayer
    MARYLAND
    Going to have a zero point done on wed., will let you know the results. Thanks
  9. Nov 13, 2017 at 2:35 PM
    TheBeast The Beach
    +1 on zero point calibration
  10. Nov 13, 2017 at 4:27 PM
    Quebec
    Quebec New Member
    I'm not sure if it's been mentioned in this thread yet, but its probably ZPC.
  11. Nov 17, 2017 at 8:47 AM
    birdslayer
    MARYLAND
    Had the zero point calibration done by the dealer. Drove 5 miles and it happened again. took it back and they are trying more stuff now. Hope they get it , leaving today on a week long hunting trip.
    kenomouth64 likes this.
  12. Nov 17, 2017 at 11:29 AM
    nowayout
    nowayout New Member
    NY
    17 CM
    There was someone else here that had this issue and could never correct it even after going to the dealer. I think he ended up removing the lift. Try to do a search. Ill see what I can find also.
    Edit: it was @Joeshaker
  13. Nov 20, 2017 at 9:01 PM
    Quebec
    Quebec New Member
    Stretched ABS Wire?
  14. Nov 27, 2017 at 7:38 AM
    birdslayer
    MARYLAND
    After the dealer recalibrated the YAW sensor I drove 95 miles then it started up again. Now it comes on at no certain amount of miles, 5 - 30. Sucks when it constantly flashes on your dash.
  15. Nov 27, 2017 at 7:45 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I'm guessing it's something else. A really close inspection of ABS sensors and wires might help. I lifted my '16, changed UCA's (twice) and haven't had any issues.
  16. Nov 27, 2017 at 9:26 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    We lifted my 18 with no issues....I'm guessing its something else as well....
    831Tun[QUOTED] likes this.
  17. Dec 5, 2017 at 9:00 AM
    birdslayer
    MARYLAND
    Just received a call from my dealer (truck not what you were thinking). they talked to engineers in San Antonio and were told that a componant on the air bag system is bad. The part that needs to be replaced is on a back order status. Apparently the a lot of the early 2018 model is having this problem.
    dcsleeper408 likes this.
  18. Dec 5, 2017 at 9:30 AM
    TheBeast The Beach
    good to know.
  19. Dec 5, 2017 at 11:25 AM
    birdslayer
    MARYLAND
    I was told it is the SRS computer. It gets information from the YAW sensor. The computer itself is failing.
  20. Dec 11, 2017 at 8:31 PM
    Liferider98
    Liferider98 New Member
    2018 tundra DC magnetic grey
    Subbed. Looking into about a 2.5 1 lift with uca. But I definitely don’t want any issues with the VSC. Had issues with that on my 2011 tacoma and it was scary ass hell, when the abs would lock up your front wheels when going around a corner!
  21. Dec 12, 2017 at 6:58 AM
    nowayout
    nowayout New Member
    NY
    17 CM
  22. Dec 30, 2017 at 2:29 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Saw this thread and had to sign up to post. I am currently going through this issue with mine as well. 3/2 level, on a TRD 4x4. None of this is the issue as a non lifted truck was there as well with the same issues. They did ZPC on as mine as well to no success. Dropped it off yesterday for the second time in a week. I've seen a video on YouTube, where a CHR was having the same issue, minus the trailer brake.
    With all that being said, there has to be an issue with the way they put all the features together in the TSS-P package that would be causing the issue. That's my 2 cents on it and I hope it helps you to know it's more widespread and not just yours.
  23. Dec 30, 2017 at 3:31 AM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    Welcome from CO. The zero point offset alert isn't always triggered when adding a lift but, that being said, when the alert is triggered the ZPC is performed. The problem is that it doesn't always work. The YAW sensor can be shimmed back to level and then redo the ZPC. My .02...
  24. Dec 30, 2017 at 3:41 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    It's happening to vehices without lifts as well. So, I really don't know, and I'm not a mechanic. I do know that they cleared memory and re calibrated mine and it still did it.
  25. Dec 30, 2017 at 3:46 AM
    Aurora CO
    Yeah, in those cases something weird is going on. If the memory is cleared and ZPC and still doesn't work...possibly bad data is being sent to the computer or a computer reflash...maybe......
  26. Dec 30, 2017 at 3:51 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    This guy posted 3 videos on YouTube where they changed all sorts of stuff on his CHR and it' still doing it. I know it's not a Tundra but with same TSS-P system and getting same errors, I'm thinking it's something there. https://youtu.be/pAzHXEm6c4Q
  27. Dec 30, 2017 at 3:57 AM
    Aurora CO
    Hmmm....definitely a possibility for sure. Now I'm kind of glad my 2nd gen doesn't have that nanny. I forgot about the pre-collision sensor on the 3rd gens..
    Larmand[QUOTED] likes this.
  28. Dec 30, 2017 at 5:32 PM
    Jebell4747
    Jebell4747 New Member
    2018 Tundra TSS
    I just ordered a 4” lift. Now I’m scared to even try to install
    It
  29. Jan 1, 2018 at 2:48 PM
    birdslayer
    MARYLAND
    The computer finally came in. It will be replaced on 1/2/18. I will let you know if it takes care of the problem. I would check with your dealer about this.
    Black Wolf likes this.
  30. Jan 1, 2018 at 3:03 PM
    Steve6
    Steve6 New Member
    Tucson
    The follow on video to the one posted above shows the end result. Dealer had it for a month, changed several components without success and finally fixed it by replacing a faulty ABS ECU. I wonder if Toyota puts out tech bulletins or similar to help streamline the diagnosis and repair process at other dealerships.
