Vinyl wrapping bulge and surround
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by havasuTRD, Jul 26, 2020.
  1. Jul 26, 2020 at 5:44 PM
    havasuTRD
    havasuTRD [OP] New Member
    Brett
    2017 Tundra crewmax TRD 4X4
    To those that have had this done, what was the cost? I’m debating on keeping the limited grill I have on my 17’ and vinyl wrapping or buy the 2020 pro grill and bulge. thx guys
  2. Jul 26, 2020 at 6:43 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I did this and the cost was around 80 dollars. I bought a 6x5 piece of vinyl and it was more than enough. Are you going to try for the grille too? I didn’t do the grill but it looks hard.
  3. Jul 26, 2020 at 6:46 PM
    Tundyfundy
    Bay Area, CA
    I also bought a squeegee and exacting knife. I already had a heat gun but didn’t have to use it.
  4. Jul 26, 2020 at 7:35 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    The quotes I got were around a couple hundred bucks. I would’ve gone for it but got a good deal on used OEM color matched bits.
  5. Jul 26, 2020 at 8:44 PM
    Tundyfundy
    Bay Area, CA
    Gotcha, yeah I thought you were going to do it yourself. IM sure having somebody do it would be at least 150 to 200.
  6. Jul 26, 2020 at 8:47 PM
    havasuTRD
    Brett
    I’ve never wrapped vinyl anything before so I would look to the pros first. And then compare costs
  7. Jul 26, 2020 at 8:57 PM
    Tundyfundy
    Bay Area, CA
    For flat pieces similar to the bulge and surround its pretty much as easy as putting on a sticker. When you have to start turning corners and filling depressions it gets a lot harder.
  8. Aug 27, 2020 at 11:13 AM
    TxLock21
    TxLock21 Bought a truck, got bit by the bug.
    I'm about to have my grille wrapped...anyone know how much wrap I need to purchase in order to wrap the grill and hood bulge? TIA
  9. Aug 27, 2020 at 11:25 AM
    tennisfreak
    tennisfreak New Member
    I thought about vinyl but too expensive.
    $10 Black Plastidip did the job pretty darn good for me!
    BravoDeltaRomeo likes this.
  10. Aug 27, 2020 at 1:11 PM
    Tundyfundy
    Bay Area, CA
    Vinyl usually comes on a 60 inch roll so measure the width of your grill and if it’s small enough to be covered by 60” then measure the height and order a piece a few sweet longer than the height. You want to leave yourself some good margins to work with. Also keep in mind the grille is two pieces so you probably should wrap them seperately. Which means height of your grill x2 plus hood bulge. I’m guessing two meters x 60” should be close.
    TxLock21[QUOTED] likes this.
  11. Aug 27, 2020 at 2:50 PM
    TxLock21
    Yeah I’m thinking 5’ X 7’ just to be safe. Thanks!
    Tundyfundy[QUOTED] likes this.
  12. Aug 27, 2020 at 3:45 PM
    Tundyfundy
    Bay Area, CA
    No worries! On the hood bulge you’ll have to place two small pieces on the sides of the recess before wrapping the remainder as the vinyl won’t stretch into that area. FYI
  13. Aug 27, 2020 at 3:48 PM
    Tundyfundy
    Bay Area, CA
    I would make it come over the edge which I didn’t do and once the vinyl shrunk back you could see a small amount of chrome. Got it right on my second try.the under side of the recess takes a small piece as well. For the bulge (after the inserts) I put one piece of vinyl over the whole bulge and then cut a line around the sides and top of my recess to create a flap and that flap will cover the bottom of the recess.
    TxLock21 likes this.
  14. Aug 27, 2020 at 3:51 PM
    Tundyfundy
    Bay Area, CA
    You can see my cut lines and over lap of the insert on the sides here.
  15. Aug 28, 2020 at 8:25 AM
    TxLock21
    Thanks for all the advice and pics! I'm thinking I'm way too meticulous and inexperienced for wrapping so I'm going to order the wrap I want and take it to a shop. I found a local one that will do it for a good price.
  16. Sep 12, 2020 at 3:19 PM
    KENNY
    KENNY New Member
    Try and find some 3m 1080 wrap if you can. It's much easier to wrap with than any others I have used :thumbsup:
  17. Sep 12, 2020 at 3:23 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Nice job on the bulge. I tried to do the fj and spent more time cursing at it.
    Tundyfundy likes this.
  18. Sep 25, 2020 at 10:23 AM
    ac762x39
    ac762x39 New Member
    A.C.
    2015 Tundra
    was going to do the same thing, then hit a deer on the way home.
