Victory4x4 new product prototyping.
Discussion in 'General Tundra Discussion' started by brimy311, Jan 5, 2019.
  1. Jan 11, 2019 at 6:30 AM
    #91
    brimy311
    brimy311 [OP] New Member
    Kalamazoo
    2018 Tundra Platinum
    The top plates are located to be in the place were you would step in and out of the truck.
    In order to make a slider strong enough to hold up the riggers of off-roading, you have to drill holes in the bottom of the frame. Without those lower mounts, the sliders have nothing to keep them from rotating up under heavy force. Now if you want to just use them as a step and nothing crazy, you can skip the drilling. Unfortunately, Toyota didn’t give us any mounting locations under the frame to use.
    As for your bed rack question, we plan to get to that.
    BlueBottle likes this.
  2. Jan 11, 2019 at 6:33 AM
    #92
    brimy311
    Kalamazoo
    Here are the 07-19 Crewmax sliders waiting to be test fit after being built on the new fixture:
  3. Jan 11, 2019 at 6:46 AM
    #93
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Nice, full-length coverage. Can you get some pics of the underside so we can see how they mount and exactly where the main slide rail sits in relation to the rocker panels?
  4. Jan 11, 2019 at 6:48 AM
    #94
    brimy311
    Kalamazoo
    On this gen1 truck or on the gen3?
  5. Jan 11, 2019 at 6:48 AM
    #95
    Sas
    OKC, OK
    Gen 3
  6. Jan 11, 2019 at 6:49 AM
    #96
    brimy311
    Kalamazoo
    I will once we get then finally installed next week. We’ll also have a ton of photos available on our website when they go live.
    Juanjoolio007 and Sas like this.
  7. Jan 11, 2019 at 7:21 AM
    #97
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2018 Tundra Crewmax Platinum
    See Build Thread.
    Subbing as this is my next project and I've been settling in on which slider to go with. (2018 Platinum)
    I live over in Ontario Canada, so the drive to Michigan isn't bad and it will give me a reason to visit a friend also.
    Do you install at the shop for purchases, or is the shop only for fitting and testing? Probably a dumb question but checking over all options.
    Thank you
    Luckydog likes this.
  8. Jan 11, 2019 at 7:43 AM
    #98
    papasmurf
    papasmurf Gun Parts Slinger
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 |Total Chaos LT | King Coils & Bypasses | ADS Bypasses | Demello Sliders | CB +2 Shackles | OME Dakar Leaf springs | 17" Double Standards | BFGKO2 37's |
    Op @brimy311 any thoughts to the diff skid??
    joonbug likes this.
  9. Jan 11, 2019 at 7:47 AM
    #99
    brimy311
    Kalamazoo
    We install our product for customers. That honestly the best way to get the back into Canada ;)
    We’ll mess with making one. It’s on the short list.
    DMG85, Cemented, GodlessPro and 4 others like this.
  10. Jan 11, 2019 at 7:49 AM
    #100
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Makes sense. Looks like you know what you are doing there! What type of bolts will be under there though? I cringe every time I see bolt heads under waiting to be sheered off. Is there space in our trucks to use carriage bolts and nuts inside the frame?
    Sas, InfernoPRO and GodlessPro like this.
  11. Jan 11, 2019 at 7:51 AM
    #101
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    sweet you can put me on the top of the list to order one asap
    831Tun, joonbug and GodlessPro like this.
  12. Jan 11, 2019 at 8:24 AM
    #102
    Krezz
    Kevin
    See Build Thread.
    My thinking also - it's how my bed rack and RTT found its way back home lol.
    Highly interested once you've priced those sliders out. Signed up for your news letter and I loved the install video for the Tacoma bumper!
    Great job
    brimy311 [OP] likes this.
  13. Jan 11, 2019 at 8:30 AM
    #103
    GodlessPro
    GodlessPro Two Timing BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    Thanks for giving us hope for a diff skid Brian. I'll be right below Bruce on the list. Between SGU and BASTRDS, we could probably take the complete first run.
    831Tun, Cemented, TheBeast and 3 others like this.
  14. Jan 11, 2019 at 8:36 AM
    #104
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    hes not wrong, thats like 15-20 guys between the two groups!
  15. Jan 11, 2019 at 9:13 AM
    #105
    InfernoPRO
    InfernoPRO New Member
    Scott
    Sacramento
    2015 Inferno TRD PRO
    Just waiting for the signup list!:D
    papasmurf and GodlessPro like this.
  16. Jan 11, 2019 at 9:14 AM
    #106
    3mxdivr
    3mxdivr New Member
    NorCal
    2018 Limited Crewmax TRD Off Road
    Do I sense a group buy price?...... ;)
    papasmurf likes this.
  17. Jan 11, 2019 at 9:20 AM
    #107
    brimy311
    Kalamazoo
    We don’t love to use button head bolts in a skid side location, after a bunch of hard hits, you won’t be able to get an Allen wrench in there to removed them in the future.
    Two issues with carriage bolts;
    1 - you would have to mark, remove, drill and reinstall the slider. Where you can just bolt the slider on and drill with a regular bolt.
    2 - finding carriage bolts rated higher than grade 2 is tough. In this application, it’s all sheer force on these bolts. So grade matters here.
    We are using 1/2” hex head bolts. They won’t budge on impact. Besides, the bottom of the tundra frame is covered in rivets anyways :shrug:
  18. Jan 11, 2019 at 9:46 AM
    #108
    fliberto38
    fliberto38 New Member
    Ft. Worth, Texas
    2019 Silver Tundra TSS Off-Road
    Toytec/Radflo coil overs, SPC UCAs, Diff drop, Toytec/Deaver AAL, Toytec Boss rear shocks
    For those asking about a metal bumper that works with BSM. This seems to not be possible without mounting the sensor on the outside of the bumper. The metal of the bumper will trigger the sensor so the truck will think there is a vehicle in your blind spot at all times. This is why Toyota uses painted plastic rear bumpers on platinum and limited models instead of chrome front and rear.
  19. Jan 11, 2019 at 9:53 AM
    #109
    3mxdivr
    3mxdivr New Member
    NorCal
    fyi the rear bumper is a Plastic fascia in front of a steel bumper, so it is steel.....
  20. Jan 11, 2019 at 10:04 AM
    #110
    fliberto38
    Ft. Worth, Texas
    The sensor mounts on the outside of the steel structure beneath. So no steel between the sensor and plastic outer cover.
  21. Jan 11, 2019 at 1:52 PM
    #111
    Boerseun
    Boerseun Super White
    Ferdie
    Sarasota Florida
    2018 White TRD Sport CrewMax 4x4
    Not where the BSM sensors are; they do not have steel in front of them; they sit in a open pocket with only the plastic cover in front of them.
  22. Jan 11, 2019 at 1:57 PM
    #112
    Boerseun
    Ferdie
    Sarasota Florida
    I am sure if someone wants to, they can fab up a steel bumper with an opening for the sensor, and have a plastic insert to cover it. My understanding is though that it might need calibration to work right, and nobody wants to take on the liability - if it does not work right (or even if it does work and there is operator error) the fab shop can be blamed for the accident in today's crazy litigious world.
    fliberto38 likes this.
  23. Jan 11, 2019 at 2:34 PM
    #113
    3mxdivr
    3mxdivr New Member
    NorCal
    My bad. I thought you meant that it was pure plastic.
  24. Jan 12, 2019 at 5:17 AM
    #114
    FirstGenVol
    FirstGenVol Many ideas, few dollars
    Erik
    Knoxville, TN
    2002 SR5 4x4 AC
    Any plans to offer these for a Gen1 Access Cab?
  25. Jan 12, 2019 at 6:04 AM
    #115
    brimy311
    Kalamazoo
    We would have to find someone that has one and could let us use it for a week.
    FirstGenVol likes this.
  26. Jan 12, 2019 at 8:34 AM
    #116
    831Tun
    831Tun IMA BasTRD
    Warren
    Santa Cruz
    '16 CM limited
    ADS C/O w/clickers, ADS bypass rear, Icon UCAs, Toytech shackles, chrome delete, Pro grille, TRD dual exhaust dumped, de-badged, black LED tail lights. BHLM w/projectors, 295 70 18 Cooper STT pro on stock rims w/1.25" Spider Tracks. N_Fab bumper w/Baja Design fogs and ditch lights, 13" antenna x, RCI skid, All Pro sliders, ARB compressor
    I'll be 3rd on the diff skid list.
    papasmurf, DMG85, GodlessPro and 2 others like this.
  27. Jan 12, 2019 at 8:36 AM
    #117
    Jimes
    Jimes New Member
    2015 toyota tundra trd pro
    stock for now
    I’ll be 4th in the diff skid list
  28. Jan 12, 2019 at 10:19 AM
    #118
    DMG85
    DMG85 New Member
    Cincinnati
    2018 CM MGM Tundra TRD Sport
    UnderCover Elite, TRD Exhaust, N-Fab Podium Steps, XPEL PPF, RCI Skid Plate, VLEDS, Krown Rust Protection, SDHQ ABS Guards, POP N’Lock, Front Window Tint, Air Flow Accelerator, Stubby Antenna, A-Pillar Handle, LED Side Step Lights
    5th on the diff skid list.
  29. Jan 14, 2019 at 2:22 PM
    #119
    brimy311
    Kalamazoo
    Picked this up from our local dealer, Metro Toyota. Working on double cab sliders!
  30. Jan 14, 2019 at 2:43 PM
    #120
    Luckydog
    Luckydog New Member
    Dominic
    Currently Ohio.
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    I have been patiently waiting for info on doublecab sliders. Will you have an option for a “kicker”? Also impressed with your primer. I check your website regularly to see if Tundra products have gone live. Keep up the hard work!
    ryanwgregg likes this.
