Victory4x4 new product prototyping.
Discussion in 'General Tundra Discussion' started by brimy311, Jan 5, 2019.
  1. Feb 11, 2019 at 3:54 PM
    #421
    brimy311
    brimy311 [OP] New Member
    Kalamazoo
    2018 Tundra Platinum
    Yup! These mounts have the ability to hold maxtrax boards, tred pro boards, hilift jack, rotopax mounts and containers and anything you can quickfist on them!
  2. Feb 11, 2019 at 3:56 PM
    #422
    3mxdivr
    3mxdivr New Member
    NorCal
    2018 Limited Crewmax TRD Off Road
    AWESOME!
  3. Feb 11, 2019 at 8:18 PM
    #423
    TheBeast The Beach
    looks great. when is the group buy ? :)
    jewsNbrews likes this.
  4. Feb 12, 2019 at 7:52 AM
    #424
    tbrown
    tbrown 2017 CM Limited
    Nashville, TN
    2017 TRD Blazing Blue
    Bilstein 6112 front Bilstein 5160 Piggyback rear Icon AAL Rear Camburg Control Arms Method 312 Nitto Ridgegrappler 295 K&N Intake Corsa Exhaust Bully Dog Viair 400c Dual Onboard Headlight Revolution Stealth Bar Trigger Switch
    Stuck in airports all day, bored, want to buy toys, anything new hitting website today?
    RELEASE THE TOYS!!! Ready to buy something...
  5. Feb 12, 2019 at 7:56 AM
    #425
    brimy311
    Kalamazoo
    I'm heading next door to do the install video on the Molle Panel right now! I'll do what I can to get it released today!
    Toytec Lifts, jewsNbrews and tbrown like this.
  6. Feb 12, 2019 at 9:27 AM
    #426
    ecm209
    ecm209 New Member
    Eddie
    2013 Magnetic Grey Tundra Rock Warrior
    8" FTS lift kit, Lift kit painted Racing Red, 22x12 American Force wheels, 35" Toyo Open Country R/T tires
    Might be the one and only, but any chance you can or might consider making wheel wells. There's really not much out there in the aftermarket business and the OEM one is not that great.
    Mwray8909 and tbrown like this.
  7. Feb 12, 2019 at 9:29 AM
    #427
    tbrown
    Nashville, TN
    And liners for aftermarket fenders!!!
  8. Feb 12, 2019 at 1:36 PM
    #428
    brimy311
    Kalamazoo
    Progress made on LCA’s! These are going up online tonight with the Bedside Molle Accessory panel.
  9. Feb 12, 2019 at 1:44 PM
    #429
    3mxdivr
    3mxdivr New Member
    NorCal
    Discount on Molle panel?
  10. Feb 12, 2019 at 2:15 PM
    #430
    brimy311
    Kalamazoo
  11. Feb 12, 2019 at 4:06 PM
    #431
    oogabooga289
    oogabooga289 New Member
    Will these Victory4x4 mounts with the standard Rotopax mount 3mxdivr linked hold the Rotopax low enough to clear a tonneau cover? The Toyota/Nissan specific factory Rotopax mount holds the Rotopax above the top of the bed and people have to drill additional, lower holes to make a cover clear. Also, they had no support/filler between the mount and side of the bed so they were not the most secure with the weight.
    3mxdivr likes this.
  12. Feb 12, 2019 at 4:11 PM
    #432
    3mxdivr
    3mxdivr New Member
    NorCal
    It should work, since rotopax on it's side (lid pointing to the side) is about 13.5". If the mount is place in the center of the bracket you only need about 7" to top of the roto. I think it is way below topline of the bed. I kinda measured it last night and i forgot the exact numbers..
  13. Feb 12, 2019 at 4:14 PM
    #433
    3mxdivr
    3mxdivr New Member
    NorCal
    i stand corrected... the 3 gallon one is about 15 inches on the side, but most of them including the 4 gallon is 13.25" wide. The length changes as you go bigger tank. In general, you only are affected with the dimensions on the sides.
    oogabooga289 likes this.
  14. Feb 12, 2019 at 4:16 PM
    #434
    pbcolt
    pbcolt New Member
    San Diego
    2017 DC Limited TRD OR 4x4
    Are rear shock guards a future possibility?
    Luckydog, theraven and brimy311 [OP] like this.
  15. Feb 12, 2019 at 4:31 PM
    #435
    oogabooga289
    Thanks for the info. I don't think any unmounted pictures have been posted to see how deep the mounts reach. Maybe that'll help clear up any clearance issues in conjuction with your measurements.
    3mxdivr likes this.
  16. Feb 12, 2019 at 5:16 PM
    #436
    Yzed608
    Yzed608 New Member
    Wisconsin
    Woah, I didn't see the posts about the LCA skids before. Something else I probably don't need/won't use to it's potential but still want. Do the bolts go all the way though to the other side of the arm? Just curious if it's an easy take on/off for alignments (or can the alignment adjustments still be done with them on?).
  17. Feb 12, 2019 at 5:48 PM
    #437
    Jrfor0
    Jrfor0 New Member
    James
    The LCA skids look awesome. Are they compatible with a mid-travel setup?
  18. Feb 12, 2019 at 6:34 PM
    #438
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    LCA GB / intro special?
    theraven likes this.
  19. Feb 12, 2019 at 6:38 PM
    #439
    brimy311
    Kalamazoo
    I’ll have install video tomorrow. It’s kist three bolts per side.
  20. Feb 12, 2019 at 6:38 PM
    #440
    brimy311
    Kalamazoo
    The IntroPricing coupon code will be active for the first few days.
    14burrito likes this.
  21. Feb 12, 2019 at 6:40 PM
    #441
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    Link? Or it’s on website
  22. Feb 13, 2019 at 2:14 AM
    #442
    brimy311
    Kalamazoo
    What kit are you running? I don’t think it is an issue, but I can double check.
  23. Feb 13, 2019 at 6:08 AM
    #443
    KevinK
    KevinK SGU - High Speed Overlander
    Gilbert, Arizona
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    Almost all mid travel setups use the stock lower so these should work unless you’re running MT2 which adds a secondary shock and you had to weld a mounting tab to your LCA. Even then it looks like you could trim the back side of the skid to eliminate the upturn and clear the tab.
    So yeah, 99% chance it bolts up to any mid travel. Anyone that it won’t fit on, they already know because of the amount of work they had to do to build their MT setup.
    831Tun and 14burrito like this.
  24. Feb 13, 2019 at 9:40 AM
    #444
    Cement
    Cement New Member
  25. Feb 13, 2019 at 9:53 AM
    #445
    831Tun
    831Tun IMA BasTRD
    Warren
    Santa Cruz
    '16 CM limited
    ADS C/O w/clickers, ADS bypass rear, Icon UCAs, Toytech shackles, chrome delete, Pro grille, TRD dual exhaust dumped, de-badged, black LED tail lights. BHLM w/projectors, 295 70 18 Cooper STT pro on stock rims w/1.25" Spider Tracks. N_Fab bumper w/Baja Design fogs and ditch lights, 13" antenna x, RCI skid, All Pro sliders, ARB compressor
    I've been looking for something, I've seen the dv8 or whatever on FB but they look a bit bulkier than I think is necessary. The tow hooks are my entry angle limiters right now. Usually I carry the OEM tow hooks in the back of the truck and install when needed.
  26. Feb 13, 2019 at 10:36 AM
    #446
    sr5shark
    sr5shark No matter where you go, there you are.
    Alan
    Walnut Creek, CA
    2016 SR5 CrewMax 4x4
    Bilstein 5100's |SCS SR8 w/ GY Duratrac | TRD rear sway bar
    That's a good idea. I painted my tow hooks and they look great on the top and are all scratched and gouged on the bottom. ;)
    Cement, 831Tun and jewsNbrews like this.
  27. Feb 13, 2019 at 12:17 PM
    #447
    TheBeast The Beach
    @brimy311 when will we see the TREd pro mounts on sale ? :)
  28. Feb 13, 2019 at 12:57 PM
    #448
    brimy311
    Kalamazoo
    Working through it all! There’s a lot to a product launch! Haha. It’s one of the next parts to launch.
    TheBeast and jewsNbrews like this.
  29. Feb 13, 2019 at 3:26 PM
    #449
    Jrfor0
    Jrfor0 New Member
    James
    I have the extended travel King 2.5's with SPC UCA's.
    Jimes likes this.
  30. Feb 13, 2019 at 3:39 PM
    #450
    brimy311
    Kalamazoo
    Here’s a new prototype. But this one is super close to final.
    This is a front bed molle accessory rack.
    We built in a bunch of features to allow for a plethora of options!
    The rack has the follow;
    - Vertical and horizontal rotopax mounting locations. Those are pictured in the center of each panel.
    - Hi-lift mounting locations
    - Tred pro and Maxtrax board mounting locations
    - A ton of locations to mount quickfists and molle bags.
    This one will work with any tonneau cover.
    You can’t mount everything, but I’ll do my best to show different combinations. You can also swap stuff out based on trip needs.
    Mwray8909, Krezz, jewsNbrews and 6 others like this.
