Vibration/Resonation at different speeds
Discussion in '2.5 Gen Tundras (2014-2021)' started by drw_2016tundra, Jan 11, 2023.
  1. Jan 11, 2023 at 4:52 PM
    drw_2016tundra
    drw_2016tundra [OP] New Member
    I have a 2016 Tundra SR5.
    52000 miles
    2w drive
    I noticed the vibration just seem to start. It starts at 40 to 45 stops and starts again at 60 to 65 and stops. I had fairly new tires with only 5000 miles.
    i brought the truck to the tire shop and they felt the tires were defective. Ended up changing all 4 out to a different brand and a higher speed rating.
    The problem continued. I had the front end aligned and they told me the front bearings were bad. The alignment did not solve the problem.
    i changed the front bearings, they seemed ok but I changed them anyway. That did not sol e the problem.
    i checked the carrier bearing and it had almost no play so I left it alone.
    so any help will be appreciated.
  2. Jan 11, 2023 at 6:37 PM
    blenton
    blenton New Member
    Any suspension mods to the vehicle? Level kit, maybe? Are your shocks in good shape? Have you had the new set of tires rotated to see if it changes the vibration? Is the vibration in the steering wheel, seat, floorboards, where? Also, what tires are you using? Some are notorious for being difficult to balance. Ask the tire shop for a balance report to see how much weight was needed to balance each tire. Are you running aftermarket wheels?
  3. Jan 11, 2023 at 7:08 PM
    drw_2016tundra
    No modifications to the truck all original.
    Shocks appear to be fine no leaks.
    Tires were rotated no change.
    Vibration in the steering wheel, dash and center console, mostly in steering wheel.
    Stock wheels.
    Had Bridgestones replaced with Parelli.
  4. Jan 11, 2023 at 7:12 PM
    blenton
    blenton New Member
    Vibration that comes and goes with speed is often a tire balance issue. I've had a tire throw a balancing weight half a mile after getting them balanced, so maybe it's worth another trip to the tire store. Do they road force balance them?
    Next check would be front steering items, but usually when those are worn they just get worse with speed - violent even.
    drw_2016tundra[OP] likes this.
  5. Jan 12, 2023 at 6:24 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Steering wheel shimmy ? Find someone who can road force balance them..make sure all the weight are off before they balance them.. My experience, techs were just adding weights and too lazy to remove the old ones..
  6. Jan 12, 2023 at 6:00 PM
    drw_2016tundra
    I had all four tires road force balanced and nothing changed.
  7. Jan 12, 2023 at 6:12 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Doesn't matter if the tech who did the balancing doesn't know what he's doing.
    I had a similar issue and went back to the shop 3 times. 1st time, re-balance. 2nd time, re-balanced and spread the weight out, 3rd time, re-balanced and found a bad tire (brand new).
  8. Jan 14, 2023 at 11:39 AM
    Fester
    Fester New Member
    2017 Crew Max
    I have the same issue with my 2017, Super Crew 1794 2wd. Humming noise that can be felt in steering wheel when it's at its loudest. It hits at exactly 50mph and between 60 & 70mph. Front wheel bearings done because Toyota dealer said it was them, not. Carrier bearing because a friend said it was the cause, not. My tire shop has rotated & balanced tires with 10K on them and no change. Only weird thing is when it's colder outside its much lower volume. Nothing else affects it, just the speed the truck is moving. At this point no matter how much it drives me crazy I'm just going to run it until some falls off, breaks or catches fire.
  9. Jan 15, 2023 at 4:06 AM
    Bassballs75
    Bassballs75 New Member
    I have a 2019 28000 miles got a balance and alignment and I'm having the same problem
  10. Jan 15, 2023 at 10:24 AM
    Fester
    Fester New Member
    2017 Crew Max
    Tires? LTX AT's. Same as factory with 10k on them when the noticed the noise.
  11. Jan 15, 2023 at 4:22 PM
    ToolCat
    ToolCat New Member
    Greg
    You guys gotta keep plugging away at it....
    I'm thinking it could be the front suspension---possibly the shocks/springs are setting up some kind of harmonic vibration, or play somewhere in a ball joint/sway bar/tie rod end?
    One trick is to cheat a bit on the front alignment toe-in, your front tires are wanting to toe-out going down the road, so if there is play anywhere they will toe out.
    Tundras are real easy to warp the rotors (with the 5-bolt pattern) when installing wheels. Usually this would show up during breaking, but could manifest as vibration at speed?
    You've got to rule out tires and proper balance 100% somehow...
    Any difference at-the-occurring speed range if you are on the gas or off? Brakes applied or not?
    If you can narrow it to a particular state, can help isolate the issue.
    Until then may just have to throw quality parts at the truck? New u-joints and carrier bearing can't hurt...
    ToolCat
  12. Jan 17, 2023 at 5:34 AM
    SupraTwin
    SupraTwin New Member
    AL
    2013 Toyota Tundra TRD Off Road
    Stock with Bypass for air injectors
    I had the same problem with a 2007 Tundra. I noticed the vibration just seem to start at 40 to 50 stops and starts again at 60 to 70 and stops. I had this truck for two weeks. I went back to the dealer and they fixed the torque converter. Problem solved. Hopefully this helps.
  13. Feb 24, 2023 at 2:12 PM
    Fester
    Fester New Member
    2017 Crew Max
    Problem solved!!!
    "People" said you cannot jack up the truck and put it in drive to spin the drive train under power. Maybe so on others but I turned off the traction control and it worked. The dash lit up like a Christmas tree but the drive train spun. The noise coming from driver's side rear wheel bearing. All the faults cleared as soon as I drove it 100ft... As the saying goes your milage may vary. Hope I can help others with this.
  14. Feb 24, 2023 at 2:31 PM
    Rocko9999
    Rocko9999 New Member
    Also, move tires around after marking them with chalk to see of any vibration changes.
  15. Feb 25, 2023 at 6:45 AM
    ssmtaco2ssmtundra
    ssmtaco2ssmtundra New Member
    Randal L
    The Bluegrass State
    2020 ssm Ltd CM
  16. Feb 25, 2023 at 6:47 AM
    ssmtaco2ssmtundra
    Randal L
    The Bluegrass State
    2020 ssm Ltd CM
    Same issue here. Dealer said bearing in front diff. Replaced the whole diff under warranty. Problem still there. Took it back and diagnosed as right rear axle bearing. Warranty job. All good now. 58,000 mi.
