Valvoline Restore & Protect?
Discussion in 'Performance and Tuning' started by Bham TRD, Jul 4, 2025 at 6:07 AM.
  1. Jul 4, 2025 at 6:07 AM
    Bham TRD
    Bham TRD [OP] New Member
    2017 Tundra Platinum 4WD CrewMax
    Anyone have any experiences with Restore & Protect?
    I just changed my oil yesterday and went with 5w-30 full synthetic Restore & Protect.
    As an extra step of caution of caution, I picked up 6 oil filters and will change them every 1000 miles just to make sure the filter doesn’t clog up.
    100k miles on mine, wouldn’t think it would be too bad.
  2. Jul 4, 2025 at 6:13 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Why? For what reason do you need to change the filter every 1000 miles on a truck that has 100k miles on it?
    Xcumminsguy likes this.
  3. Jul 4, 2025 at 6:24 AM
    Bham TRD
    Shouldn’t have to, but $4.50 for each filter is cheap insurance.
    Restore & Protect should be slowly breaking stuff down, super cheap insurance to make sure it doesn’t flood the filter with crap clogging it up, bypassing it and sending stuff unfiltered through engine clogging the oil pick up screen.
    Also important, I’m really interested in inspecting the filters to see what they’re catching as it goes.
    Granted @ 100k there shouldn’t be that much…
  4. Jul 4, 2025 at 6:28 AM
    Danman34
    Danman34 New Member
    Danny
    After 100k miles, if youve been changing oil every 5k like you should, there shouldn’t be much of any deposits. Even so, whatever is broken down, won’t be solid pieces. The filter isn’t going to catch liquified oil deposits. The heat will turn it back into a viscous liquid that goes right through it. I think you’re trying to reinvent the wheel here.
  5. Jul 4, 2025 at 6:39 AM
    Bham TRD
    Guess I should said that, I recently bought this truck, oil was consistently changed at 9-10k miles, which I never would’ve done.
    Also, I understand how it’s supposed to work, but there are instances in other engines of it overwhelming the filter and clogging the pickup screen.
    Rather than discussing obsessive cheap and quick filter changes, I just wondered what experiences others might have had with Restore & Protect.
  6. Jul 4, 2025 at 2:58 PM
    d33pt
    d33pt New Member
    Does it burn any oil?
  7. Jul 4, 2025 at 3:21 PM
    Bham TRD
    It doesn’t from what I’ve noticed in the 2500 miles I’ve owned it.
    I don't like that the oil was changed on a 10k interval its whole life though.
    Carfax does show that differential fluid was changed appropriately.
    Doesn’t show any coolant or transfer case changes.
    Coolant looks fresh, I changed it anyway.
    As soon as my buddy’s shop has a free lift he’s gonna let me change differential and TC fluids, will also drain and fill tranny.
  8. Jul 4, 2025 at 3:24 PM
    d33pt
    d33pt New Member
    If it doesn't burn oil or show any sludge, I wouldn't really worry about doing anything special. Just change it at the interval you like and go on with it. Everything else you're doing is great. Always good to get fresh fluilds in when you buy a used car. 100k is nothing for these trucks. I got mine at 120k and I did everything on it so far, except the tranny. Ordered 15 qts today since it's on sale, and will do 3 drain and refills and I'll be good to go for another 60k.
    snivilous and Bham TRD[OP] like this.
  9. Jul 5, 2025 at 8:52 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    My buddy just ran it for 10k in his Tacoma coming up on 200k with 10k OCIs. Pretty wild how well it cleaned up the internals you can see under the fill cap. I’ve got it in my 3rd gen runner currently. Only a couple thou on it. Also it’s intentionally designed to work slowly as to not overwhelm a filter in 5k.
  10. Jul 5, 2025 at 11:07 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    If you’re doing the rest of the fluids at 100K, don’t forget the power steering and brake fluids. Everyone forgets the power steering and brake fluids…
    And spark plugs. And serpentine belt. And PCV valve.
  11. Jul 5, 2025 at 11:43 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Yes. Brake fluid is always forgotten and it's job is so important.
    sudobash and j_supra like this.
  12. Jul 5, 2025 at 1:24 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    I’m on my first oil change with R&P 5w30 and I’m at 96k miles. And I just changed the filter at the first 1000 miles on the oil. I went through every pleat and hardly found any sediment.
    My previous oil change was using Amsoil SS 5w30 for 5k miles and found more crap over that interval.
  13. Jul 5, 2025 at 1:28 PM
    blenton
    blenton New Member
  14. Jul 5, 2025 at 2:41 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    I drop a couple Tide Pods in with my Kirkland oil…
    WILLINH likes this.
  15. Jul 5, 2025 at 2:52 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Bob himself does this. A hack of greater significance than the nitrogen hack.
