V8 flex fuel vs v8 non flex fuel
Discussion in '2nd Gen Tundras (2007-2013)' started by Jgarcia6820, Aug 5, 2018.
  1. Aug 5, 2018 at 4:49 PM
    Jgarcia6820
    Jgarcia6820 [OP] New Member
    Jhonny
    2013 tundra rock warrior
    just bought a tundra 5.7 v8 and keep reading every where flex fuel this none flex fuel that. How do I know weather mines is a flex fuel tundra or not, and what’s the difference?
    Feel free to dumb it down for me! Thanks in advance
    TundraAllTheWay likes this.
  2. Aug 5, 2018 at 4:51 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Gas cap should tell you. Flex fuel is up to 85% ethanol. Non flex fuel cap will say something like 20% ethanol max.
    OBXTundra and Blueknights75 like this.
  3. Aug 5, 2018 at 5:12 PM
    Jgarcia6820
    Jhonny
    I belive mines saids 85 with the circle cross sign, in other words not allowed. In other words im not a flex fuel engine ?
  4. Aug 5, 2018 at 5:13 PM
    Blueknights75
    Ron
    Clayton, NC
    Yep
  5. Aug 5, 2018 at 5:14 PM
    Jgarcia6820
    Jhonny
    Like this
  6. Aug 5, 2018 at 5:14 PM
    Jgarcia6820
    Jhonny
    Perfect, thanks
    Blueknights75[QUOTED] likes this.
  7. Aug 5, 2018 at 7:29 PM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    Gas caps can be switched.
    Go to the Toyota Owners website and enter your VIN, it will tell you a lot about your vehicle;
    https://www.toyota.com/owners/vehicle-specification
    It will tell if you have a E85 Flex Fuel engine. If you don't see those words in the Mechanical & Performance section for your engine, you don't have Flex Fuel engine.
    Greg
  8. Aug 5, 2018 at 8:05 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    What Greg said...
    Jgarcia6820[OP] likes this.
  9. Aug 6, 2018 at 3:20 AM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    You can also request the specs from Toyota with email. Did this with daughters Rav4. They send window sticker type info and even MSRP
  10. Aug 6, 2018 at 5:32 AM
    Jgarcia6820
    Jhonny
    I wanted to do this thanks for the information
  11. Aug 6, 2018 at 5:41 AM
    Jgarcia6820
    Jhonny
    Checked non flex fuel thanks, greg
  12. Aug 12, 2018 at 1:17 PM
    JTP
    JTP The Big Black Moose
    Sterling, Alaska (Formerly DFW Texas)
    The Big Black Moose
    I put some of that E85 shit in my tank ONCE (2013 Flex Fuel 5.7) and that shit was terrible. No power and I could watch the gas gauge moving to empty.
  13. Aug 23, 2018 at 2:45 AM
    Aron9000
    Aron9000 New Member
    Aaron
    Funny because a lot of high performance turbocharged cars run great on the E85 and make more power than 93 Octane swill(mainly tuned BMW twin turbo six cylinders and built turbocharged GM LS V8 engines)
    WXman likes this.
  14. Sep 17, 2018 at 11:10 PM
    JTP
    The Big Black Moose
    LOL I hear if you wear a DD bra and put water balloons in them your safer in a crash
  15. Sep 18, 2018 at 12:16 AM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    Ethanol is dumb; corn has better uses than as fuel and has a lower energy density than regular gasoline.
    Jengel451 and UNTMatt like this.
  16. Sep 18, 2018 at 4:40 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Since this came back up, let me ask this question: My truck is FFV. Other than that I can use E85 if I want to or for whatever reason I have to if I get to a place where that is all that is available, what other advantage or disadvantage is there to having a FFV? I have heard that non-FFV can do oil changes at 10,000 intervals and FFV has to do at 5,000. I assume that is only if you use E85. Can I do 10,000 intervals if I use regular gas?
  17. Sep 18, 2018 at 4:57 AM
    scruffy
    scruffy New Member
    Dmitriy
    2014 Toyota Tundra Double Cab Limited TRD 5.7 4X4
    100% correct on this just gotta understand why. I absolutely guarantee you that if you had a supercharged Tundra, you'd be running from station to station on E85 happily. Simply put it's poor man's race gas. It burns cooler and has higher knock resistance. What this means for a boosted engine is that you can turn up the pressure with less chance of pre-detonation/detonation. This does come as the cost of poor economy associatated with ethanol as well as being heavy footed. Naturally aspirated engines just don't stand to gain anything from it really.
    In terms of E85 tundra vs Non, I personally would go E85 (and did). Yes earlier ones did have issues but those seem to be ironed out. In general the engines are going to be the same, biggest differences you see is fuel systems. The E85 will be more apt to handle corrosive materials, ethanol, and potentially stronger injectors/pump due to viscosity differences especially on colder days. (source: I have one of those BMWs and had to do my own research. Now runs a Walbro 450 in tank.)
    bvia, UNTMatt and Boerseun like this.
  18. Sep 18, 2018 at 5:21 AM
    scruffy
    scruffy New Member
    Dmitriy
    To answer you question, simply no and in no vehicle ever should you do 10k oil change intervals. I still can't believe Mobil is trying to get away with annual oil changes. The simplest way to put this is, your fuel does not mix with your oil and if it does, you will be looking for a new engine soon (washed out bearings). As such the biggest factor for oil is heat. The thermostats on the engine are all set the same, relatively speaking between 180 and 210 F. That is not to say oil temperature doesn't exceed that. For example if towing frequently, consider shorter intervals. Heat breaks down the oil and it's lubrication capability. Otherwise, for full synthetics observe anywhere from 5,000 - 8,000 miles changes depending on abuse and usage and you will have a happier longer-lasting engine.
  19. Sep 18, 2018 at 5:26 AM
    UNTMatt
    UNTMatt New Member
    2015 Attitude Black 4x4 Limited
    TRD Pro grille, TRD Pro black badging, TRD Pro shift knob, LED under dash lights, GBS, Llumar ceramic tint, BackFlip HD.
    I'm not sure why the difference in oil changes between FFV and non-FFV.
    That being said, the owners manual on the FFV states that oil changes are every 5,000 miles IF you run E10 or lower in your ethanol concentration. In other words most standard gas.
    IF you run E85 more than 50% of the time, you need to change your oil every 2,500 miles.
    --Matt
    Boerseun[QUOTED] likes this.
  20. Sep 18, 2018 at 6:09 AM
    Boerseun
    Ferdie
    Sarasota Florida
    I do full synthetic at 5,000 intervals. I was just wondering why they recommend different intervals for different fuel types. As you said, the fuel and oil should not mix, so from that standpoint oil change interval should not be impacted by what fuel you are using. I don't plan on using E85 anyway; was just wondering in case I have to run it for whatever reason. I get free oil changes anyway, so if I have reason to get a flush I can do it every 1,000 miles, but typically I am at 5,000.
  21. Sep 18, 2018 at 6:19 AM
    scruffy
    scruffy New Member
    Dmitriy
    Albeit I cannot speak for Toyota, a best guess would be there's a difference simply to cover their asses. In my opinion, at most there might be an operating temperature difference between the two fuels. It's commonly known fact running too cool can also be detrimental just like running too hot. As with most things though, once out of warranty use the manual more as a guide. For example many vehicles will specify a lifetime fluid in a transmission, ie BMW, but you ask any mechanic and they will tell you no such fluid exists.
    All things considered, stick to a good maintenance schedule and you should be fine. Just glanced at a Silverado manual and they don't specify anything special for FFV and they've been running them longer than most.
  22. Oct 18, 2018 at 6:56 AM
    Ericsopa
    Ericsopa Old man and the sea
    Hmm. Don't tell that to my 1990 Jeep Comanche (actually, little brother has it now, since I bought the Tundra) that I bought new and have only changed the Amsoil once a year for the last 28 years. 300k miles, still 150# compression in all 6 cylinders, nary a drop of oil added between annual changes, never down for any maintenance, save a couple water pumps, an alternator, and an ignition coil. 28 years young and still pulling strong. Pulled my 4500# boat 500 mile round-trips 4-5 times/year for 7 years till I got the Tundra three years ago. My wife's VW Beetle 99K+ miles, and the Tundra 95K+ miles, are getting the same treatment. At my age, the Tundra will outlive me.
    Smoofers and gosolo like this.
  23. Oct 18, 2018 at 7:23 AM
    scruffy
    scruffy New Member
    Dmitriy
    Really, I truly am happy that you've had such an experience with your vehicles. Not to mention, I'm a fan of straight six's. That said I wouldn't compare the tolerances of your 6 to that of a DOHC modern V8. Should also note that aside from you using a quality oil, a lot of things changed in production since the early 90's, some good and some bad. Anything from the types of alloys, to tolerances, to the number of plastics used, etc. Out of curiosity, consider getting a Blackstone oil report to see how well your extended oil changes fare. Basically your post is something along the lines of, if my neighbor can get 200k miles on his timing belt that means all vehicles can so I shouldn't do mine at 100k.
    My experience is different from yours though and actively working on other's vehicles that use various types/brands of oil have shown different results. So in the simplest of terms, with a typical consumer changing say 2,000 miles sooner than 10,000 not only doesn't hurt the wallet but also provides a nice margin of safety. In reality, the average consumer more often than not ends up driving past the recommended norm for oil changes, using the most budget friendly oil change, and typically resides on the fix when it breaks as opposed to preventative schedule. The only true way to tell someone an accurate oil change interval is to have them pick a brand/type/weight, establish a typical driving regime, submit samples for testing, and adjust the interval accordingly. Now the average Joe will not do that, so the err on the side of caution is best when providing advice to people and not recommend doing something to the absolute recommended limit of a product.
    I should also note that it is common practice for manufacturers to note that engine oil consumption to a certain degree is normal and should not be a point of concern. It is nice that yours doesn't use any though. A lot of today's engines are also going the way of forced induction, high compression, plastic timing components, etc meaning that a lot more stress and heat is generated. This is largely connected to more stringent emissions standards and the strive for better economy.
    Don't take this post as an attack, I just don't want someone to walk away thinking this is OK just cause it works for you. As always, I would encourage anyone to do their own research in the effort of protecting their property.
    gosolo and Ericsopa[QUOTED] like this.
  24. Oct 18, 2018 at 7:52 AM
    Ericsopa
    Well, next oil change comes up in Dec. I'll get the sample done. Been meaning to do that anyway.
    scruffy likes this.
  25. Oct 18, 2018 at 7:57 AM
    scruffy
    scruffy New Member
    Dmitriy
    Be sure to share when you do, I would definitely be curious!
    Currently at the shop we have an 11 Tiguan with 120k and a 14ish Cadillac with 50k. Both came in with oil starvation for timing jobs. Let me tell you, times like this I wish it was a 90's straight six. The Tiguan alone had 3 chains and 6 guides. Now we have the belly pan coming down to see where shavings came from.
    Ericsopa[QUOTED] likes this.
  26. Oct 18, 2018 at 8:01 AM
    Ericsopa
    Yessir! I'll post up the results in this thread.
  27. Dec 16, 2018 at 5:57 PM
    Ericsopa
    Changed oil today. Sending my sample in to Blackstone tomorrow. It's been 12 days shy of one year since I changed oil. And 23090 miles. Haven't needed to add any oil during that time. Truck has 100183 on it now. We'll see what Blackstone has to say.
    scruffy likes this.
  28. Dec 16, 2018 at 6:06 PM
    scruffy
    scruffy New Member
    Dmitriy
    Nice to see you're still going through with it, can't wait for the results!
  29. Dec 18, 2018 at 10:00 AM
    Dr_Al
    Dr_Al New Member
    Al
    Read your owner's manual. My '13 Rav4 it says change the oil every 10k in summer conditions and 5k in winter and in severe conditions. I haven't looked hard for it so maybe you can get it but the 0w20 oil seams to be just synthetic. With 160k on it now and it not burning a drop of oil I would say that the engineers at Toyota know what's best. The only deviation was when it was new, I did an oil change at 1500 and then another at 5000. After that almost all of them have been 10k apart.
    My '07 Tundra says change the oil every 5000 miles. It doesn't say anything about flex fuel (mine isn't) so it's possible that Toyota has a different schedule for it. I'm not one who goes for the idea that switching to synthetic will give you the ability to extend the oil change interval. I'm not saying it's not possible just that I personally like to stick to the schedule set by Toyota.
  30. Dec 18, 2018 at 6:25 PM
    Ericsopa
    If you're talking to me about reading the owners manual, understand that I know exactly what it says. Do whatever you want with whatever product you choose. I know what I'm doing.
