Using Map and Weathe
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mootball, Feb 15, 2019.
  1. Feb 15, 2019 at 7:12 PM
    Mootball
    Mootball [OP] New Member
    ‘16 TRD Crew Max
    None yet but plenty to come.
    So I have a 16 CM TRD and wondering what I need to do so I can use the Map and Weather parts of the truck. I thought the Entune app would do it but I can’t get the thing to pair to my phone. Is it user problems haha cause I can’t figure it out!!!
    Thanks for the help!
  2. Feb 15, 2019 at 7:24 PM
    dmiller
    dmiller New Member
    Dusty
    Guntersville, AL
    '18 MGM CM SR5 XSP
    BD Squadron Sport Amber WC Fogs
    I'm going to assume your entune headunit is about the same as mine. If that is the case then the Entune app is essentially worthless. I've yet to figure out what, if anything, it is good for. I believe Weather relies on an HD radio signal. If you have a stubby antenna you may or may not have enough signal strength for it to come in. Mine works most of the time, even with the Stubby.
    For the map, you need the Scout GPS Link app.
    https://itunes.apple.com/us/app/scout-gps-link/id866180950?mt=8
    Even then it only gives turn by turn, it doesn't actually show a map.
  3. Feb 15, 2019 at 7:46 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I've tried to install scout on my JBL entune and it does not work. I think its a 2018+ thing.
    NewImprovedRon likes this.
  4. Feb 15, 2019 at 8:48 PM
    Mootball
    ‘16 TRD Crew Max
    Hmm
    So I guess having a broken antenna is not gonna help the situation at all...
  5. Feb 15, 2019 at 10:03 PM
    iHacker
    iHacker SW TRD PRO
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    The Scout app is only for Entune Plus head units (non-Navi) 2016+ trucks, the Entune Premium (Navi) and JBL headunits are not compatible with the scout app.
  6. Feb 16, 2019 at 5:23 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    I am confused. Why do you need to use the Scout app at all? My maps work just fine without it. I open it up, put in the location, and it works flawlessly. Why don't you juts use the default?
  7. Feb 16, 2019 at 8:50 AM
    iHacker
    iHacker SW TRD PRO
    The Scout app is intended for units without navigation, the Scout app is kind of navigation add on if you don’t have it.
    Just a clarification, you have to download the Scout Link app not the Scout main app to do this.
    https://youtu.be/kq0B78CGp3I
    Ronin73[QUOTED] likes this.
  8. Feb 16, 2019 at 8:54 AM
    Ronin73
    Ronin73 New Member
    Gotcha. Thanks for that clarification.
