Upper control arms 1 gen
Discussion in '1st Gen Tundras (2000-2006)' started by mertintech, Apr 9, 2021.
  1. Apr 9, 2021 at 6:24 AM
    mertintech
    mertintech [OP] New Member
    ross
    2001 tunda
    Looking to install 3 inch lift on front and 2 on rear want to go with spring lift no spacer so 2 part question which shock spring assemble and the most important which Upper control arms are okay but don't break the bank
  2. Apr 9, 2021 at 7:21 AM
    Professional Hand Model
    Hand Protectors
    Whats your budget?
    2006Tundra likes this.
  3. Apr 9, 2021 at 7:32 AM
    Wes_heppy
    Wes_heppy Trucks...Dirtbikes... Guns...
    Weston
    2003 tundra 4x4 4.7
    TC UCA Radflo coilovers Long Tubes LSD
    The best upper control arms are total chaos or possibly solo motor sports. A good choice for cheaper is SPC. For coilovers there are many options. For the full 3 inches there are radflo, ads, icon, and fox because they are available in extended length option. I believe king says they are only 2.5 inches of lift because they are not extended length. Old man emu is a very good choice. Give about 2.5 inches, super high quality and durable, and very reasonably priced. Also cant go wrong with bilstein 5100s on using an old man emu spring.
    https://yotamafia.com/product/radflo-stage-1-lift-kit-1st-gen-tundra/
    https://www.1stgenoffroad.com/store/c18/TundraSuspension#/
    https://www.shocksurplus.com/products/fox-2-5-factory-series-coilovers-pair-883-02-026
    Pearl-snap and Glock 40 like this.
  4. Apr 9, 2021 at 8:15 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
  5. Apr 9, 2021 at 8:21 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    I have a mild lift (2.5" front) and am running these, happy.
  6. Apr 9, 2021 at 8:39 AM
    SouthWestGA
    SouthWestGA New Member
    Don’t buy the generic knockoffs Ebay ones they’re junk and aren’t to spec
    i know from experience
    i bought the uniball style uppers and they were junk
  7. Apr 9, 2021 at 8:57 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    I bought some new JBA off-road ones from a member here and I’m happy with them. I was looking at Freedoms as they have some pretty good reviews and don’t break the bank. Again, for another $100 over the freedoms, you can go with a ‘premium’ brand.
    Wes_heppy likes this.
  8. Apr 9, 2021 at 12:42 PM
    mertintech
    ross
    2001 tunda
    budget 1100 to 1500 all in
  9. Apr 9, 2021 at 2:47 PM
    Mitch09
    Mitch09 New Member
    NC
    2022 SR5 TRD Off-road
    I recently went with the Bilstein 5100s with Old Man Emu 2887 Springs. I got about 2.5 inches lift (front) and am very pleased with the ride quality. Was looking for some budget UCAs. I went with Freedom Off-road. Got them off the 1stgenoffroad website, someone posted the link above. That whole set up was about $850.
  10. Apr 9, 2021 at 2:54 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Access cab or double cab?
  11. Apr 9, 2021 at 2:58 PM
    Mitch09
    Mitch09 New Member
    NC
  12. Apr 9, 2021 at 5:26 PM
    mertintech
    ross
    2001 tunda
    So you are happy with the ride and feel you get from the freedom control arms and when the truck is on hoist does the spindle not contact the spring .
  13. Apr 10, 2021 at 5:40 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    Same.
  14. Apr 10, 2021 at 6:16 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    There's also the Mevotech arms out there that are rebranded SPC arms for about $150 less.
    I'll also argue that for a daily driver truck the SPC arms are a better choice than uniball arms.
    My 2 cents order the Eibach 2.5 units from @Toytec Lifts using the forum discount code and the Mevotech arms from Rock Auto. Gets you out the door at just over $1k and the only special tool you'll need is the press for the upper ball joint.
  15. Apr 10, 2021 at 1:23 PM
    mertintech
    ross
    2001 tunda
    So has any one used the movetech control arms do they hold up ok
  16. Apr 10, 2021 at 1:26 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Mevotech arms are rebranded SPC arms (old spc stock) unless you get the ones that look exactly like OEM. Those ain't what you want for a lift.
  17. Apr 10, 2021 at 2:22 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 340k+
    2” Lift, Bilstein 5100’s and 885’s, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags with Daystar Cradles. Spider Trax 1.25” Wheel Spacers, Factory Wheels wrapped with Toyo 285/70r17 AT2’s.
    Why do you need upper control arms? Are you maxing out your factory ball joints? I’m guessing not.
    I’m asking cause I know they aren’t needed. You don’t need gobs of Castor to track straight down the road. Higher offset wheels correct for lack of castor as well. The CV’s have limited travel, you start pushing these things to 3” lift, you’re running out of down travel. Also you start putting the TRE’s at steeper angles and they are already not the beefiest.
    I put 40k a year on my truck and I’m on 285’s and beat the $hit out of my truck on washboard roads. I’m at 1* negative castor and I track straight down the road with no bump steer. Upper ball joints are $51 from the dealer and can be replaced without pulling the whole front end apart.
    I’ve owned and currently own multiple 4Runners and Tacoma’s. My 5th gen runner I’m not impressed with the gobs of Castor I picked up from the installing the JBA UPA’s. I replaced the stock uppers cause they contacted the 6112’s. Also, uniballs squeak when they get worn in and rust.
    In the end it’s a big investment if not needed.
    MS22 likes this.
  18. Apr 10, 2021 at 9:45 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    You make some great points. The wheels offset does change how the steering wheel centers itself. It's all about kpi or kingpin inclination. Pretty interesting how high or low offset wheels and even tire size can change kpi for better or worse. I've noticed that wheels with low backspacing tend to help center the steering wheel just because your tire is now turning out and in around the imaginary line drawn when connecting the upper and lower kingpins to the ground. Almost like caster, but not quite the same feeling for me.
    My truck is running somewhere around 2-2.5* caster. It wandered a bit at 1.75* so I bumped it up. These trucks especially start losing caster on downtravel quickly so anybody running with nearly no downtravel from ride height is looking at low low or 0* caster. I think my truck runs into 0* at the bottom of the droop, but my truck is damn near airborne at that point and I likely won't notice a lack of caster.
