UPOER CONTROL ARM QUESTION
Discussion in 'Suspension' started by 2010bigdog, Apr 24, 2019.
  1. Apr 24, 2019 at 6:54 PM
    2010bigdog
    2010bigdog [OP] New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD /2026 TUNDRA LIMITED
    Looking to switch out my 3/1 leveling kit to maybe the BDS 4.5” kit and was wondering what UCA’s I could go with since that kit doesn’t come with new arms ? Any suggestions?
  2. Apr 25, 2019 at 8:44 AM
    Justin@bajakits
    Justin@bajakits Suspension dude
    Justin
    California
    07-17 Tundra: Bajakits chase kit demo vehicle
    Bajakits Chase kit: UCAs with king 2.5 coilovers Bajakits Rear Chase kit: Deaver F85 pack with King 2.5 Remote Resi.
    Are you looking for more of a lift kit or a suspension system giving you a bit of usable travel?
    Whats your overall goal of the truck?
  3. Apr 25, 2019 at 10:14 AM
    2010bigdog
    Chuck
    Chicago
    I have a 3/1 kit now and they can’t seem to get the alignment correct so therefore the front tires look like a V so looking to switch out the control arms (upper) to correct the problem but looking to do a little bit more lift 4”-5” down the road and some of those kits do not come with upper control arms and just knuckles so I was trying to figure out what arms would work now with what I have but more importantly to make sure they would work with the new lift in the future because I know some arms are only good up to 3”. Hope that makes sense. Looking to do just a 4.5” BDS or a 5” ZONE lift down the road
  4. Apr 25, 2019 at 11:06 AM
    SPC UCA's are adjustable
    Les7311 and Black Wolf like this.
  5. Apr 25, 2019 at 11:34 AM
    n2deep
    n2deep Pavement Princess
    But how do you plan to use the truck? If you want just looks then a lift kit works- if you want more performance and travel then you need suspension uprade.
    Justin@bajakits likes this.
  6. Apr 25, 2019 at 6:27 PM
    2010bigdog
    Chuck
    Chicago
    just looks
  7. Apr 25, 2019 at 6:30 PM
    2010bigdog
    Chuck
    Chicago
    those are the ones I was thinking about getting or the JBA but the JBA arms are only good up to 3" and I plan on going a tad higher. Not sure about the SPC arms and how high they are good for ?
  8. Apr 25, 2019 at 6:57 PM
    I've seen one member @Les7311 he on a 6" kit with those UCA's
    Les7311 likes this.
  9. Apr 25, 2019 at 6:59 PM
    Believe Zone Off-road UCA are good with 5"
    Some Fabtec ones for 4"
  10. Apr 30, 2019 at 7:10 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    The positive camber was corrected after I install the SPC UCA.
    I also have a write up on this....
    Black Wolf likes this.
  11. Apr 30, 2019 at 7:25 AM
    Black Wolf Unsupervised in Alamosa
    Yep....the adjustability of the spc's are a huge plus.
  12. Apr 30, 2019 at 7:28 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Try a different shop first before spending the cash on UCAs that’s my .02
  13. Apr 30, 2019 at 5:23 PM
    Les7311
    Good luck on that. My ToyUndra saw the alignment shop 4 different times , 3 different shops and non could correct that ghastly \ /.
    Purchased the SPC, did the install myself and BINGO!!!!!!
    As easy as changing the rotors and brakes on a car....
  14. Apr 30, 2019 at 5:40 PM
    2010bigdog
    Chuck
    Chicago
    Same here !
    Les7311 likes this.
  15. Apr 30, 2019 at 6:56 PM
    xtyfighterx
    Ty
    North Idaho
    That sucks. I’m at like 3.5” up front everything aligned fine each truck is driffetent but I’d defatinly get a second shop to look before I bought.
