Upgrading my 2018 Tundra JBL system
Discussion in 'Audio & Video' started by Surfanarchist, Jun 26, 2018.
  1. Jun 26, 2018 at 6:44 AM
    Surfanarchist
    Surfanarchist [OP] New Member
    Hello all,
    As the title says I'm looking to up-grade my 2018 Tundra Crewmax JBL audio system. I spoke with a very helpful person at Crutchfield yesterday about what my options where and it looks like I can replace the JBL amp with a Kenwood Excelon XR600-6DSP and a iDatalink Maestro AR Amplifier Replacement Module and keep the OEM JBL HU. Not cheap but fairly straight forward. The IDatalink Maestro interfaces with the Kenwood to decode the digital stream from the OEM JBL HU. That leaves me open to replacing the sub woofer and door speakers with what ever will fit. I could also then run from the Kenwood to a sub woofer amp.
    Has anyone out there done this? How did they like it? And my biggest question/concern - what if anything did you loose in functionality from the OEM set up? I'm concerned that this system might change how voice activation, nav system announcements, etc., and what ever else might be lost.
    Thanks,
    Wayne
  2. Jun 26, 2018 at 8:41 AM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    2010 Super White DC
    Following... I don't know of anyone who has replaced just the JBL amp with a different amp and a Maestro, but it sounds intriguing. If you go through with it and get it working definitely let us know as I know many of us would likely follow suit!
  3. Jun 26, 2018 at 8:44 AM
    Danimal86
    Danimal86 What's a Dickfir?
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I havent heard of anyone using that particular amp with the maestro, but i did hear about James at Tech12Volts thinks it was possible to ditch the jbl amp/processor and use a similar Audison dsp/amp.
    Pudge likes this.
  4. Jun 26, 2018 at 8:52 AM
    Cfincke
    San Antonio
    2002 Tundra SR5 with Fabtech adjustable coil-overs to level the truck
    I ditched the JBL amp by installing the Rockford Fostgate DSR1 and idatalink cable from James at T12V. I already had 2 JL amps I wanted to keep, so the DSR1 was my option. I did have a JL Fix86 prior.
    Pudge likes this.
  5. Jun 26, 2018 at 11:15 AM
    Surfanarchist
    The total configuration is the Kenwood Excelon XR600-6DSP ($800), iDatalink Maestro AR Amplifier ($100), and a iDatalink HRN-AR-TO3 cable ($30) if anyone is interested. Total cost is about $930 + power cable to the amp. I'm thinking of going with 1/0 gage wire so I can run both the Kenwood and a JL amp for the subs from a #4 split so that wire kit is $220 (scratch and dent!). So if I launch into this I'm in over $1000 before I know it. If I do this I will definitely keep everyone updated. I'm collecting data before I leap. Crutchfield's says this will work and I understand that they will take it back if I'm not happy but I don't want to start pulling up seats and removing door panels unless I am pretty sure it will work.
    That's great. How do you like it and did you loose anything (chimes, turn by turn nav instructions, Bluetooth, voice commands) making the switch?
  6. Jun 26, 2018 at 11:30 AM
    Cfincke
    San Antonio
    Bluetooth works as I stream from my phone all the time for music and nav. In the 2 years I have had the truck, I have never used voice commands or the navigation. I guess I need to test those.
  7. Jun 26, 2018 at 3:36 PM
    Cfincke
    San Antonio
    Tested the voice commands and nav turn by turn and they both work
  8. Jun 27, 2018 at 3:02 PM
    13igtymer
    13igtymer New Member
    2016 toyota tundra crewmax limited
    I had the jbl system on my 2016. I ended up changing the whole system. I went with a mixture of kenwood and alpine components. Very happy with it. Best feature is the android auto and mirror link.
  9. Jul 9, 2018 at 9:52 AM
    Surfanarchist
    Last week I jumped in and started my upgrade. In the rear I did three upgrades; I installed an ESP storage box, matted the rear wall, installed a JL Audio Stealth Box with twin 10"sub woofers and in the center storage box of the ESP I mounted a JL Audio 1000 watt sub amp. I've installed the 1/0 dual amp wiring set (Kicker, best price Wal-Mart on line) and from a block sent two 4 gage wires to the kenwood and the JL respectively. Under the passenger seat I installed a Kenwood Excelon XR600-6DSP iDatalink Maestro AR Amplifier, and a iDatalink HRN-AR-TO3 cable. In the dash I installed two Infinity Kappa 300 3.5" mids. The Kenwood has six channels as well as two RCA line outs so I feed the sub woofer amp through one set of the RCA line outs and channel 1/2 to the front doors, 3/4 to the dash, 5/6 to the rear doors. With the Kenwood built in DSP I can select via my IPhone and Bluetooth the frequencies for each speaker set. So I'm running what Kenwood calls "mid-high" to the dash speakers and "Mid" to the doors, of course "sub woofer" to the subs. I have not yet installed the new door speakers (I have JL component C2 600 for the front and JL C2 525 for the rear) but it sounds awesome even with the stock speakers. I'm going to sound deaden the doors and install the door speakers this week. The Kenwood has a 13 band EQ which I've not attempted to mess with. I'll do some fine tuning once the door components are in. The main thing is getting the proper frequencies to the speakers sets and learning how to use the Kenwood app to get everything configured.
    Issues - while Crutchfields says the dash speaker are a fit, it takes a lot to make them fit. I used a dremmal to remove three of four bolt ears and had to trim some of the rim of one speaker. I also had to trim just a little plastic from the dash mounting points. All invisible once the speaker covers are on and the speakers fit so tightly that just having one 10MM bolt on each is more than adequate. I also made no modification that would prevent me from putting the old speakers back if I so choose.
    The wiring diagram for the HRN-AR-TO3 cable is correct in showing you what wires go to each speaker set but it is incorrect on showing how to wire to the Kenwood. But once you understand how to use the Bluetooth app to configure the Kenwood it makes no difference. You can make any channel pair on the Kenwood anything you want. You select the position (dash, front, rear, sub woofer) anyway you want and you can send the correct set of frequencies to any pair. The last wrinkle is that center dash speaker. Right now I just have it doubled with the right dash speaker but I'm not sure I'll keep that. I might just disconnect the front center speaker as I'm not sure it gives me anything.
    All steering wheel controls work. Voice command works but the volume seems a little lower. You can adjust the hands free phone volume from the HU so I don't see it as a problem.
    I learned a lot doing this. I'll update this post when I get the door speakers installed.
  10. Jul 9, 2018 at 10:18 AM
    Danimal86
    Daniel
    Sacramento, CA
    Sounds like a baller setup! Which jl amp did you use?
  11. Jul 9, 2018 at 12:19 PM
    Surfanarchist
    JX1000/1. I don't do pounding bass. This thing just has quiet authority.
  12. Jul 9, 2018 at 12:41 PM
    Danimal86
    Daniel
    Sacramento, CA
    If i went with a separate mono amp, i was going to go with that one. hard to beat for that price.
    I'm pushing my stealthbox with probably only 400w and it pounds. I couldn't imagine what 800w would do.
  13. Aug 20, 2018 at 12:10 AM
    Dalkire1980
    Dalkire1980 New Member
    Dustin
    2018, Tundra, limited, 4x4, JBL
    I'm thinking of the Kenwood xr600, stock HU plus all stock speakers.
    I've always been a factory stereo guy. I just want to bring this system alive. Will the Kenwood alone do that?
    Thanks again!
  14. Aug 27, 2018 at 10:53 AM
    Surfanarchist
    Dalk...
    Assuming you have the JBL system than you would need the HRN-AR-TO3 cable and iDatalink Maestro AR Amplifier Replacement Module as well. The Idatalink serves to convert the output from your HU to signals that the Kenwood Excelon XR600-6DSP can understand. The HRN-AR-TO3 cable makes it all plug in play. The stock speakers are 2 ohm so that means the Kenwood would not drive them as well as 4 ohms speakers. Not sure if they would sound right for you or not. But if you went that route and kept the stock speakers you would soon know if you need to upgrade them or not. One thing about the Kenwood Excelon XR600-6DSP is that it has a very good equalizer built in so you can do a lot to make marginal speakers sound better. It's taken my two months to get this thing tuned the way I want but it sounds great now. Your stock speakers are designed to run with the EQ already set from the old JBL system. You will need to do a lot of EQ and distance adjusting so it does not sound like everything is coming from the two dash 3" speakers. Good luck.
    Dalkire1980 likes this.
  15. Aug 30, 2018 at 12:45 AM
    Dalkire1980
    Dustin
    Surf-
    Thank you sir. I'm having the Kenwood installed this coming Tuesday. Along with Idatalink and a T harness. My local shop has been around for 30 years. I'm trusting their experience on this one.
    Sticking with the stock speakers, hoping they dial them in properly. Might change the sub if it's terrible. I will update. Thanks for advice.
    SR5TRDTUNDRA likes this.
  16. Aug 30, 2018 at 5:49 AM
    Surfanarchist
    Just a few points from my experience. There are six channels in the Kenwood plus two sets of RCA outs. You can use either set of the RCA outs to power the sub-woofer as long as the sub-woofer has enough stock amplification (separate from the Kenwood) to drive it. I don't know if it does as I replaced mine with a big ol' sub and dedicated amp.
    Ideally you need two channels (left and right) for the dash, two for the front doors and two for the rear. That takes up the six channels. If you can't/don't drive the sub from the RCA outputs (they are lower gain) the you would have to run it off one of the six channels which forces you to double up the doors and/or dash speakers. Then there is the the center dash speaker. There may be some way to do a left/right combination but it's not as simple as summing one of the L/R channels without adversely effecting the other speakers on whichever of the six channels you're using. Your shop should know this and will probably recommend that you just drop off that center dash speaker. I did that and I don't miss it.
    I considered taking my rig to a shop just to do the EQ. It's that complicated. After playing with it for about a month I got it where I want it. Since the head unit is configured to work with all the stock stuff (amp under seat and stock speakers) it's really far off from what the Kenwood will output. That's ok as you can adjust it and make it great. For me I set it do go easy on high frequencies except the woofer which is flat on. The rule of thump is whenever possible reduce gain in the adjustable frequencies, don't make them higher unless you must and no more than 2-3 dbs of gain change between individual adjustable frequencies (small steps as you go higher or lower along the frequencies sounds better). Now what really made my set up sound good was telling the Kenwood that the dash speakers are zero distance from the driver (me) and telling the Kenwood the front door speakers where about 2.5 - 3 feet away. Back doors about 2 feet away. What this does is reduce the volume of the dash speakers (since the Kenwood now thinks they're right in your ear) and boosting the volume of the doors (which the Kenwood thinks are farther away). Like forward and aft fade but the fade in your HU does not give enough separation between the dash and the front doors. This got rid of the extreme brightness I had due to so many small (tweeter like speakers) in the dash and right there in your sail panels. All this goes out the window though if you need to double up the dash and/or door speakers to give you that channel you need for the sub-woofer because the gain on the RCA's is to low. Your shop guys probably already know all this but the Kenwood/Tundra JBL thing is pretty new and it's most definitely different than a non-JBL set up.
    Last thoughts. The front speakers are 6X9 paper conned and seam kind of cheap. However the rear door speakers are 5", polymer, and looked pretty nice. Except for the impedance match I might have kept them. I'm now driving all 4 ohm speakers, you will be driving 2 ohm (stock) speakers. At 3/4 volume I'm blasting. In your case with 2 ohm you'll have even more headroom. If you replace the door speakers down the road get rid of the tweeters in the sail panels and mount the new tweeters down close to the door speakers. Leave the sails empty or just disconnected. No one in audio thinks tweeters should be right in your face and that far from the woofers. There's plenty of room in the door speaker locations to mount the tweeters. If you replace any speakers I'd recommend you keep them all the same impedance.
    Good luck. I'd be curious how your set sounds when your shop is done.
  17. Sep 9, 2018 at 4:47 PM
    carman
    carman New Member
    CENTRAL PA
    17 Tundra 1794
    Kicker sub woofer, 1500 watt inverter
    The simplest easiest, most cost effective addition is to add a Kicker CompRT 43CWRT81 subwoofer. $149 from Crutchfield, 1 hr install if you can handle simple mechanics. Uses factory wires, nothing else to add, plug and play ( after you you use 1.5" self tapping screws-kicker/8 hoLes stock 6/holes). The factory amp will rock your mirror when heavy bass songs played.Everything else is totally stock.
    The Kicker sub is all the factory JBL system needed.
    Pudge and silverhack like this.
  18. Jan 4, 2019 at 5:33 AM
    Elendil
    Elendil New Member
    Surfanarchist, I was looking to do a similar upgrade as you have by adding the Kenwood XR600 DSP amp. Are you getting any static hum with the radio off or volume low? Are you still happy with your setup?
  19. Jan 4, 2019 at 10:16 AM
    carman
    carman New Member
    CENTRAL PA
    17 Tundra 1794
    extremely happy!!. least expensive, easiest upgrade to do. no hum crystal clear. my suggestion is (if you have the upscale JBL system with the 440watt amp) try just the woofer. if not happy add amps, etc. good luck ( i have the 17 tundra 1794 with the top line JBL/nav factory set up).
  20. Jan 16, 2019 at 7:47 PM
    ajscaife19
    ajscaife19 New Member
    AJ
    2018 Tundra Limited Crewmax 4x4
    6” Rough Country Lift 35” Toyos on 20” wheels Amp Power Running Boards Borla Exhaust
    Where can I find the info to know if I have the 440 watt amp?
  21. Jan 18, 2019 at 11:02 AM
    dekeray
    dekeray New Member
    2018 limited 4x4
    Trd rear sway bar
    Did you have any issues re-installing the seat (i.e. is the kicker speaker deeper than the oem?)?
  22. Feb 9, 2019 at 1:16 AM
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    Are all JBL systems 440watt? I’m curious if just changing the sub in the stock enclosure work out?
  23. Feb 9, 2019 at 3:26 PM
    phogallen
    phogallen My Last Mid-Life Crisis
    Kansas
    2019 Black 1794 Fusion Edition
    TRD Pro Grill, front bumper end caps, mirror caps and door handles blacked out. ATC Cap, Cap Pack 6 Gun Drawer, LED lights in CAP, Rhino rails on top, 12 volt accessory plugs. Weathertech floor mats, after market antenae. Ceramic tint film to driver and passenger door. Coachbuilder shims ,+2 shackles, steering kit, bumper shims, Bora 1.25 wheel spacers Bilstein 5100's on mid setting. BW flares with blacked out Route 66 screws. Gloss black powder coated OEM rims and Cooper 295/70/18 ST MAXX. Tech12Volt sound system upgrade...JL C2's doors and C1's on dash, 5 channel JL amp, 2 10inch subs in custom box and DSR1 sound processor...Soundskins in doors and back wall. Trunk and body badges removed. Powder coated tow hooks red. Linex bed lining front bra film and flares along with full ceramic coat. Cramic Pro interior plus windshield treatment. Toyota running boards and TRD anti sway bars in front and rear along with blacked out exhaust tip. TRD door latch cover plates. Full VLED light upgrade puddle, license, interior added footwell plus rear tail light brake, reverse. Added ASM turn signal LED's in front. OPT 7 tailgate light in red. Baja Design amber squadrons wc in front and SR2 Pro's in amber on rear bumper. Filmed reverse light in back, added red shackle on tow hitch and new license plate in front
    yeah I would switch out sub first...if not happy add an amp...if not happy add speakers with dsr1...if not happy replace dash speakers....if not happy something is wrong with yr hearing. Of course subject to products and set up. I ended up keeping the head unit and threw all other JBL parts in the trash.
    SpeshulED likes this.
  24. Feb 9, 2019 at 4:07 PM
    Pudge
    Pudge Sap Wizard
    CT
    2015 Blue Ribbon Platinum
    TRD PRO grille, OCD consol organizers, DIY wireless phone charger, 33" Michelin Defender LTX MS, Bak revolver X2 tonneau, weathertech liners, 20% tints. DIY pop n lock, 2018 LED headlights, morimoto fogs, TRD shift knob
    I have one of these subs for sale if anyone is interested
  25. Feb 9, 2019 at 7:48 PM
    SpeshulED
    Pardon my ignorance but what’s a dsr1?
  26. Feb 10, 2019 at 3:17 AM
    phogallen
    Kansas
    DSR1 is the sound processor sold by Rockford Fosgate...It basically helps clean up the sound coming from the JBL headunit while keeping the functions. There are various ones on the market and not really to be confused with very simple line processors which are inferior. Bottom line don't get one of these unless you upgrade the amp at the same time since the JBL amp would need to be disconnected and bypassed.
  27. Feb 10, 2019 at 9:51 AM
    SpeshulED
    Would replacing the door speakers and dash speaker sound any more clear with the kicker sub using the stock jbl amp?
  28. Feb 10, 2019 at 9:57 AM
    Pudge
    Pudge Sap Wizard
    CT
    We have a group buy going on right now for door and dash speakers that are a great upgrade for the JBL system.
    The kicker sub is a slight upgrade from the stick JBL sub but the box has its limitations. If you want some really good bass with the stock amp James at tech12volts has a 10" JBL sub and box for around $200 that sounds great. If you wanna try just the kicker sub I have one for sale that'll fit in your stock box.
  29. Feb 10, 2019 at 10:06 AM
    phogallen
    Kansas
    personally when you move beyond the sub upgrade to doors and dash I would seriously consider an amp upgrade as well. Try the the sub first and see how that sounds to you...
  30. Feb 22, 2019 at 12:47 PM
    SYRTundra315
    SYRTundra315 New Member
    Andrew
    2019 Super White Tundra CrewMax Platinum
    OEM nerf bars, BakFlip MX4, BedRug, VLED interior lights and license plate bulbs, JDM Astar turn signal and reverse bulbs.
    Hey - Has this setup been working out well for you? I am thinking of doing exactly this or using a similar shallow mount 8" sub. Just wondering if you are still happy with it.
    Thanks.
