UPDATED 02/02/23 - ULTIMATE Official MY22+ Tundra Technical Service Bulletin Thread - USA & Mexico
Discussion in '3rd Gen Tundras (2022+)' started by ryanwgregg, Dec 22, 2022.
  1. Dec 25, 2022 at 12:20 PM
    Dmon187
    Dmon187 New Member
    DFW
    2022 Tundra SR5 TRD OFF ROAD
    18x9 Method 316 wheels, TRD skid plate, Cat plate, Heritage grill with color match front end, TRD suspension OEM Lift kit with Toyo Open country At3
    Is this something they will correct when taking it in? Like a known recall or you have to mention this TSB?
    ChiefG likes this.
  2. Dec 25, 2022 at 12:57 PM
    ryanwgregg
    ryanwgregg [OP] MY22 PLT - IN THE GARAGE
    Ryan
    DFW, TX
    2022 Toyota Tundra Platinum 4x4 - 089/LA21
    ...OEM+ Mods... ..Coming Soon.. ...TIS Savant...
    These are NOT recalls. Mention the TSB number to you service advisor and tell them you’d like it performed.
    ChiefG and Dmon187[QUOTED] like this.
  3. Dec 26, 2022 at 9:10 AM
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    I have a service appointment in a while to replace a part what was damaged when I took possession of the truck. At that time can I ask them to perform any necessary TSB's? Or is a TSB something that has to be specifically requested based on a real problem? I'm thinking particularly about the transmission shifting TSB. My 1794 does not seem to have this problem now, but also seems reasonable to have them verify that it's software is the latest. Thoughts appreciated.
    ChiefG likes this.
  4. Dec 26, 2022 at 10:05 AM
    ryanwgregg
    Ryan
    DFW, TX
    Request that it be done while they have the truck. I’ve never had an issue with my dealership performing them even if I’ve never experienced the issue. I’ve had the symptoms described and the ECU update helped but didn’t fully resolve it.
  5. Dec 26, 2022 at 10:44 AM
    truckit
    truckit New Member
    Georgia
    2023 1794 MGM, AVS, power running boards, spray in bed
    Thank you VERY much for doing this ryanwgregg. I have a clarification for the community regarding T-SB-0070-22, 'Rear Air Suspension Feels Rough Over Bumps'. I have a '23 model year and though listed here as 2022 only problem it WAS a fix that needed to be performed to my 2023 1794 non-hybrid with a 10/14 build and 12/10 delivery date.
  6. Dec 26, 2022 at 11:46 AM
    Paul Moll
    Paul
    Idaho
    Will do ryanwgregg. Good input, thanks.
  7. Dec 29, 2022 at 3:45 PM
    dutchydawg
    dutchydawg New Member
    Scott
    2022 Toyota Tundra
    You are amazing! I appreciate you taking the time to do this. You are a rock star, seriously!
    I went into the dealer and they looked at me like I grew a third eye when I explained what was happening.
    After coming home and researching I found this. I called them back and miraculously they knew what I was talking about even though my description of the problem was almost identical to the wording in the TSB.
    Found a couple other ones they can work on now. So one issue turns into three.
    And I played nice but since this is a safety issue I got in much earlier than they had me originally scheduled for when I dropped in.
  8. Dec 31, 2022 at 4:39 AM
    Adam B
    Adam B New Member
    2022 Tundra TRD OFF-RD LIMITED- Green
    Thank you for this post.
    ryanwgregg[OP] likes this.
  9. Jan 1, 2023 at 7:00 PM
    Ope311
    Ope311 22' SR5. Cool Truck.
    South Dakota
    2022 Tundra SR5
    Wheels, TRD Pro flares, tint. 2/3" drop pending...
    TSB's are to be performed when and only when the concern is present and verified. The bulletins are so that the proper fix is performed consistently by technicians to factory spec.
    When I was a service advisor they helped investigate concerns but when someone is standing there demanding or expecting to go down the list and perform them like a safety recall.....it takes everything, and more to not hit them with a dipstick when they are unable to understand or except the process needed.
    Perfect resources for every model.
    truckit and ryanwgregg[OP] like this.
  10. Jan 12, 2023 at 12:18 PM
    ArmygreenTRD
    ArmygreenTRD New Member
    2022 Army Green TRD, SR5 DC
    @ryanwgregg Can you post TSB 0134-16 that is referenced in clunk and surge TSBs? TIA
  11. Jan 13, 2023 at 8:24 AM
    ryanwgregg
    Ryan
    DFW, TX
    Added T-SB-0134-16 to the posts for T-SB-0110-22 & T-SB-0111-22.
    ArmygreenTRD[QUOTED] likes this.
  12. Jan 13, 2023 at 11:41 AM
    nodak67
    nodak67 New Member
    JR
    23 Tundra Platinum Blueprint CM 4x4 Non Hybrid
    anyone heard of the "a" pillar air bag issue? or is there one? heard that the qc hold was due to this
  13. Jan 13, 2023 at 2:35 PM
    ArmygreenTRD
  14. Jan 13, 2023 at 3:13 PM
    ryanwgregg
    Ryan
    DFW, TX
    This would be news to me. It could also be related to an installation issue with that particular airbag causing the leaks that some are experiencing.
  15. Jan 16, 2023 at 7:23 AM
    minh
    minh New Member
    @ryanwgregg excellent thread, thank you!!
    question, does anyone know how much effort is needed for these TSB? is it an hour of work? 5 hours? etc...
    • T-SB-0110-22 MY22+ Tundra: Pop/Clunk Noise on Initial Engine Start (Cold)
    • T-SB-0111-22 MY22+ Tundra: Hesitation From Stop and Surge Concerns
  16. Jan 16, 2023 at 7:28 AM
    ryanwgregg
    Ryan
    DFW, TX
    Depends on the service department and how busy they are that day and how knowledgable they are about this process. Mine wanted to be sure I had the issues before performing them. They did a quick test drive and felt the hesitation. The clunk couldn't be heard because it had sat overnight and was started to get the dealership. The clunk, for me, happened the most when it had say for long periods of time.
    The actually flash process is probably 30-45 minutes. Mine took 3 hours because of how busy my local dealership was that day.
    minh[QUOTED] likes this.
  17. Jan 16, 2023 at 2:43 PM
    Maharisc
    Maharisc w/
    Karl
    2023 Tundra Platinum CM MBM Adv Pckg
    Build date: 12/05/22
    Dropped my truck off today at 9am for 10k and both of those TSBs. Tech had 1 hr lunch during that time, and it was ready to go at 2:40 pm. They will test to see if they can duplicate, then perform TSB, then test again to see if it made a difference - that's what I was told.
  18. Jan 18, 2023 at 5:52 AM
    ryanwgregg
    Ryan
    DFW, TX
    TRD Pro Specific T-SB-0004-23 has been added.
    Production Change Effective VIN - 5TFPC5DB#NX009672
  19. Jan 18, 2023 at 7:23 AM
    #49
    tundradude21
    tundradude21 New Member
    When it says it effects trucks with a production change effect VIN, does that mean any vin with a higher VIN is not effected? My VIN is 5TFPC5DB1NX009979
  20. Jan 18, 2023 at 7:28 AM
    #50
    ryanwgregg
    Ryan
    DFW, TX
    Correct. Higher last 6 means it SHOULD NOT be affected.
    tundradude21[QUOTED] likes this.
  21. Jan 19, 2023 at 8:04 AM
    #51
    TopDawg1776
    TopDawg1776 New Member
    2022 Tundra TRD Pro Solar Octane
    My Pro is in the effected trucks, I cannot tell if the spring is bowed or not. Can I just schedule an appointment like usual and want this TSB checked out?
  22. Jan 19, 2023 at 8:11 AM
    #52
    extremes074
    extremes074 New Member
    David
    West Coast, Florida
    22 1794 TRD Off-Road
    Thanks so much. The loud clunk issue has made me wonder several times...
  23. Jan 20, 2023 at 4:47 AM
    #53
    ryanwgregg
    Ryan
    DFW, TX
    Yes.
  24. Jan 20, 2023 at 4:49 AM
    #54
    TopDawg1776
    Brought the truck in today, needed and alignment anyway, it hasn't driven straight since I've had it. They said theyd look at it while it was on the rack.
  25. Jan 20, 2023 at 5:03 PM
    #55
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    Appreciate you providing these for us. I've been trying to track down the root cause of a hesitation in high gear, and turns out there is a TSB for hesitation from start and / or 8th gear. What would you know! Thanks Ryan.
  26. Jan 25, 2023 at 4:27 PM
    #56
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    2022 Tundra Limted TRD
    Thank you for posting these. My Canadian dealership was able to find the CDN equivalent numbers for throttle lag and trans clunk, 5585 and 5586. Both done with same TCM update. Might be placebo, but truck does feel like it has superior throttle response than before. There's a stop sign on a hill on my street where it always lagged noticeably, doesn't lag at all now at that same spot. Without these TSBs, I suspect the dealership might have thought I was just being a complainer instead of pointing out a real issue that many others are experiencing.
    For example: I had the ticking noise (that a handful of others have pointed out here) at the driver's side A-pillar; tech initially said it was ice around the panoramic sunroof. Uh, hard no, I know what that sounds like. Someone later determined noise was from "windshield locator tabs" under the headliner. Apparently these tabs are used at the factory to ensure proper placement of the glass during assembly. Appears the tab on the driver's side had moved somehow (think a piece of foam had fallen or shifted) and the tab was making contact with the front glass — driving me crazy with a constant but irregular tick, tick, tick that was almost as loud as my signal indicator. May be a future TSB.
  27. Jan 26, 2023 at 7:23 AM
    #57
    JJtruckon
    JJtruckon New Member
    JJ
    2018 Tundra
    Undercoating
    Great examples to wait 2-3 years after a new product is introduced. 2024-25 all these bugs will be worked out. And some additional updates will be introduced.
  28. Jan 26, 2023 at 1:36 PM
    #58
    truckit
    truckit New Member
    Georgia
    Yes, but at what price? It's such a personal thing especially at current prices.
  29. Jan 26, 2023 at 1:59 PM
    #59
    ryanwgregg
    Ryan
    DFW, TX
    You do realize that the MY21 Tundra, which had been out since 2007 with the 2014 facelift, had quite a few TSBs as well...so who's to say that the MY24-25 will be any better than the MY22 Tundra...and if Digital Key comes to the MY24+ Tundra (I'm hoping the MY22+ has the ability, just needs a firmware/software update), I would venture to say that their will be even more TSBs, but what I do I know with access to TIS and all.
    MY20 Tundra - 6 Safety Recalls and 40 listed TSBs (not all Tundra specific)
    MY21 Tundra - 5 Safety Recalls and 34 listed TSBs (not all Tundra specific)
    MY22 Tundra - 5 Safety Recalls and 25 listed TSBs (not all Tundra specific) - I will update this model year as need be.
    And the shocker of them all for me....
    MY19 Tundra - 12 Safety Recalls and 36 listed TSBs (not all Tundra specific)
    dekeman and JJtruckon[QUOTED] like this.
  30. Jan 26, 2023 at 3:52 PM
    #60
    ArmygreenTRD
    @ryanwgregg I don’t understand the (not all Tundra specific)?
