Unsuccessful install attempt with Demello Sliders
Discussion in '2.5 Gen Tundras (2014-2021)' started by Brimaster, Apr 30, 2018.
  1. Apr 30, 2018 at 5:13 PM
    Brimaster
    Brimaster [OP] New Member
    2017 Magnetic Gray Metallic DC TRD
    Tried to install the Demello Dominator sliders I picked up from the_midwesterner over the weekend and it was a frustrating afternoon. :mad:
    Got the driver side up to the frame and started to bolt it up and the back side of the slider is hitting the bracket from the gas tank causing it not to mount flush with the frame. Maybe because I have the 38 gallon tank? Cussed and pulled it back off.
    Looked at the passenger side and there is a couple of plastic line holders on the inside of the frame protrude out which I think would affect the slider mounting flush to the frame. I did not think it would be smart to disconnect them and not have support for those lines.
    I sent a quick note to Demello but thought I would see if anyone had the same issues and had a solution you used.
    Thanks in advance for any input.
  2. Apr 30, 2018 at 5:37 PM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    Yeah. Thanks for posting. Will avoid those like a plague.
  3. Apr 30, 2018 at 5:47 PM
    Professional Hand Model
    Hand Protectors
    Anyway to grind off that little bit of the slider where it hits the bracket?
    15whtrd likes this.
  4. Apr 30, 2018 at 5:53 PM
    Hand Protectors
    For the passenger side measure and identify the hole locations where your ‘plastic line holders’ are currently and mark the locations on the sliders. From this point you could drill and remount the new bolts through the slider with longer screws OR counter drill the locations on the slider so the existing bolts heads recess into the slider. Ideas. Hope it helps.
    theraven, Sunnier and 15whtrd like this.
  5. May 3, 2018 at 5:37 PM
    Brimaster
    Thanks for the replies everyone....
    I heard back from Jason and he said the older version of those sliders had a bracket plate that didn't fit the frame on the new tundras with out modification. But they changed that about a year or two ago.
    He said cutting/grinding the metal of that section to fit around the bracket is okay and will not affect the slider and has been done successfully in the past.
    I am leaning toward your suggestion for the pass side Professional Hand Model as that was running through my mind as well.
    Give it a try in a couple of weeks...
    Thanks again....
    NewImprovedRon likes this.
  6. Sep 23, 2018 at 4:21 PM
    Brimaster
    Well, finally took the time to try again to get these installed. Last weekend did the passenger side. Did not worry about the plastic holders and left them in place. Had to unclip the lines from one to be able to get to one nut to tighten it. After that side was all tight it pushed the plastic clips away from the frame but they are snug and do not look like they move. Just to be safe I did cut a small section of rubber hose to protect one of the lines from the nut and bolt end. Drove for a couple of days with just the one side on.
    Then, during the week I took a day and got the driver side laid out and marked the metal that needed to be removed and got the cutting wheel and took off the section that was hitting the bracket from the larger gas tank. Then did the hand grinder/sander to clean up the area and shot it with a rattle can of Rust-Oleum .
    Let it dry and got it installed on friday. Other then trying to get to the bolt by the gas tank everything went on fine.
    One thing I did not do is drill the bottom holes on each side but being not going off road anytime soon for the added strength and have time to get to those but will need a lift to do it right.
    It was a pain but finally getting them on I really like them.....
  7. Sep 23, 2018 at 5:13 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
  8. Sep 23, 2018 at 5:17 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    :popcorn:
    joonbug[QUOTED] likes this.
  9. Sep 23, 2018 at 7:26 PM
    nodnero
    nodnero I'm here legally yo!
    Temecula, CA
    Cement 2018 Limited 4x4 Crewmax
    18x9 Method 312 285/75R18 Toyo R/T Trail TRD Pro Suspension
    :pccoffee: I’ll just join the wait here for pictures...
  10. Sep 23, 2018 at 11:59 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    Man... good to see that you got them on. Sorry about not posting to help, but I didn’t see that I got tagged in this months ago. Also, didn’t we do this deal back in February..? You sir are a patient man!
    As others have mentioned, let’s see some pics.
    ColoradoTJ likes this.
  11. Sep 26, 2018 at 9:54 AM
    Brimaster
    I knew i should have posted pics and i didn't so the hate is deserved. :crapstorm:
    Just took a couple quick pics a few minutes ago so hope this works.
    Here is the cut bracket on the driver side.
    Here is the passenger side line pic.
    Side shot passenger side.
    Side shot driver side.
    NewImprovedRon and Black Wolf like this.
  12. Sep 26, 2018 at 9:59 AM
    Brimaster
    Yep, was last year when I met you and I picked these and the skid plate up on that cold winter day in Terre Haute. :)
    As they say good things come to those that wait.
  13. Sep 26, 2018 at 9:59 AM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    yet another reason to get weld on sliders.
    Thegr8punkin and Black Wolf like this.
  14. Sep 26, 2018 at 10:37 AM
    d0zer
    d0zer I beat the internet.
    Definitely somewhere
    2017 MGM Platinum
    ADS 3.0" & 2.5" AllPro APEX Sliders SCS SR8 on Cooper ST MAXX 295/70r18
    I had a similar problem with my apex sliders, had to cut out a section for that same support bolt/line.
  15. Sep 26, 2018 at 1:27 PM
    the_midwesterner
    Luis
    None, yet....
    I hear you. Good to see you got them on.
  16. Sep 26, 2018 at 1:55 PM
    Thegr8punkin
    Thegr8punkin A G.D.M/Sofa King Cool/COTJ's dreamboat
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    When are you getting sliders?
  17. Sep 26, 2018 at 2:11 PM
    speckmon
    Thornton, CO
    got 'em!
    Thegr8punkin[QUOTED] likes this.
  18. Sep 26, 2018 at 2:13 PM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Hell ya!
    speckmon[QUOTED] likes this.
  19. Sep 26, 2018 at 2:21 PM
    speckmon
    Thornton, CO
    that's right, i'm protected. and they didn't cost me my left nut like these off the shelf sets.
