Under carriage coating
Discussion in 'General Tundra Discussion' started by TXRailRoadBandit73, Oct 28, 2016.
  1. Oct 28, 2016 at 7:14 AM
    TXRailRoadBandit73 [OP] YOTAS,RAILROADIN',RÖKnRÖLLN',BEER,MAX/GEMMA
    Anyone done or recommend doing under carriage coating??? Is it worth it???
  2. Oct 28, 2016 at 2:43 PM
    I remember back in the day my dad n uncles went to a place that was a ziebart dealer n did their whole trucks underneath
  3. Oct 28, 2016 at 3:11 PM
    joeguam
    joeguam New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
    That is why the old cars stayed in good condition. My belief is that the companies nowadays want it to rust/fall apart quicker to keep selling number consistent more often than later.
    TheBeast likes this.
  4. Oct 28, 2016 at 3:12 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    My next truck i'lol be getting undercoating done. It looks awesome.
  5. Oct 28, 2016 at 3:15 PM
    joeguam
    joeguam New Member
    JOE
    I grew up with an old fashion thinking and did mine.
    In process undercoating using the BMW undercoating formula at LINEX
    Motor71 and NewImprovedRon like this.
  6. Oct 29, 2016 at 2:29 AM
    Motor71
    Motor71 teufel hunden
    Rob
    New Jersey
    2016 tundra platinum
    TRD sway bar, matching mirror cover, 20% tint, esp aluminum box, Line-X premium, Undercover Flex tonneau cover, led interior lights, winjet smoked tail lights. Road armor rear bumper w/ road armor shackles, go rhino front bumper.
    How much did it cost you to do it?
  7. Oct 29, 2016 at 3:20 AM
    HWU
    HWU We like white!
    N.W. Ohio
    2003 White Tundra SR5
  8. Oct 29, 2016 at 3:31 AM
    HWU
    HWU We like white!
    N.W. Ohio
    I recently bought a 2003 Tundra, yes the frame has rust, but, nothing really bad, surface and scales on it. No holes, nothing rusted through. "OUR" biggest deterent of under body damage is the "brine" that our nations "road" dept's are using to melt ice. I have seen 2014 Tacomas frames rusted completely through. (Friend is a mechanic) at a Toyota dealership. Whatever year of truck you have...and your area uses brine....have it under coated. Me? I was in touch with a company called "The Rust Store" emailed them pictures of the frame ....asked them what they recommended. Within one day they responded! Couldn't believe it. Dan, the tech guy there said I should use a product called "Rust Bullet Paint" in a nutshell.....it stops rust and prevents any further damage. One coat...no top coat. If you have questions ...this site has answers....check it out....."The Rust Store"
    GNTundra likes this.
  9. Oct 29, 2016 at 4:55 AM
    PermaFrostTRD
    Northern NY
    If you've already been bitten by rust from road salt or brine as described previously and are looking to stop and prevent further issues check out POR-15 (stands for paint over rust).
    I used it on my old Sierra worked as advertised as long as you prepped properly(remove flaking or peeling rust) and applied properly (follow humidity and temp guidelines).
    The stuff is a beast though. Respirator and eye-pro a must. I'd also tyvek it or wear some old clothes you don't mind throwing out. Wrap your head and face in a tshirt too. It doesn't come off of your skin for about a month.
    HWU likes this.
  10. Oct 29, 2016 at 5:22 AM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    fluid film is the way to go. regular undercoating traps moisture and causes rust. you can even spray fluid film on over rust and it will stop it from rusting further
    PermaFrostTRD and NewImprovedRon like this.
  11. Oct 29, 2016 at 7:07 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I too like POR 15. I put it on my boat trailer and it's been holding up well for years. Pretty amazing product.
  12. Oct 29, 2016 at 9:35 AM
    joeguam
    joeguam New Member
    JOE
    I believe $300. I has been a awhile and do not recall the actual.
  13. Nov 1, 2016 at 8:14 AM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Is there anything under my truck that can be damaged by Fluid Film or can I pretty much spray it everywhere?
  14. Nov 1, 2016 at 8:32 AM
    PermaFrostTRD
    Northern NY
    I would also like more info on this.
    Looks like there's was black paint/undercoating sprayed on my truck. Doesn't look super thick. The fluid film site / FAQs indicate it might soften existing coatings and or paints.
    If I read it correctly. Lol.
    Tundraplatinum likes this.
  15. Nov 1, 2016 at 9:20 AM
    TRD Pro Rookie
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    How many cans should I buy?
  16. Nov 1, 2016 at 9:42 AM
    TRD Pro Rookie
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Just bought 3 cans, figured I could use it on my other toys.
    NewImprovedRon likes this.
  17. Nov 18, 2016 at 2:10 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Well I took your advice and splurged for a respirator and tyvek suit. Rocked eyewear as well, my neighbors thought I was headed to the moon but wow was it worth it.
    Great advice!
    joonbug, 831Tun and NewImprovedRon like this.
  18. Nov 18, 2016 at 5:22 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    :thumbsup: Great stuff, I've got it on my boat trailer, nasty to work with though.
    MotoTundra likes this.
  19. Nov 20, 2016 at 3:16 PM
    joeguam
    joeguam New Member
    JOE
    Yes, it will soften the undercoat. Not sure about paint though.
    PermaFrostTRD[QUOTED] likes this.
  20. Nov 20, 2016 at 3:38 PM
    SDNY
    SDNY New Member
    Castleton NY
    2024 Sequoia Sonic Red
    I had mine done at the dealer when i purchased the truck. They discounted $500 of the $1000 price. They also included the paint protection as well as interior fabric protection. I looked underneath when i got the truck back and they covered everything. Nice job they did. Was it worth it? In my opinion, yes.
  21. Nov 20, 2016 at 3:40 PM
    PermaFrostTRD
    Northern NY
    My CPO was coated with a black coating. Thicker than paint.
    Didn't cover *everything* but I hit the leaf springs (in between) and a couple of rusty bolts, inside of C-channel frame etc. with the fluid film. we'll see how she does.
    *edit* Getting our first storm now. I'll post a T.I.T.S. pic tomorrow.
  22. Dec 4, 2016 at 3:37 PM
    PermaFrostTRD
    Northern NY
    Just sprayed some fluid film on an old rag and gave the wheels a wipe down with it after washing it today.
    Obviously didn't want to spray directly onto the wheels but I figured this might help fight rust from the awful brine they put on the roads up here.
