Under Cabinet LED Lighting 12 volt
Discussion in 'Home Improvement' started by LennyFL, Sep 11, 2020.
  1. Sep 11, 2020 at 8:10 AM
    LennyFL
    LennyFL [OP] New Member
    New to me 2007 with 59,600 miles
    I'm trying to find under cabinet LED lighting for my kitchen. It already has 12 volts to the existing incandescent lighting. It is switched at the wall. I don't need converters just LED lights that I can wire to the existing 12 volts wires.
    The next problem is they are all not in line there are three separate areas separated by the oven and sink, see attached.
    What kind of LED's can i get? They all come with there own kind of converters and connectors. Any ideas? I just want to wire them to the existing wiring.
  2. Sep 11, 2020 at 8:48 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    What's the wattage of your power supply. The longer the strip you have, the more wattage it requires.
    You can get under cabinet led strips from Amazon with no power supply. There an extension connector available for the specific style you select.
  3. Sep 11, 2020 at 9:14 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
  4. Sep 11, 2020 at 10:00 AM
    LennyFL
    I've keep finding only LED strips with power supplies do you have a link to a specific model in mind?
  5. Sep 11, 2020 at 10:02 AM
    LennyFL
    I have a wall switch to the power supply. I don't really need a remote.
    Thanks,
    Lenny
  6. Sep 11, 2020 at 10:15 AM
    Azblue
    The Dirty T ( ^_^)_且
    Tundra2 and SprinterAE86 like this.
