Under body rust proofing
Discussion in '2.5 Gen Builds (2014-2021)' started by PaulROahu, Feb 8, 2017.
  1. Feb 8, 2017 at 11:50 AM
    PaulROahu
    PaulROahu [OP] New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    Reaserching for a good under body rustproofing. Question is what type is a good way to protect my underbody from rusting. I life close to the ocean with salt water about 200 yards from ocean bay and will be parked under a car port under my house so I want to protect my truck as much as possible. Any advice, recommendation and pics would be greatly appreciated. Would it be hard to do it myself or have it done professionally?
  2. Feb 8, 2017 at 12:17 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Fluid film. Tons of threads on it. It's sold at home improvement stores as well as a lot of auto parts stores.
  3. Feb 8, 2017 at 12:18 PM
    TheBeast The Beach
    Fluid Film is usually recommended here
    NewImprovedRon likes this.
  4. Feb 8, 2017 at 12:19 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
  5. Feb 8, 2017 at 12:19 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Can you give a good name brand and how many cans will I need to get a good coat on?
  6. Feb 8, 2017 at 12:23 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Fluid film is the name of the brand. 4-6 cans would be plenty
  7. Feb 8, 2017 at 12:24 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
  8. Feb 8, 2017 at 12:27 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Thanks Kevin for the video, look easy and NO sanding required? Any one done this to there Tundra or something else.
    BlueFalconActual likes this.
  9. Feb 8, 2017 at 1:04 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    No problem. Lots here have done it including me. It's not bad to do. A little messy and a little smelly a few drives after but it works great.
  10. Feb 8, 2017 at 1:09 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Just saw couple utube videos. I'll do this after my instal. Saw them spraying on anything metal: frames, underbody, rear axle, leaf springs, inside metal holes and openings, is that what you guys did?
  11. Feb 8, 2017 at 2:32 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Correct. Minus the exhaust of course.
    PaulROahu[QUOTED][OP] likes this.
  12. Feb 8, 2017 at 3:41 PM
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    I had the local line-x guy spray mine with Krown. They guarantee no rust if the truck is new and if you get it redone annually. I also happened to spray it myself right before winter with fluid film. Ounce of prevention and all, you know.
    NewImprovedRon and Krezz like this.
  13. Feb 8, 2017 at 3:59 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Just spray over the rust with black paint and forget about it. :)
    Sunnier, tundraforme and TheBeast like this.
  14. Feb 8, 2017 at 4:11 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Great news: just got my vin# and shipping notice for my new 2017 Tundra Platinum 4x4 MGM. eta end of Feb... now will be able start my build thread
  15. Feb 8, 2017 at 4:14 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Thanks guys I will do the fluid film treatment
  16. Feb 12, 2017 at 8:01 AM
    Quartermeter
    Quartermeter New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
    sounds like a good inexpensive method to prevent rust. Does fluid film eventually dry? I've used NAVEL JELLY ON RUST. It covers it, creates a chemical reaction, turns it black and stops the rust. N JELLY needs rust to work.
    If I have NO Rust will the FLUID FILM prevent rust? Again does it ever dry???
  17. Feb 12, 2017 at 8:07 AM
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    Paint wont stick to rust. They need something to stop the rust near rhe beach and up north. FF sounds good if it will eventually dry.
    I got the front mats they work well.
  18. Feb 12, 2017 at 9:21 AM
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    Will it wipe off a year after applied? Will driving thru lots of water or pouring rain rinse it off? Not knowing I would say yes to all 3 above.
    I'm trying to understand how it stays on... Tell me how how it stays on long term??
  19. Feb 12, 2017 at 9:31 AM
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    Lots of chemicals cure and stay pliable but are dry to the touch. When I hear DOES NOT DRY I think it's wet to the touch.
    Pliable is good. Silicone rubber is PLIABLE but it dries oUT or CURES and is not tackey or wet to the touch. And it won't wipe or rinse off. Maybe a better description for Fluid Film is it CURES but is still flexable.
    But is FFilm still WET or TACKEY?? Hopefully not. Thanks just trying to understand.
  20. Feb 12, 2017 at 2:39 PM
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    Thanks for the info. I learned something today.
  21. Feb 14, 2017 at 8:17 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Scribed
  22. Feb 16, 2017 at 5:00 PM
    thinblueline54
    thinblueline54 New Member
    2017 Tundra TRD Offroad
    20" Rockstar wheels, PIAA led headlights, plasti dipped badges, TRD dual exhaust, TRD CAI, window tint, Tonopro cover
    Be careful with Fluidfilm. I had a 2016 Silverado and sprayed that stuff under it and two days later all the wax (black coating) came off the frame!!! Fluidfilm repsonded by only stating "that happens sometimes".
    WTF !?!?!
  23. Feb 16, 2017 at 5:08 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Great to know, I'll probably try a small part and see if anything happens. So what did you end up doing thinblueline54 with your truck underbody?
  24. Feb 16, 2017 at 5:20 PM
    thinblueline54
    I traded it but lost my ass. Fluidfilm ruined the frame, ate all the coating off to the bare metal that then started to rust. Really, stay away from that stuff!
    PaulROahu[OP] likes this.
  25. Mar 9, 2019 at 9:43 AM
    Jeepcjaholic
    Jeepcjaholic New Member
    Mark
    2019 TRD crew max
    Been using fluid film for years both at work and on personal vehicles and I swear by it. I also use POR15 with a top coat of Tremclad paint to protect it from UV’s. Been using this method of my 80 series Landcruiser and my Jeep Rubicon and has saved both and will do the same on my 19 crewmax as well. Also wash your undercarriage ever time you wash your vehicles to remove salt dirt build up and grime.
