Ultimate OEM Toyota Parts Thread for 2nd gens (2007-21)
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Feb 16, 2017.
  1. Oct 14, 2019 at 8:08 AM
    #2131
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Not that I'm aware of, no. It would require more than just a switch for it to work too. You would need all new window motors that have the auto function as well.
  2. Oct 14, 2019 at 8:11 AM
    #2132
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    @Roman am I able to buy a bumper cover? Need one for a 2012 Rav4 Base 4cyl, 2WD.
  3. Oct 14, 2019 at 9:20 AM
    #2133
    Roman
    Roman
    Franklin, TN
    If you were local, you could pick one up from us. Bumper covers are one of the large body items that we are unable to ship.
  4. Oct 14, 2019 at 9:40 AM
    #2134
    FirstGenVol
    East TN
    2002 AC
    I'm actually passing through Nashville on Friday. Give me an estimate if you don't mind. I'm assuming they come unpainted?
  5. Oct 14, 2019 at 9:43 AM
    #2135
    Roman
    Roman
    Franklin, TN
    Sure thing. PM me your VIN and email. I can shoot you over a quote for it for pick up. They do come unpainted.
  6. Oct 15, 2019 at 11:26 AM
    #2136
    spyshot
    spyshot New Member
    Ohio
    2019 Tundra Platinum
    Hey can anyone tell me the difference between the following numbers? 53911-0c050 and 53911-0c090? I'm looking to replace the front valance on my platinum to black like the TRD Pro. @Roman
    Thanks
  7. Oct 15, 2019 at 11:36 AM
    #2137
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    @Roman i know you’ve posted before but what’s the part number/link to a 2017 SR5 center console lid?
  8. Oct 15, 2019 at 12:54 PM
    #2138
    Roman
    Roman
    Franklin, TN
    The black one you're looking for is part # 53911-0C050. The 53911-0C090 is the gray one from the 1794 model.
    Here you go:
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-armrest-589050c140c1
    PLC721[QUOTED] likes this.
  9. Oct 15, 2019 at 1:23 PM
    #2139
    spyshot
    spyshot New Member
    Ohio
    Thanks
    Roman[OP] likes this.
  10. Oct 15, 2019 at 2:06 PM
    #2140
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    @Roman - need your help. I've got a 2019 SR DC and want to do the LED Fog light upgrade and would like to confirm if I've got the right parts. I get conflicting information on the relay part number. Here is my list of what I think I need:
    bezel trim: Driver (LH): 52128-0C070; Passenger (RH): 52127-0C070 (I assume I need these to replace the blank bezel covers I have now?)
    Relay: 90080-87026 (the parts store tells me to use P/N: 90080-87024...?)
    Head light stalk 84140-07113
    black fog light: PT41342191
    Thanks for the help!
  11. Oct 16, 2019 at 6:08 AM
    #2141
    azTony
    azTony member since sept, 2017 and over 1,600 messages
    Tony
    Sun Lakes, AZ
    @Roman can you help me find part numbers and pricing for my front sway bar? I removed it since it rubs on my icon 3.0’s but now the wife wants hail a trailer and no way I am hauling without the sway bar.
    I have a 2018 Platinum
    I need the 4 bolts and associated washers for the metal brackets that bolt to the frame
    I need the 2 bolts and associated washers for the sway bar ends that bolt to the LCA
    thanks in advance
  12. Oct 16, 2019 at 6:51 AM
    #2142
    Roman
    Roman
    Franklin, TN
    Yep, those part numbers are correct. You will also need 2 of these little blue clips as well. 75392-0R010
    Sure thing. Do you want the stock sway bar, or do you want to upgrade to the TRD front sway bar? I'll include both part numbers for you.
    Stock sway bar
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-stabilizer-bar-488110c020
    TRD Sway bar
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-trd-sway-bar-front-red-ptr620c180
    Hardware
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-stabilizer-bar-screw-90119a0192 x4
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-bolt-w-washer-90119a0278 x2
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-nut-flange-90178a0085 x2
  13. Oct 16, 2019 at 8:44 AM
    #2143
    dugfur
    dugfur New Member
    doug
    2016 limited DC
    Roman, can you price me a set of bedrail caps for a 2016 DC please? THX
  14. Oct 16, 2019 at 9:03 AM
    #2144
    Roman
    Roman
    Franklin, TN
  15. Oct 16, 2019 at 10:28 AM
    #2145
    danno266
    danno266 n00b
    2016 White CM SR5/TRD OR
    Curious about the difference between these items. Anyone know?
  16. Oct 16, 2019 at 10:48 AM
    #2146
    War Machine
    War Machine SSEM # 5 3MW
    @Roman what percentage of questions on this thread can be found by just going to your site and looking it up ourselves? TIA
  17. Oct 16, 2019 at 11:03 AM
    #2147
    dugfur
    dugfur New Member
    doug
    2016 limited DC
    not everyone on this forum has time to sit in front of computer and look for parts. its faster to post a question and come back at a later time and have the answer or part number...………………...
  18. Oct 16, 2019 at 12:55 PM
    #2148
    Roman
    Roman
    Franklin, TN
    There is a difference between the two. The 81210,81220 numbers are the factory LED fogs, where the PT413 number is an accessory knock off basically. I do not know if there is a difference in light output between the two.
    Probably not a lot, honestly. You would have to know the Tundra parts inside and out by going to the store and searching for answers. The OP of this thread does a good job of explaining a lot of the most popular parts.
  19. Oct 16, 2019 at 1:11 PM
    #2149
    War Machine
    I hear he’s terrible at Destiny though.
    Roman[QUOTED][OP] likes this.
  20. Oct 16, 2019 at 1:13 PM
    #2150
    Roman
    Roman
    Franklin, TN
    He is. He just went on a 9 game win streak in comp the other night. Basically a kinderguardian. :D
    War Machine[QUOTED] likes this.
  21. Oct 16, 2019 at 1:17 PM
    #2151
    War Machine
    I haven’t played it in quite a while, but I had at least a 2:4billion KDR back in the day. (Pretty sure the two guys I killed were on a bathroom break.)
  22. Oct 16, 2019 at 1:52 PM
    #2152
    Roman
    Roman
    Franklin, TN
    We all have to start out somewhere. ;)
  23. Oct 16, 2019 at 3:53 PM
    #2153
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Hey Roman
    I need the window gaskets/trim for a 2007 Crewmax. The bottom trim gasket on passenger side has ripped, and figured I should just bite the bullet and replace them all. Y'all carry these as a kit or do I need to buy each piece? Thanks.
  24. Oct 17, 2019 at 6:48 AM
    #2154
    Roman
    Roman
    Franklin, TN
    They're all sold individually. I made a thread for all of the belt moldings here:
    https://www.tundras.com/threads/belt-moldings-for-all-years-and-models.52575/
    Let me know if you need any other weatherstrips or moldings. I may need a picture of it to figure out which ones you're referring to.
  25. Oct 17, 2019 at 9:33 AM
    #2155
    Kerch71
    Mechanicsville VA
    Those are the ones. Ordered for all 4 windows. Much appreciated!
  26. Oct 20, 2019 at 2:56 AM
    #2156
    unclebeejo808
    unclebeejo808 New Member
    Oahu
    Was about to order the pro grille until I seen the shipping to Hawaii, $332. I gotta hope one pops up on cL. Can’t stand all that chrome isn’t he drone.
  27. Oct 22, 2019 at 8:03 AM
    #2157
    bmann7
    bmann7 Silver Sky Platinum Pro
    WA
    2019 SSM Tundra Crewmax Platinum
    See signature line
    What about an OEM bed mat for a 2019 Crewmax? Shipped to 98105 (ish)
  28. Oct 22, 2019 at 8:50 AM
    #2158
    Roman
    Roman
    Franklin, TN
  29. Oct 22, 2019 at 10:28 AM
    #2159
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Roman, can you confirm...that none of the honeycomb grilles fit on a 2015 SR5?
  30. Oct 22, 2019 at 10:30 AM
    #2160
    Roman
    Roman
    Franklin, TN
    I can not confirm that. They all fit the 2015. All 2014+ grilles are interchangeable.
    GODZILLA and Pinay[QUOTED] like this.
