Ultimate OEM Toyota Parts Thread for 2nd gens (2007-21)
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Feb 16, 2017.
  1. Aug 9, 2018 at 10:18 AM
    #1021
    yosh2000
    yosh2000 New Member
    Denver
    '17 MGM CM Tundra
    yep
  2. Aug 12, 2018 at 6:06 PM
    #1022
    Yzed608
    Yzed608 New Member
    Wisconsin
    So after seeing @belanger9 has a powered rear DC sliding window (https://www.tundras.com/threads/roll-down-rear-window-on-the-crewmax.25187/page-4#post-631498) I decided to see what would be necessary to add it, not sure why some have it and some don't. I found part numbers:
    https://parts.toyotaofcoolsprings.c...-engine/body-cat/glass-and-hardware-back-scat
    https://parts.toyotaofcoolsprings.c...gas-engine/body-cat/cluster-and-switches-scat
    So it looks like 2, 4, 6-10 would all be needed? Plus 84810-0C090 Window Switch horizontal open. Is this something could could possible be pre-wired and everything would be there on the truck already and just need to install the motor etc? I'd rather not have to wire the whole thing up from switch to motor. It's already almost not worth it because of the pricing. Just curious as that window doesn't get used right now because I never climb in the back to open it.
  3. Aug 13, 2018 at 7:05 AM
    #1023
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    @Roman ...Does this part come with the 2 vents included? I had talked to you a bit ago about swapping my chrome ones out...just trying to find the most cost effective way of getting rid of the last of the chrome!
  4. Aug 13, 2018 at 7:50 AM
    #1024
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Good question. Only way to know for sure is to have a look and see if it is pre wired. I can't recall anyone attempting this swap, so I don't really know. ¯\_(ツ)_/¯
    Yzed608[QUOTED] likes this.
  5. Aug 13, 2018 at 7:51 AM
    #1025
    Roman
    Roman
    Franklin, TN
    Yes, it does come with the vents.
  6. Aug 15, 2018 at 2:33 PM
    #1026
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
    2014 Silver Tundra SR5
    3in ToYtech lift on Tundra and 2.5in in the rear. Tow Mirrors. Toyota grill, and Front bumber. New 6in antenna. Repainted the stepping boards
    Thanks @Roman that first post help me alot.
    Roman[OP] likes this.
  7. Aug 15, 2018 at 8:27 PM
    #1027
    ARES
    ARES ARES Fabrications
    God Bless America
    2018 Tundra TRD Cement
    If your wanting the 2017 TRD pro grille or the 2019 TRD PRO GRILLE on your 2018-2019 Toyota Tundra I have developed a relocation bracket that will relocate the radar to a functioning location. @Roman
    $100 shipped
    2017 TRD PRO Grille, 2018 Honey comb, platinum Grille Bracket kit. This bracket is adjustable for lifted suspension systems.
    $100 Shipped
    2019 TRD PRO Grille Shield/Bracket.
    - If you do not have a 2018-2019 Tundra you can still use this shield on the grille
    The new batch of shields will match the oem grille color I just got the dye mixture off.
    Roman[OP] and Spitfire like this.
  8. Aug 15, 2018 at 8:44 PM
    #1028
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
    Ares post a pic of your truck so I can see whole front end thx
  9. Aug 15, 2018 at 9:09 PM
    #1029
    ARES
    God Bless America
    I didnt take a photo of the entire truck just the front. I can take a few tomorrow after I get the color matched grille piece on.
    KnuckleHD likes this.
  10. Aug 15, 2018 at 11:16 PM
    #1030
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    @Roman. Do you have a link for the 2018 TRD sport rear shocks? The red shocks.
  11. Aug 16, 2018 at 6:38 AM
    #1031
    Roman
    Roman
    Franklin, TN
  12. Aug 19, 2018 at 7:29 AM
    #1032
    ARES
    God Bless America
    Ares 2019 TRD PRO GRILLE Shield kit
    Try not to drool....
    Dunno if its just me but im kind of digging the new setup
    emdcksn and Tundracollector like this.
  13. Aug 20, 2018 at 11:29 AM
    #1033
    dmking8
    dmking8 New Member
    DAVID
    Hey Roman. This is such a great write-up. Everything you need to know is right here. Is the FORUM20 promo code for 20% of the order or just shipping? Thanks.
  14. Aug 20, 2018 at 11:55 AM
    #1034
    easleycrawler
    Travis
    Shipping.
    Roman[OP] and dmking8[QUOTED] like this.
  15. Aug 20, 2018 at 12:28 PM
    #1035
    Roman
    Roman
    Franklin, TN
    No information is available on them yet.
    SoCal619 likes this.
  16. Aug 20, 2018 at 2:40 PM
    #1036
    iamvietness
    iamvietness New Member
    Dallas, TX
    @Roman any update on the 2019 TRD Pro fogs? I just ordered the headlights and completely forgot about the fogs
  17. Aug 21, 2018 at 3:28 PM
    #1037
    @Roman having trouble finding a/c compressor, 1997 Toyota T100 3.4 V6 vin#
    JT4UN22D9V0046609 , even went to Denso site and and that part number don't match OEM one I have KIMG0445.jpg
    0914 is number after 447200
    Recommend anywhere else?
  18. Aug 22, 2018 at 6:43 AM
    #1038
    Roman
    Roman
    Franklin, TN
  19. Aug 22, 2018 at 7:18 AM
    #1039
  20. Aug 22, 2018 at 7:19 AM
    #1040
    Roman
    Roman
    Franklin, TN
    I do not have one in stock. It's a special order part.
  21. Aug 22, 2018 at 7:34 AM
    #1041
    Happen to know why Denso site when I put in info numbers don't match?
  22. Aug 22, 2018 at 7:47 AM
    #1042
    Roman
    Roman
    Franklin, TN
    ¯\_(ツ)_/¯ Your guess is as good as mine.
  23. Aug 24, 2018 at 10:40 AM
    #1043
    Ryooo
    Ryooo New Member
    Boynton Beach FL
    2014 CM SC Platinum
    TRD Supercharger 4.5 BDS lift 20” Method Standards sitting on 35 Nitto Grapplers Rigid grill top and bottom with lights AMP running boards Fender flares Magnum rear bumper Rear LED bar Air bags with onboard compressor Brake controller Alpine Navi Alpine amps x 2 Focal Separates front and rear 2 x JL 13s in a stealth box behind the back seat LTE cellular booster Rear seat under locked storage Dynamat from ceiling to floor LEDs all over Bed liner Bed rails Paint protector covering nearly the entire front end and more
    Hey @Roman do you have a link for the OE TRD Pro Fog lights (rigid) and mounting bezel? We contacted Rigid and they don’t sell them.
  24. Aug 24, 2018 at 10:41 AM
    #1044
    Ryooo
    Ryooo New Member
    Boynton Beach FL
    2014 CM SC Platinum
  25. Aug 24, 2018 at 10:45 AM
    #1045
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Already asked, he does not.
    Also asked a buddy of mine to look in the catalogue with no luck.
  26. Aug 24, 2018 at 10:46 AM
    #1046
    Ryooo
    Ryooo New Member
    Boynton Beach FL
    2014 CM SC Platinum
    Dang, ok thanks. That’s weird.
  27. Aug 24, 2018 at 10:48 AM
    #1047
    14burrito
    2014 SR5 CM 4x4 5.7
    SoCal619 and Roman[OP] like this.
  28. Aug 24, 2018 at 10:53 AM
    #1048
    Ryooo
    Ryooo New Member
    Boynton Beach FL
    2014 CM SC Platinum
    You’re on it man! Keep me posted if you hear anything new. Thanks for all the info/research.
    14burrito[QUOTED] likes this.
  29. Aug 24, 2018 at 12:23 PM
    #1049
    Roman
    Roman
    Franklin, TN
    OP will be updated with any new parts for the 2019 Pro as soon as I get it. :)
    Ryooo, SoCal619 and 14burrito like this.
  30. Aug 24, 2018 at 7:22 PM
    #1050
    Inder
    Inder New Member
    Inderjit
    2014 Tundra SR
    Hello everyone. I am new member to this forum. I would like to ask if those LED headlights will be compatible with a 2014 Tundra 4.0L SR.
