Ultimate OEM Toyota Parts Thread for 2nd gens (2007-21)
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Feb 16, 2017.
  1. Apr 26, 2018 at 8:02 AM
    #781
    itsdchz
    itsdchz 50statesoverland
    Clovis, CA
    2018 SR5 CM Cement 4x4
    Icon, UCAs, Method, SSO, KB VOODOO, Skids and Sliders
  2. Apr 26, 2018 at 8:24 AM
    #782
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    That is because the grille is technically for a TRD Pro. When the system sees you do not have a TRD Pro, it says it is incompatible, but of course we know the grilles are interchangeable between the two models.
    That part is for the 4WD model.
    2WD = 55405-0C010-C1
    4WD = 55405-0C020-C1
    ryanwgregg likes this.
  3. Apr 26, 2018 at 8:30 AM
    #783
    Cfincke
    San Antonio
    How early you leaving today?
    And do you have the power fold tow mirrors in stock or would they have to be ordered?
  4. Apr 26, 2018 at 9:03 AM
    #784
    itsdchz
    Clovis, CA
    020 does not seem to have the hole cut out for the 2WD-4WD knob.... could you verify? The original pic posted has it, however, neither of the part numbers you referenced has the cut out.. ideas why?
  5. Apr 26, 2018 at 10:44 AM
    #785
    Roman
    Roman
    Franklin, TN
    I'm leaving at about 3. I do have those mirrors in stock, though.
    It is definitely for the 4WD. The image in the diagram is just a general image for the part. It's not going to have minute differences for each individual iteration of a single part.
    Cfincke[QUOTED] likes this.
  6. Apr 26, 2018 at 10:47 AM
    #786
    itsdchz
    Clovis, CA
    Thank you Roman!!
    Roman[QUOTED][OP] likes this.
  7. Apr 28, 2018 at 5:34 PM
    #787
    TTU-Tundra
    TTU-Tundra New Member
    2014 Black 1794
    What is the part number for a black (preferably 218 Attitude black if it’s available) front fender? I have a 14 1794 edition I am in the process of blacking it out. See pic for reference
  8. Apr 28, 2018 at 5:38 PM
    #788
    TTU-Tundra
    2014 Black 1794
  9. Apr 28, 2018 at 7:20 PM
    #789
    Axelay2003
    Axelay2003 New Member
    2018 Tundra
  10. Apr 30, 2018 at 7:24 AM
    #790
    Tophergt99
    Tophergt99 Back in black
    Weston, Wisconsin
    2015 SR5 Black TRD Crewmax
    In progress....
    Looked on you site but couldn't find a part #, missing a door stop like this.20180429_201319.jpg
  11. Apr 30, 2018 at 8:37 PM
    #791
    Tophergt99
    Weston, Wisconsin
    In progress....
    Is the new SR grill center black?
  12. May 1, 2018 at 6:40 AM
    #792
    Roman
    Roman
    Franklin, TN
    Looks black to me.
    Picture from the OP
  13. May 1, 2018 at 10:26 AM
    #793
    Tophergt99
    Weston, Wisconsin
    In progress....
    If it is good, might have to update my black beast :D Do you know if the clips are in the same spots as a 15 grill outside?
  14. May 1, 2018 at 11:43 AM
    #794
    Roman
    Roman
    Franklin, TN
    Yep, they are. It's interchangeable with the 2014-17 grilles.
  15. May 1, 2018 at 11:46 AM
    #795
    Roman
    Roman
    Franklin, TN
  16. May 1, 2018 at 11:48 AM
    #796
    Roman
    Roman
    Franklin, TN
    Those do not come painted in the body color from the factory. Your best bet is to take yours to a local body shop and have it painted.
  17. May 1, 2018 at 11:48 AM
    #797
    Roman
    Roman
    Franklin, TN
  18. May 1, 2018 at 1:38 PM
    #798
    ldale
    ldale New Member
    Txk Tx
    17' Limited Silver Sky Metalic
    Tonno Pro LowPro , TRD Sway Bar, Helwig Leaf Pack
    Nice! Makes me glad mine came with smoked lens.
  19. May 1, 2018 at 2:32 PM
    #799
    SHawthy33
    SHawthy33 New Member
    Shawn
    2015 Toyota Tundra Platinum
    Picking it up on Thursday
    @Roman - first post here, I pick up my 2015 Platinum on Thursday, but this is unreal. Scrolling through reading and planning over the past few days. A forum like this is lucky to have you.
    Looking forward to putting in a bulk order with you shortly.
  20. May 2, 2018 at 6:35 AM
    #800
    Roman
    Roman
    Franklin, TN
    I do what I can to help you guys give me your money as easily as possible. :D
    Blueknights75 and Erichudgins like this.
  21. May 2, 2018 at 3:34 PM
    #801
    willworkfor4x4
    willworkfor4x4 New Member
    Is the "map clip" for the overhead center console available by itself? 2014 SR5.
    Also, how about a part number on the dome light lens?
  22. May 3, 2018 at 6:45 AM
    #802
    Roman
    Roman
    Franklin, TN
    Map clip? Do you have a picture of it?
    Also, the dome light lens is not available separately. The dome light has to be replaced. Is yours a Double Cab or Crewmax? Gray or tan interior?
  23. May 3, 2018 at 8:14 AM
    #803
    willworkfor4x4
    It’s grey- here’s a pic of the missing clip. I’m guessing it also has to be fully replaced :(
  24. May 3, 2018 at 9:04 AM
    #804
    Roman
    Roman
    Franklin, TN
    That is correct. Here's a link to it:
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-map-lamp-assembly-636500c420b0
    The dome lamp is dependent on which cab you have.
    Double cab
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-dome-lamp-assembly-812400c050b0
    Crewmax
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-dome-lamp-812400c060b0
  25. May 7, 2018 at 11:27 AM
    #805
    willworkfor4x4
    How about the LED lights, 00016-34089?
  26. May 7, 2018 at 7:20 PM
    #806
    Steve89gt
    Steve89gt New Member
    2018 Limited CM
    De-badged, De-chromed, TRD CAI, TRD Exhaust, Bilstein 5100s, Fuel 18 x 9 wheels, BFG KO2s 275/70/18, ESP Underseat Storage
    You're a real man of the people, "Romantic"...:p
  27. May 9, 2018 at 7:32 AM
    #807
    wwinslett
    wwinslett New Member
    Will
    Birmingham AL
    2016 Tundra CM Magnetic Grey
    6112's Toytec Shackles Method NV on Ridge Grapplers 295/70/18
    I'm hearing/reading more rumors of the TRD PRo Grill being discontinued. Any validity in this @Roman
    I'm on the fence about buying one and want to pull the trigger if this true
  28. May 9, 2018 at 8:07 AM
    #808
    Roman
    Roman
    Franklin, TN
    Those are aftermarket. The 00016 on the beginning of the part number shows that it is an aftermarket part from a SET or GST dealer.
    None whatsoever. Toyota has to maintain these parts for at least 10 years. BUT, 10 years sneaks up on you quick, so you might want to just grab one now. :D
  29. May 10, 2018 at 10:57 AM
    #809
    elemento911
    elemento911 New Member
    Eric
    Hey Roman,
    I have a White 2018 Tundra SR5 Crewmax TRD Sport (4x4) and wanted to replace the black handles with the color matched white ones. Do you know if the ones in the link below will work? When I contacted my local dealer they mentioned they made not have color matched as an option for 2018, just the black and chrome. Most of these say compatible with 2007+ so I wanted to confirm. Thanks!
    https://parts.toyotaofcoolsprings.c...ssories-door-handles-door-handles?parent=1001
    Thanks again,
    Eric
  30. May 10, 2018 at 12:21 PM
    #810
    Roman
    Roman
    Franklin, TN
    Yep, those will work. Swapped them on many of the 2018s.
